1 Reply Latest reply on Jun 21, 2017 11:09 AM by surajpindoria
    Android build error
    tigergroup Level 1
      I'm getting Android build error and this hasn't be fixed since a few days ago.  Did something change for the Android build?  Below is the error message.
      FAILURE: Build failed with an exception.
      * What went wrong:
      Execution failed for task ':transformClassesWithDexForDebug'.
      > com.android.build.api.transform.TransformException: com.android.ide.common.process.ProcessException: java.util.concurrent.ExecutionException: com.android.dex.DexException: Multiple dex files define Lcom/google/android/gms/iid/zzc;
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      BUILD FAILED
      Total time: 6.556 secs
      Error: /project/gradlew: Command failed with exit code 1 Error output:
      Note: Some input files use or override a deprecated API.
      Note: Recompile with -Xlint:deprecation for details.
      Warning: AndroidManifest.xml already defines debuggable (in http://schemas.android.com/apk/res/android); using existing value in manifest.
      Note: Some input files use unchecked or unsafe operations.
      Note: Recompile with -Xlint:unchecked for details.
      * What went wrong:
