10 Replies Latest reply on Jun 21, 2017 4:47 AM by Obi-wan Kenobi
    Fractions in GREP
    Dative Level 1
      Is there a 'wildcard' or the equivalent through which I can select all fractions in GREP?
        • 1. Re: Fractions in GREP
          vinny38 Level 5
          Hi
          You should be more specific about the patterns of what you call "fractions".
          Something like this: (a certain number of digits)+(a slash)+(a certain number of digits) maybe? Like 450/50
          Or do you have separators? 27/1.5 or 27/1,5? Or even 1(space)500/2 or 5,500.50/3
          Or maybe something completely different, possibly built with some math font?
          Please provide more details, being as specific as possible (screenshots can also help)
          Vinny
          • 2. Re: Fractions in GREP
            dhafirp16891848 Level 1
            Try this code: (\d+\.\d+)|[/\d]|\p{no}
            • 3. Re: Fractions in GREP
              Dative Level 1
              Okay so I need to be more specific, what I'm trying to do is find WxH measurements and flip them to HxW.
              This is my code so far.
              (.+)(~<×~<)(.+)(?=~<in\.)
              and change to
              $3$2$1
              While this finds inches I need to be able to find centimetres as well. This is easy enough to do in two steps but I was hoping there was a more elegant solution with one. The structure of the measurements is always as follows
              30 × 29 ⅞ in. (78 × 76 cm)
              With the numbers varying obviously.
              \d doesn't find fractions in the typeface I'm using because they're an individual glyph rather than composite parts.
              I think I need a GREP expression like this (\d+~<(possible fraction))( ~<×~< )(\d~<(possible fraction))(?=~<in\.|~<cm\))
              I seem to remember theres a way using a question mark you can say 'this may appear or it may not' so ideally I'd like it to be ?wildcard for fractions.
              • 4. Re: Fractions in GREP
                Dative Level 1
                I should also note there's probably a way to do it without having to denote the fractions, I would just need the 'any character' expression to end at in. otherwise this happens.
                • 5. Re: Fractions in GREP
                  Try this: (\p{n*}+)(\s×\s)(\p{n*}+\s\p{n*}?)(?=\(?\s?(in|cm))
                  • 6. Re: Fractions in GREP
                    vinny38 Level 5
                    Hi
                    To find your fractions, you can use set of Unicode ranges.
                    Given this site: Searching in Unicode character names for fraction, there are two sets of fractions that could be used to reach fractions (should be tested):
                    U00BC to U00BE and U2153 to U215E
                    Grep query for Unicode range is like this : [\x{Unicode}-\x{Unicode}]
                    So in your case, [\x{00BC}-\x{00BE}\x{2153}-\x{215E}] should catch your fractions.
                    Please notice I've also used the Unicode search pattern to get the multiplication sign.
                    Search:
                    ([\d~<\x{00BC}-\x{00BE}\x{2153}-\x{215E}]+)(~<\x{00D7}~<)([\d~<\x{00BC}-\x{00BE}\x{2153}-\x{215E}]+)(?=~<in\.|~<cm\))
                    Replace:
                    $3$2$1
                    Now, this is very verbose and not very elegant
                    Maybe Grep enthusiasts (Peter Kahrel, Obi-wan Kenobi, and many more) could come up with a better query.
                    Hope that helps anyway
                    Vinny
                    • 7. Re: Fractions in GREP
                      Peter Kahrel Adobe Community Professional & MVP
                      Nice one, vinny38. But you can match fractions with the Unicode property \p{Other_number} (or \p{No} in its abbreviated form). But unfortunately you can't use Unicode properties in character classes, so that [\d\.\p{No}] doesn't work. So you'd get something like this:
                      ((?:\d[\d.]+)(?:\s\p{No})?)   // A digit followed more digits or dots, maybe followed by a space and an 'other' number.
                      \s×\s
                      ((?:\d[\d.]+)(?:\s\p{No})?)  // Another number
                      (?=\s(in\.|cm))
                      It's not entirely clear which one bends the mind more . . .
                      Peter
                      2 people found this helpful
                      • 8. Re: Fractions in GREP
                        vinny38 Level 5
                        Thanks a lot for your answer Peter,
                        I've seen this \p{No} property in dhafirp16891848's answer but couldn't figure out what it was.
                        Much more clear now, although I have no idea on how we could figure that fractions are "other numbers". But that's a specialist call.
                        Also not forgetting about possible dots is definitely a good idea ^^
                        Nice stuff...
                        • 9. Re: Fractions in GREP
                          The Unicode properties aren't documented in InDesign itself. The Find/Change dialog's flyout you can use to insert codes is pathetic, many codes are missing.
                          This script corrects that and adds a few useful things: http://www.kahrel.plus.com/indesign/grep_classes.html
                          P.
                          3 people found this helpful
                          • 10. Re: Fractions in GREP
                            Obi-wan Kenobi Level 5
                            Try:
                            Find:  (\d+.+?)(~<×~<)((?1))(?=~S(in\.|cm))
                            Replace by:  $3$2$1
