I very disappointed with Adobe Dreamweaver CC 2017.5. I was hoping the new Classic Theme option would have the option to see my PHP code in the colors as it has been for the last 10 years.
The issue is "Document type" is not available in Dreamweaver CC 2017.5 as it was in Dreamweaver CC 2015 (screen print below to illustrate).
Tech support has sent me the following link: Learn how you can customize the colors of your code elements in Dreamweaver.
However we should not have to spend hours trying to make the code colors look like it did in the previous version.
I managed to make the PHP code colors look like they were in Dreamweaver CC 2015.
Here are the changes I made to main.less
Change the background to white:
/* Define some variables used in multiple places */
/* 1. Background color for the code view */
@background: #FFFFFF;
/* 2. Foreground color for the code view (Regular strings or text) */
@foreground: #3A3A3A;
also in the PHP section I added the following:
.cm-comment {
color: #ffa86c !important;
.cm-keyword {
color: #00750f !importan
...Copy link to clipboard
.cm-comment {
.cm-keyword {
color: #00750f !important;
.cm-def {
color: #000000 !important;
.cm-variable-2 {
color: #0e83fc !important;
.cm-variable-3 {
color: #db2114 !important;
.cm-string {
Also this link is very helpful in determining the CSS names.
In addition to the CSS I show above, I also needed to add the following to the main.less in two areas, the HTML and the PHP. This will allow the cursor to be seen when tags or brackets are highlighted.
.CodeMirror-matchingtag {
background-color: #CCCCCC !important;
.CodeMirror-matchingbracket {
background-color: #dedede;
The first thing I'd like to mention is that any changes to the main.less file require restarting Dreamweaver before the changes take effect.
If you would like to make Dreamweaver CC 2017.5 look like it did on Dreamweaver 2015 using the PHP theme here is what you can do.
Edit the main.less file.
Line #133 change the background to white:
@background: FFFFFF;​
All other changes have been added below line #407
/* Custom code colors or overrides should start after this line */
.cm-comment {
.cm-keyword {
.cm-def {
.cm-variable-2 {
.cm-variable-3 {
.cm-string {
.CodeMirror-matchingbracket, .CodeMirror-matchingtag {
/* Ensure visibility against white background */
background-color: #ffffff !important;
