6 Replies Latest reply on Jun 18, 2017 4:42 PM by JJMack
    Liquify tool crashes PS CC
    axb-42
      PS Version: CC
      I used to be able to use Liquify tool on my old laptop (XPS 15) but recently after changing to the Surface Book, PS crashed whenever I pull up the tool.
      I tried to disable the "Use Graphics Processor" option and it was somewhat working, i.e. I'm able to open it without crashing the software but the Face-detecting tool is not working. So it's most likely that the graphic card (GeForce GTX 965M) is the problem.
      Any suggestion how to fix this?
      Cheers.
        • 1. Re: Liquify tool crashes PS CC
          Trevor.Dennis Adobe Community Professional (Moderator)
          Liquify uses GPU acceleration and might be affected by GPU settings in Preferences.  Or it might be related to the video card driver.   So make sure your video card driver is up to date as a first step.
          • 2. Re: Liquify tool crashes PS CC
            axb-42 Level 1
            The graphic card appears to be up-to-date!
            • 3. Re: Liquify tool crashes PS CC
              What spec is the surface book?   Open Photoshop and go Help > System Info > Copy and paste to this thread.
              • 4. Re: Liquify tool crashes PS CC
                What does the Windows Crash report show as the failing modules? photoshop CC 2017 Liquify filter crashes application
                • 5. Re: Liquify tool crashes PS CC
                  axb-42 Level 1
                  Adobe Photoshop Version: 2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967  x64
                  Number of Launches: 217
                  Version: 10 or greater
                  System architecture: Intel CPU Family:6, Model:14, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
                  Physical processor count: 2
                  Logical processor count: 4
                  Processor speed: 2808 MHz
                  Built-in memory: 16310 MB
                  Free memory: 13113 MB
                  Memory available to Photoshop: 14407 MB
                  Memory used by Photoshop: 95 %
                  History Thumbnails: Enabled.
                  Touch Bar: Enabled.
                  Alias Layers: Disabled.
                  Modifier Palette: Disabled.
                  Highbeam: Enabled.
                  Image tile size: 128K
                  Image cache levels: 2
                  Font Preview: Medium
                  TextComposer: Latin
                  Display: 1
                  Display Bounds: top=0, left=0, bottom=1000, right=1500
                  OpenGL Drawing: Enabled.
                  OpenGL Allow Old GPUs: Not Detected.
                  OpenGL Drawing Mode: Basic
                  OpenGL Allow Normal Mode: True.
                  OpenGL Allow Advanced Mode: True.
                  AIFCoreInitialized=1
                  AIFOGLInitialized=1
                  OGLContextCreated=1
                  NumGLGPUs=1
                  NumCLGPUs=2
                  NumNativeGPUs=0
                  glgpu[0].GLVersion="4.1"
                  glgpu[0].IsIntegratedGLGPU=0
                  glgpu[0].GLMemoryMB=1024
                  glgpu[0].GLName="Intel(R) HD Graphics 520"
                  glgpu[0].GLVendor="Intel"
                  glgpu[0].GLVendorID=32902
                  glgpu[0].GLDriverVersion="20.19.15.4463"
                  glgpu[0].GLRectTextureSize=16384
                  glgpu[0].GLRenderer="Intel(R) HD Graphics 520"
                  glgpu[0].GLRendererID=6422
                  glgpu[0].HasGLNPOTSupport=1
                  glgpu[0].GLDriver="igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igd12umd64.dll,igdumdim3 2,igd10iumd32,igd10iumd32,igd12umd32"
                  glgpu[0].GLDriverDate="20160706000000.000000-000"
                  glgpu[0].CanCompileProgramGLSL=1
                  glgpu[0].GLFrameBufferOK=1
                  glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.30 - Build 20.19.15.4463"
                  glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1447 ]
                  glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
                  glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
                  glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
                  glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
                  glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
                  glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
                  glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
                  glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[64]
                  glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
                  glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
                  glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
                  glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
                  glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
                  glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
                  glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
