0 Replies Latest reply on Jun 19, 2017 12:43 PM by janeller316
    Exporting numbered lists not working...
    janeller316 Level 1
      I find that when I export complex numbered lists, they don't export right.
      For example, if I export the following list:
      1. XXXXX
           a. nnnnn
           b. ccccc
      2. xxxxx
      It might look like this in the Epub:
      1. XXXXX
           1. nnnnn
           2. ccccc
      3. xxxxx
      Or like this:
      1. XXXXX
           1. nnnnn
           2. ccccc
      2. xxxxx
      Occasionally, I've even had numbers be out of order:
      1. XXXXX
      2. nnnnn
      3. ccccc
      5. a. xxxxx
           b. xxxxx
      4. dddd
      I read one similar question where the solution would be to have it convert to text on export, but when I tried this with a sample file, this resulted in no space between the numbers and sentence (meaning it's either jammed up right next to each other or (in the case of numbers over 10) with the period and the answer overlapping). In addition, alignment is very messy and unprofessional looking.  It's certainly nothing anyone would want to publish unless it's that or nothing at all. Is there a better way to do this or fix the problem?
