C:\Users\(username)\AppData\Roaming\Adobe\Adobe Muse CC\2017.0
The solution to stop the message File ont the server are missing is not working.
Site worked fine untill I made some minor changes today.
I did change the file in the appprefs. I uploaded the complete site 2 times. No result.
Copy of the appprefs file
<prop.list>
<prop.pair>
<key>MinifyCSSFiles</key>
<true/>
</prop.pair>
<prop.pair>
<key>MinifyJSFiles</key>
<true/>
</prop.pair>
<prop.pair>
<key>SuppressMissingFileError</key>
<true/>
</prop.pair>
</prop.list>
Message was edited by: David Asch Subject title amended.
Dear Askay, Thanks for helping out. I got it working.
I stupidly forgot to close Muse first.
If you change the value with Muse open it's not working. That's obvious.
But if you change the value, close Muse and restart Muse it's set back to False again.
So the lesson is. Close Muse first and then change the value.
Hi Gerard,
Please share the site URL.
Regards,
Akshay
www.you-uv.com
Would ne nice from you, akshay​, to let us know the final solution. For all these unsatisfied customers.
Hi Gerard,
The value of the key is coming up as false on the site, I believe it is not updating on the server.
Can you please export the site as HTML and check if the exported site is showing the correct value of the key?
Regards,
Akshay
Dear akshay​, could this be edited directly from ftp-server as well, if it is to open via ftp with cyberduck or filezilla or …?
Or is it too complicated to find and therefor may lead to follow up error s?
Uwe
I can't find the AppPrefs.xml here Library > Preferences > Adobe > Adobe Muse CC > 2017.0, even the 2017.0 folder on my Mac. Is file hidden anywhere else?
I only know the German part and try to translate:
Apple Menu:
Go To - looks like this:
click ALT and an additional folder will show up, called Library
In my case it shows between Benutzerordner (User?) and Computer (Computer?).
You see how the path looks on my machine:
The ALT-key is really the most important here: Go To - ALT - choose Library.
Does this help?
Best Regards,
Uwe
Thank you so much! I find the MUSE AppPrefs.xml and find the "Files on the server are missing or incorrect solution not working" message without pop again on Chrome. However, all images are still missing on Safari and Firefox.
This is my problem page http://imagineerstudio.net/2017summer/
Please open a new thread for this.
Something is very different to the original question.
It might have nothing to do with "files on server are missing".
Your files show blank white page.
ok
Oh! I haven't check IE, the pages even disappear in all small versions screen size in both safari and firefox, except the larger screen. Only chrome shows the page properly. How can I fix this?