                  glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
                  glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
                  glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
                  glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=0
                  clgpu[0].CLPlatformVersion="1.2"
                  clgpu[0].CLDeviceVersion="1.2 CUDA"
                  clgpu[0].IsIntegratedCLGPU=0
                  clgpu[0].CLMemoryMB=2048
                  clgpu[0].CLName="GeForce GTX 965M"
                  clgpu[0].CLVendor="NVIDIA Corporation"
                  clgpu[0].CLVendorID=4318
                  clgpu[0].CLDriverVersion="376.67"
                  clgpu[0].CLBandwidth=6.66935e+10
                  clgpu[0].CLCompute=863.486
                  clgpu[1].CLPlatformVersion="2.0 "
                  clgpu[1].CLDeviceVersion="2.0 "
                  clgpu[1].IsIntegratedCLGPU=1
                  clgpu[1].CLMemoryMB=6516
                  clgpu[1].CLName="Intel(R) HD Graphics 520"
                  clgpu[1].CLVendor="Intel(R) Corporation"
                  clgpu[1].CLVendorID=32902
                  clgpu[1].CLDriverVersion="20.19.15.4463"
                  clgpu[1].CLBandwidth=1.82887e+10
                  clgpu[1].CLCompute=171.496
                  License Type: Subscription
                  Serial number: 90970749101902010530
                  GUIDBucket:
                    bucket: 3
                    test: control
                  Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\
                  Temporary file path: C:\Users\AXB\AppData\Local\Temp\
                  Photoshop scratch has async I/O enabled
                  Scratch volume(s):
                    D:\, 3.64T, 772.7G free
                  Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-ins\
                  Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\
                  Installed components:
                     A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
                     ACE.dll   ACE 2017/01/26-01:10:02   79.579975   79.579975
                     AdbePM.dll   PatchMatch 2016/11/03:19:48:57   1.578146   1.578146
                     AdobeLinguistic.dll   Adobe Linguisitc Library   10.0.0
                     AdobeOwl.dll   Adobe Owl   5.2.11
                     AdobePDFL.dll   PDFL 2016/08/10-16:53:20   79.195992   79.195992
                     AdobePIP.dll   Adobe Product Improvement Program   7.4.1.60.45263
                     AdobeSVGAGM.dll   AdobeSVGAGM   79.579975   79.579975
                     AdobeXMP.dll   Adobe XMP Core 2016/09/14-01:09:01   79.159824   79.159824
                     AdobeXMPFiles.dll   Adobe XMP Files 2016/09/14-01:09:01   79.159824   79.159824
                     AdobeXMPScript.dll   Adobe XMP Script 2016/09/14-01:09:01   79.159824   79.159824
                     adobe_caps.dll   Adobe CAPS   10,0,0,6
                     AGM.dll   AGM 2017/01/26-01:10:02   79.579975   79.579975
                     ahclient.dll    AdobeHelp Dynamic Link Library   2.2.0.1
                     AIDE.dll   AIDE 2016/05/27-01:08:49   79.574279   79.574279
                     amtlib.dll   AMTLib (64 Bit)   10.0.0.119 BuildVersion: 10.0; BuildDate: Thu Dec 22 2016 3:0:7)   1.000000
                     ARE.dll   ARE 2017/01/26-01:10:02   79.579975   79.579975
                     AXE8SharedExpat.dll   AXE8SharedExpat 2015/03/13-23:40:54   79.562390   79.562390
                     AXEDOMCore.dll   AXEDOMCore 2015/03/13-23:40:54   79.562390   79.562390
                     Bib.dll   BIB 2017/01/26-01:10:02   79.579975   79.579975
                     BIBUtils.dll   BIBUtils 2017/01/26-01:10:02   79.579975   79.579975
                     boost_date_time.dll   photoshopdva   10.0.0
                     boost_signals.dll   photoshopdva   10.0.0
                     boost_system.dll   photoshopdva   10.0.0
                     boost_threads.dll   photoshopdva   10.0.0
                     cg.dll   NVIDIA Cg Runtime   3.0.00007
                     cgGL.dll   NVIDIA Cg Runtime   3.0.00007
                     CITThreading.dll   Adobe CITThreading   2.1.0.1   2.1.0.1
                     CoolType.dll   CoolType 2017/01/26-01:10:02   79.579975   79.579975
                     dnssd.dll   Bonjour   3,0,0,2
                     dvaaudiodevice.dll   photoshopdva   10.0.0
                     dvacore.dll   photoshopdva   10.0.0
                     dvacrashhandler.dll   Adobe Audition CC 2017   10.0.0
                     dvamarshal.dll   photoshopdva   10.0.0
                     dvamediatypes.dll   photoshopdva   10.0.0
                     dvametadata.dll   photoshopdva   10.0.0
                     dvametadataapi.dll   photoshopdva   10.0.0
                     dvametadataui.dll   photoshopdva   10.0.0
                     dvaplayer.dll   photoshopdva   10.0.0
                     dvatransport.dll   photoshopdva   10.0.0
                     dvaui.dll   photoshopdva   10.0.0
                     dvaunittesting.dll   photoshopdva   10.0.0
                     dynamiclink.dll   photoshopdva   10.0.0
