4 Replies Latest reply on Jun 22, 2017 5:28 PM by Yuliascript
    How to assign blend mode to a graphic in indesign CS6, javascript
    Yuliascript
      I need to set blend mode for artwork to multiply in Indesign CS 6 through Javascript:
      myLinkFile = myFrame.place (myFile);
      myFile.blendmode = multiply;
      But I was not able to find it in Object Model Viewer.
      Thank you.
      Yulia
        • 1. Re: How to assign blend mode to a graphic in indesign CS6, javascript
          Hi Yulia,
          see into:
          Adobe InDesign CS6 (8.0) Object Model JS: TransparencySetting
          Climb up in the hierarchy of objects to get to e.g. contentTransparencySettings etc.pp. if needed.
          Here an example with transparencySettings :
          // Example
          // Select an object on the page
          var item = app.selection[0];
          item.transparencySettings.blendingSettings.properties =
              blendMode : BlendMode.MULTIPLY ,
              opacity : 50 ,
              isolateBlending : false ,
              knockoutGroup : false
          Best download the iChm files to search in DOM documentation by Jongware here:
          Indesign JavaScript Help
          Regards,
          Uwe
          • 2. Re: How to assign blend mode to a graphic in indesign CS6, javascript
            Yuliascript Level 1
            Yes, thank you, it did work. I had to remove opacity, but all else is good:
            Yulia
            • 3. Re: How to assign blend mode to a graphic in indesign CS6, javascript
              Hi Yulia,
              why do you like to set the blendmode to the contents of variable myFile ? Your code is suggesting this.
              I guess, there is actually a file object stored with this variable. You cannot set transparency to a file stored in your system.
              For that you would like to open it in the creator app and set transparency there.
              Instead you would set transparency to a placed "thing" on a page in InDesign that could be anything depending on your file type.
              An image, a vector graphic, a PDF etc.pp.
              So check what's in variable myLinkFile that is returned by method place() :
              $.writeln(myLinkFile);
              But be not misguided what you see with that. Also ask:
              $.writeln(myLinkFile.constructor.name);
              And if that's clear, also do:
              $.writeln(myLinkFile.length);
              And maybe you want to know:
              $.writeln(myLinkFile[0].constructor.name);
              And now think about what object you like to set to multiply.
              The "thing" inside the frame?
              ( Could also be outside the frame depending on the file type you are placing even if you do myFrame.place() ) [*]
              myLinkFile[0]
              or the frame, that would be:
              myFrame
              That frame could be also defined as:
              myLinkFile[0].parent
              But it's not sure if myFrame and myLinkFile[0].parent is always the same object. [*]
              Look up this:
              Adobe InDesign CS6 (8.0) Object Model JS: Rectangle
              Would variable myLinkFile always be of length 1 ?
              Depending on the file type—see into IDMS snippet files—the length could be different.
              E.g. if the IDMS snippet file you want to place contains several ungrouped page items.
              [*] FWIW: If you do method place() on a graphic frame with an IDMS snippet file the contents will placed on the spread where the graphic frame resides. And not in the frame. No error message…
              Regards,
              Uwe
              • 4. Re: How to assign blend mode to a graphic in indesign CS6, javascript
                Yuliascript Level 1
                Hi Uwe,
                You are absolutely correct. It did not work when I used it on File object, so I tried it on the rectangle object containing the file and it did work.
                Thank you.
