I work in a QA department and I have numerous signatures required per PDF. Sometimes up to 30. Saving after every signature gets quite time consuming. Saving after each signature was not always required and my coworkers do not have this issue. Perhaps I got a new update? Any advice on how to disable this would be greatly appreciated.
Thank You
Hi codyk10217005,
Sorry for the delay in response.
You have to save a file after you sign it, it is As Design behaviour and can't be avoided. You may also visit this discussion: User has to save document after electronically signing Feel free to update the discussion if you have further questions.
-Tariq Dar
Hi codyk10217005,
-Tariq Dar
Hi, I'm looking for a possibility to have an option where the file would automatically be saved with an extended file name (as it is for Redacted documents) which would at least decrease the number of clicks one has to make when signing multiple documents. Is it possible? Thank you!
No.
Did you ever find a workaround for this?
If you are signing "each page" as people sometimes do, DON'T. That's not how digital sugnatures are used, because a signature ALWAYS applies to the whole file.
There's no "workaround". When you digitally sign a file you must also save it.