                     ExtendScript.dll   ExtendScript 2016/12/13-13:10:33   80.1089815   80.1089815
                     icucnv40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                     icudt40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                     icuuc40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                     igestep30.dll   IGES Reader   9.3.0.113
                     imslib.dll   IMSLib DLL   10.0.0.11
                     JP2KLib.dll   JP2KLib 2017/04/05-14:24:38   79.266006   79.266006
                     libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
                     libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
                     libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
                     LogSession.dll   LogSession   7.4.1.60.45263
                     mediacoreif.dll   photoshopdva   10.0.0
                     MPS.dll   MPS 2016/09/14-15:20:26   79.577269   79.577269
                     pdfsettings.dll   Adobe PDFSettings   1.04
                     Photoshop.dll   Adobe Photoshop CC 2017   18.1.1
                     Plugin.dll   Adobe Photoshop CC 2017   18.1.1
                     PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   7.0.0
                     PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   7.0.0.67
                     PSArt.dll   Adobe Photoshop CC 2017   18.1.1
                     PSViews.dll   Adobe Photoshop CC 2017   18.1.1
                     SCCore.dll   ScCore 2016/12/13-13:10:33   80.1089815   80.1089815
                     SVGRE.dll   SVGRE   79.579975   79.579975
                     svml_dispmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
                     tbb.dll   Intel(R) Threading Building Blocks for Windows   4, 4, 2016, 0412
                     tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   4, 4, 2016, 0412
                     TfFontMgr.dll   FontMgr   9.3.0.113
                     TfKernel.dll   Kernel   9.3.0.113
                     TFKGEOM.dll   Kernel Geom   9.3.0.113
                     TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
                     updaternotifications.dll   Adobe Updater Notifications Library   10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   10.0.0.1
                     VulcanControl.dll   Vulcan Application Control Library   5.3.0.16
                     VulcanMessage5.dll   Vulcan Message Library   5.3.0.16
                     WRServices.dll   WRServices Thu Jan 07 2016 04:50:10   Build 0.21960   0.21960
                     wu3d.dll   U3D Writer   9.3.0.113
                  Required plug-ins:
                     3D Studio 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                     Accented Edges 18.1.1 - from the file “Filter Gallery.8bf”
                     Adaptive Wide Angle 18.1.1 - from the file “Adaptive Wide Angle.8bf”
                     Angled Strokes 18.1.1 - from the file “Filter Gallery.8bf”
                     Average 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Average.8bf”
                     Bas Relief 18.1.1 - from the file “Filter Gallery.8bf”
                     BMP 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Camera Raw 9.10.1 - from the file “Camera Raw.8bi”
                     Camera Raw Filter 9.10.1 - from the file “Camera Raw.8bi”
                     Chalk && Charcoal 18.1.1 - from the file “Filter Gallery.8bf”
                     Chrome 18.1.1 - from the file “Filter Gallery.8bf”
                     Cineon 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Cineon.8bi”
                     Clouds 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Clouds.8bf”
                     Collada 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                     Color Halftone 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Colored Pencil 18.1.1 - from the file “Filter Gallery.8bf”
                     CompuServe GIF 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Conté Crayon 18.1.1 - from the file “Filter Gallery.8bf”
                     Craquelure 18.1.1 - from the file “Filter Gallery.8bf”
                     Crop and Straighten Photos 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “CropPhotosAuto.8li”
                     Crop and Straighten Photos Filter 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Crosshatch 18.1.1 - from the file “Filter Gallery.8bf”
                     Crystallize 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Cutout 18.1.1 - from the file “Filter Gallery.8bf”
                     Dark Strokes 18.1.1 - from the file “Filter Gallery.8bf”
                     De-Interlace 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Dicom 18.1.1 - from the file “Dicom.8bi”
                     Difference Clouds 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Clouds.8bf”
                     Diffuse Glow 18.1.1 - from the file “Filter Gallery.8bf”
                     Displace 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Dry Brush 18.1.1 - from the file “Filter Gallery.8bf”
                     Eazel Acquire 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “EazelAcquire.8ba”
