2 Replies Latest reply on Aug 11, 2017 7:17 AM by smacdonald2008
    How to test process with SoapUI?
    BjornEricsson Level 1
      In an effort to help my collueges I have begun creating example projects in SouapUI that consume our AEM Forms REST services. My problem that I am not able to solve on my own (or by googling) is: I am not able to configure the SoupUI request so that It can send a document to a process that takes List<Document> as input. The input variable only contains the encoded "file:<filename>" string in the byte-Array. Not the file itself:
      <?xml version="1.0"?>
      <list>
        <com.adobe.idp.Document serialization="custom">
          <com.adobe.idp.Document>
            <int>3</int>
            <boolean>true</boolean>
            <boolean>false</boolean>
            <null/>
            <string>127.0.0.1///////////10.47.0.140/////</string>
            <byte-array>ZmlsZTpUZXN0X0JTLnBkZg==</byte-array>
            <null/>
            <null/>
            <string/>
            <int>0</int>
            <string>text/plain</string>
            <null/>
            <map>
              <entry>
                <string>file</string>
                <null/>
              </entry>
              <entry>
                <string>wsfilename</string>
                <null/>
              </entry>
            </map>
            <string>adobe/idp/DocumentPullServant/adobejb_server1</string>
            <long>-1</long>
          </com.adobe.idp.Document>
      </list>
      I have no problem creating an HTML-page that sends this request:
      <FORM ACTION="http://nc1140.rsvc.se:8080/rest/services/Björn/Processes/Test" METHOD="post" ENCTYPE="multipart/form-data">
          <B>Test List<document> input</B>
          File: <INPUT TYPE="file" NAME="InputDocs" /><BR>
          <INPUT TYPE="submit" VALUE="Skicka" /><BR>
         </FORM>
      How should I edit this SoaupUI-project so that AEM forms will receive the file?
      You can find a zip with the process and the SoapUI Project here.
