I just purchased an HP PageWide Pro MPF with a single pass ADF scanner, which allows two-sided documents to be scanned simultaneously. Am now having trouble getting Adobe Acrobat Standard to scan both sides of a two sided document with this MPF. Any ideas how to get Adobe to scan both sides of a two sided document using this single pass technology?
Please be advised as I was providing below information, I realized I had
exchanged printers (same model) but had uninstalled software and then
reinstalled software with second printer.
Tried Adobe again, and the single pass scanner now works correctly with
two-sided documents being scanned, so it appears my.issue has bern resolved.
Thank you
Bruce R.
--- Forwarded message ---
Hi brucer18892299,
Sorry for the delay in response.
Have you tried to check if you have any pending updates for Acrobat, to check for pending updates, launch Acrobat>Help> Check for updates. Also, try to check for the latest drivers for the scanner.
If the issue is still reproducible, please help us with the following information.
1. Operating system name and version.
2. Acrobat version installed. To check launch Acrobat> Adobe Adobe Acrobat.
3 Driver version for the scanner and is it WIA or Twain driver?
4. Make and model of the scanner.
Will be waiting for your response.
-Tariq Dar
No new updates found for Adobe/current version
Drivers on printer brand new, completely updated
1) Windows 7 Pro, 64 bit
2) Adobe Acrobat Standard DC, version 2015.006.30306
3) HP Pagewide Pro 577dw scanner driver 38.1.1859.57182,TWAIN and WIA (using TWAIN)
4) HP Pagewide Pro 577dw MFP with scanner
Bruce R.
Thank you
Bruce R.
Thank you, Bruce, for the information and the solution.
I am Happy your issue is resolved now.
-Tariq Dar.
Here's a fairly straight-forward manual way to create a PDF of single-sided scans of a two-sided document using Adobe Acrobat and Adobe Bridge with no scripting.
@AM_Dave: that may seem straight forward to you, for everyone else it's complicated as heck.
Use VueScan or another third party utility such as Foxit Business. The fact that Adobe Acrobat lacks the functionality to allow one to scan double sided sheets with a single side scanner is absurd.
Right? I'm having this same issue after recent Acrobat updates, only to come here and find threads on the same problem dating back to 2014. Seriously, wtf? I pay way to much money for this suite for this kind of BS to be happening to literally 101 level functionality. Get your act together Adobe.
