It doesn't happen often but it's getting old. It seems to happen when I am applying any change to a layer. Maybe I am changing the layer effect or moving an object this happens. Anyone else have this issue? Today I did an Undo and this happened. Photoshop decided to screw up this layer and every copy of this layer in my entire document. It was just a gradient of color.
Mac Pro
macOS Sierra 10.12.5
3.5 GHz 6-Core Intel Xeon E5
32 GB of RAM
Photoshop CC 2017
2017.0.0 Release
Hi GES,
Could you please unchecking "Use Graphics Processor' From Photoshop's Preferences > Performance, then relaunch Photoshop and check if the issue still exists.
Regards,
Sahil
Thanks! I'll see if this does the trick and I'll try to remember to check back. Last time this happened was probably a month ago. By the way here is my graphics card specs.
AMD FirePro D500 3072 MB graphics
Also please update your Photoshop as your GPU is compatible with Photoshop, you can check this article for more info:
I checked for updates. Photoshop is up to date.
As you've mentioned that you're using Photoshop release CC 2017.0.0 the latest version is CC 2017.1.1. You can check the version of Photoshop by going to Help > About Photoshop CC. Please make sure that you are using the latest version.
If you are not able to see the update in the creative cloud application then, please sign out then sign into the creative cloud application.
