I have a small flash game where, for a section, I need a sniper scope custom cursor. After this section I want to return to using the default cursor. Does anyone know the code needed to do so, as the code snippets within animate and other discussions haven't been able to help me.
This is the current code I'm using to create the cursor (animate code snippet with my cursor name "scope1"):
And this is the closest I have been to resolving it so far:
Thank you for any and all help,
Rob.
If there is no other code than what you showed, the timeline would have gone quickly onto the Mouse.show() frame. You would normally have a stop() somewhere, and only go on to the Mouse.show() when you're finished with the custom cursor.
Also, if there is anything inside the scope sight that might trap the mouse click you ought to set mouseChildren to false.
Here are scripts I just tested, and the initial frame:
scope1.mouseEnabled = false;
scope1.mouseChildren = false;
scope1.visible = true;
scope1.a
...Copy link to clipboard
scope1.addEventListener(Event.ENTER_FRAME, fl_CustomMouseCursor);
stage.addEventListener(MouseEvent.CLICK, clicked);
function fl_CustomMouseCursor(e: Event) {
scope1.x = stage.mouseX;
scope1.y = stage.mouseY;
function clicked(e: MouseEvent) {
stage.removeEventListener(MouseEvent.CLICK, clicked);
scope1.removeEventListener(Event.ENTER_FRAME, fl_CustomMouseCursor);
play();
Mouse.hide();
stop();
and on a frame after that, which is reached because to the play() line:
Mouse.show();
scope1.visible = false;
stop();
This is perfect and works completely. I can't thank you enough for the super quick response and fix. You've just made me and my lecturer very happy.
Always a good thing to make lecturers happy!
