7 Replies Latest reply on Jun 21, 2017 5:38 PM by coldwetnozz
    Cannot stroke a path
    coldwetnozz Level 1
      I am using PS CC 2017 and I'm having problems stroking a path.   I think I have a setting wrong.  The option is greyed out.  No problem with this in my old PS.  Can you tell me what setting I may have wrong for this to happen?
        • 1. Re: Cannot stroke a path
          S_Gans Adobe Community Professional
          Honestly, it looks to me like you're missing with the selection tool. All of the options that would be active if you were right clicking directly ON the path are grayed out. The thing that, to me indicates it the most is the "Add Anchor Point" normally would show with a checkmark next to it if you were right on the path. That's the default behavior when right clicking a path with the selection tool. Please confirm that you ARE using the black arrow (selection tool, not 'direct selection tool') as well.
          • 2. Re: Cannot stroke a path
            c.pfaffenbichler Level 8
            The screenshot seems pretty much useless as it does not include pertinent Panels like the Layers Panel and the Paths Panel. (edited)
            Instead of using »Stroke Path« destructively using a Shape Layer with Stroke (as set in the Options Bar) may be a better alternative.
            • 3. Re: Cannot stroke a path
              K´mo Level 3
              You are editing a vector mask. It's not a pixel mask so you can't stroke there. You need to have pixel layer or mask and path selected. You may have to copy the path from vector mask, activate pixel layer and then you can make a stroke.
              • 4. Re: Cannot stroke a path
                coldwetnozz Level 1
                I am using the pen tool.  The same way I do it with an older version of PS and it works fine there.  It's a pain to have to save everything , close out and re-open in an older version of PS, which is exactly what I will have to do if this keeps up.
                The problem is probably in the top bar.  I will send another screen shot of that.  Should the word selection be there?
                • 5. Re: Cannot stroke a path
                  K´mo Level 3
                  You have clicked the mask button. Therefore you have the vector mask and maybe it is still active. You can still stroke it if you have targeted something that you can draw.
                  • 6. Re: Cannot stroke a path
                    Once again: The screenshot seems pretty much useless as it does not include pertinent Panels like the Layers Panel and the Paths Panel.
                    • 7. Re: Cannot stroke a path
                      coldwetnozz Level 1
                      Okay I reopened PS and tried again.  This time "Mask" was enabled (not greyed out).
                      This time the stroke option was working.  So the mask option has to be enabled for this to work.  That solves the problem!
                      Thank you all.
