1 Reply Latest reply on Jun 20, 2017 6:26 AM by Karl Heinz Kremer
    PDF to DOCx Conversion - Text incorrect or missing ... WHY??
      We have PDF's that are needing to be converted into doc to review and change for them to be converted back to PDF. I understand that the pro subscription will change PDF's without needing to convert but the cost can not be covered.
      Is there a setting to stop the fonts from either mixing and merging or being completely different to the original?
      We require the PDFS to be copies of the originals clearly
      Any help will be much appreciated!!
      Thank you
        • 1. Re: PDF to DOCx Conversion - Text incorrect or missing ... WHY??
          Karl Heinz Kremer Adobe Community Professional
          Converting from PDF to Word, Excel or any other format is one of the most complex things you can try to do with a PDF file. It works very well in some cases, in other cases the output has very little to do with the original file. The key for success is that the PDF file needs to be "tagged" - which means that it contains information about the information that is displayed in the file. The best way to make sure that a PDF file is tagged correctly is by using the PDFMaker in Acrobat to create the PDF file from Word or Excel (that's the Acrobat ribbon or toolbar).
          Unfortunately there is not much you can do to improve the output without spending a lot of time (e.g. by manually tagging the file). Also, if you are using Adobe's ExportPDF service and don't have access to Acrobat, that is not even an option.
          The only thing you can do is complain to the original author of the file and tell them that they used a bad PDF generator to create the PDF file.
          Sometimes it helps to save the PDF file as a set of high resolution (e.g. 600dpi) images, then import these images back into Acrobat, run OCR and then export to Word or Excel again.