                     Entropy 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                     Export Color Lookup Tables 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Export3DLUT.8be”
                     Extrude 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     FastCore Routines 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “FastCore.8bx”
                     Fibers 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Film Grain 18.1.1 - from the file “Filter Gallery.8bf”
                     Filter Gallery 18.1.1 - from the file “Filter Gallery.8bf”
                     Flash 3D 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                     Fresco 18.1.1 - from the file “Filter Gallery.8bf”
                     Glass 18.1.1 - from the file “Filter Gallery.8bf”
                     Glowing Edges 18.1.1 - from the file “Filter Gallery.8bf”
                     Google Earth 4 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                     Graphic Pen 18.1.1 - from the file “Filter Gallery.8bf”
                     Halftone Pattern 18.1.1 - from the file “Filter Gallery.8bf”
                     HDRMergeUI 18.1.1 - from the file “HDRMergeUI.8bf”
                     HSB/HSL 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     IFF Format 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     IGES 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                     Ink Outlines 18.1.1 - from the file “Filter Gallery.8bf”
                     JPEG 2000 18.1.1 - from the file “JPEG2000.8bi”
                     Kurtosis 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                     Lens Blur 18.1.1 - from the file “Lens Blur.8bf”
                     Lens Correction 18.1.1 - from the file “Lens Correction.8bf”
                     Lens Flare 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Liquify 18.1.1 - from the file “Liquify.8bf”
                     Matlab Operation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “ChannelPort.8bf”
                     Maximum 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                     Mean 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                     Measurement Core 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MeasurementCore.8me”
                     Median 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                     Mezzotint 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Minimum 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                     MMXCore Routines 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MMXCore.8bx”
                     Mosaic Tiles 18.1.1 - from the file “Filter Gallery.8bf”
                     Multiprocessor Support 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MultiProcessor Support.8bx”
                     Neon Glow 18.1.1 - from the file “Filter Gallery.8bf”
                     Note Paper 18.1.1 - from the file “Filter Gallery.8bf”
                     NTSC Colors 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “NTSC Colors.8bf”
                     Ocean Ripple 18.1.1 - from the file “Filter Gallery.8bf”
                     OpenEXR 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Paint Daubs 18.1.1 - from the file “Filter Gallery.8bf”
                     Palette Knife 18.1.1 - from the file “Filter Gallery.8bf”
                     Patchwork 18.1.1 - from the file “Filter Gallery.8bf”
                     Paths to Illustrator 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     PCX 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “PCX.8bi”
                     Photocopy 18.1.1 - from the file “Filter Gallery.8bf”
                     Photoshop 3D Engine 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Photoshop3DEngine.8bi”
                     Photoshop Touch 14.0 - from the file “PSDX.8bi”
                     Picture Package Filter 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “ChannelPort.8bf”
                     Pinch 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Pixar 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Pixar.8bi”
                     Plaster 18.1.1 - from the file “Filter Gallery.8bf”
                     Plastic Wrap 18.1.1 - from the file “Filter Gallery.8bf”
                     PLY 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                     PNG 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Pointillize 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Polar Coordinates 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Portable Bit Map 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “PBM.8bi”
                     Poster Edges 18.1.1 - from the file “Filter Gallery.8bf”
                     PRC 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                     Radial Blur 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Radiance 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Radiance.8bi”
                     Range 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                     Render Color Lookup Grid 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Export3DLUT.8be”
