3 Replies Latest reply on Jun 20, 2017 5:41 AM by A. Patterson
    Storing ITextRange/TextRangeRef in dictionary
    alam_84 Level 1
      HI All,
      Is it possible to store selected text range reference i.e TextRangeRef in a dictionary? It would  help me if some one can explain this with a code snippet.
      I tried following to get UIDRef but api GetUID complains type mismatch error
      AIUIDRef uidref;
      sUIDRef->GetUID(textRange.GetRef(), &uidref);
      I have found same unanswered query at https://forums.adobe.com/message/5182873#5182873
      Regards,
      Alam
        • 1. Re: Storing ITextRange/TextRangeRef in dictionary
          A. Patterson Level 4
          Unanswered? I answered all the questions in that thread!
          It does sound like you're interested in the same thing, why exactly don't the answers I posted there work for your situation?
          • 2. Re: Storing ITextRange/TextRangeRef in dictionary
            alam_84 Level 1
            Thanks Patterson for quick reply
            I see your replies in that thread but you have explained getting art uidRef from textRange
            AIArtHandle GetArt(ATE::ITextRange range)
                 ATE::ITextFramesIterator iter = range.GetTextFramesIterator();
                 AIArtHandle result = 0;
                 if (!iter.IsEmpty()) {
                      ATE::ITextFrame frame = iter.Item();
                      AIErr error = sAITextFrame->GetAITextFrame(frame.GetRef(), &result);
                      if (kNoErr != error) throw ai::Error(error);
                 return result;
            in above code you had explained of getting art UIDRef from textRange but I need the example that will store textRange UIDRef.
            • 3. Re: Storing ITextRange/TextRangeRef in dictionary
              You need to combine that code with the earlier post in the thread:
              AIUIDRef GetId(AIArtHandle handle, bool forceCreate = true)
                   AIUIDRef result = 0;
                   // forceCreate causes the art to generate an id, if it doesn't already have one; this can cause an undo & the document to become modified, so be careful
                   AIErr error = sUIDUtils->GetArtUID(handle, forceCreate ? 1 : 0, &result);
                   return result;
              AIArtHandle GetHandle(AIUIDRef uid)
                   AIUIDREFRef uidRef;
                   AIErr error = sUID->NewUIDREF(uid, &uidRef);
                   error = sUIDUtils->GetReferencedArt(uidRef, &result);
                   // if the art referenced by uid no longer exists result will be 0
                   sUIDRef->Release(uidRef);
                   return result;
              Then, like so:
              AIArtHandle handle = GetArt(textRange);
              AIUIDRef uid = GetId(handle);
              There's no such thing as getting an AIUIDRef for a text range directly. Only AIArtHandles can have AIUIDRefs, but fortunately all text ranges have an associated AIArtHandle.