                     Reticulation 18.1.1 - from the file “Filter Gallery.8bf”
                     Ripple 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Rough Pastels 18.1.1 - from the file “Filter Gallery.8bf”
                     Save for Web 18.1.1 - from the file “Save for Web.8be”
                     ScriptingSupport 18.1.1 - from the file “ScriptingSupport.8li”
                     Shake Reduction 18.1.1 - from the file “Shake Reduction.8bf”
                     Shear 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Skewness 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                     Smart Blur 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Smudge Stick 18.1.1 - from the file “Filter Gallery.8bf”
                     Solarize 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Solarize.8bf”
                     Spaces 18.1.1 - from the file “Spaces.8li”
                     Spatter 18.1.1 - from the file “Filter Gallery.8bf”
                     Spherize 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Sponge 18.1.1 - from the file “Filter Gallery.8bf”
                     Sprayed Strokes 18.1.1 - from the file “Filter Gallery.8bf”
                     Stained Glass 18.1.1 - from the file “Filter Gallery.8bf”
                     Stamp 18.1.1 - from the file “Filter Gallery.8bf”
                     Standard Deviation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                     STL 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                     Sumi-e 18.1.1 - from the file “Filter Gallery.8bf”
                     Summation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                     Targa 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Texturizer 18.1.1 - from the file “Filter Gallery.8bf”
                     Tiles 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Torn Edges 18.1.1 - from the file “Filter Gallery.8bf”
                     Twirl 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     U3D 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                     Underpainting 18.1.1 - from the file “Filter Gallery.8bf”
                     Vanishing Point 18.1.1 - from the file “VanishingPoint.8bf”
                     Variance 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                     Virtual Reality Modeling Language | VRML 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                     Water Paper 18.1.1 - from the file “Filter Gallery.8bf”
                     Watercolor 18.1.1 - from the file “Filter Gallery.8bf”
                     Wave 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Wavefront|OBJ 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                     WIA Support 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “WIASupport.8li”
                     Wind 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Wireless Bitmap 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “WBMP.8bi”
                     ZigZag 18.1.1 - from the file “Standard MultiPlugin.8bf”
                  Optional and third party plug-ins:
                     Imagenomic Plug-in Console 1, 2, 0, 0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\Imagenomic\ImagenomicPluginConsole64.8li”
                     Portraiture 2.3.4.1 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\Imagenomic\Portraiture64.8bf”
                  Duplicate and Disabled plug-ins: NONE
                  Plug-ins that failed to load: NONE
                  Extensions:
                     Recent Files  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
                     com.adobe.inapp.purchase  2.10.56 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_10_56\purchase.html”
                     New Document  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\fnft.html”
                     Libraries  2.10.56 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_10_56\index.html”
                     Start  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
                     com.adobe.experimentation.extension  2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.experimentation.extension\index.html”
                     BEAUTY RETOUCH v3.1  3.1.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\BeautyRetouch\index.html”
                     Adobe Color Themes  6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
                     Export As  3.0.8 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
                     Device Preview  1.3.2 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSPanel\panel.html”
                     com.adobe.preview.loader  1.3.2 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSLoader\loader.html”
                  Installed TWAIN devices: NONE
                  • 6. Re: Liquify tool crashes PS CC
                    Search
                    Intel® Graphics Driver for Windows* [15.45]
                    Date: 05/30/2017 Version: 15.45.19.4678 Type: Drivers
                    OS: Windows® 10, 64-bit*; Windows 8.1, 64-bit*; Windows 7, 64-bit*
                    Installs the Intel® Graphics Driver version 15.45.19.4678 for Windows*.
