3 Replies Latest reply on Jun 21, 2017 6:53 PM by Chuck Uebele
    PS Script - Render Video into Image Sequence multiple times
    Jacksoneon Level 1
      Is there a way to render video in a script or batch so that the images will either save sequentially from the previous images saved, or into a new folder?
      I am trying to render a video into an image sequence, than transforming position, and then rendering it again, a total of 900 times, but the images are saving over themselves or not saving at all.
      I am able to render the video into an image sequence the first time, but when I try to run a script that will transform the image position, than render a second time, the image sequence does not render, or it renders over the previously rendered images.
      It would be okay to have a continuous sequence past jpg 900.. 901.. 902.. 903..
        • 1. Re: PS Script - Render Video into Image Sequence multiple times
          Chuck Uebele Adobe Community Professional & MVP
          I haven't checked if this is possible, but if you install the scriptListener plugin, then render a video, it should provide you with the code. Then you just need to exchange the file save info in that code with a variable that you can sequentially increase the file number.
          • 2. Re: PS Script - Render Video into Image Sequence multiple times
            Jacksoneon Level 1
            Thanks Chuck,
            That is a great idea. I downloaded script listener and gave it a shot. I got the code but unfortunately I don't know enough programming to manipulate the string. Do you? I'm guessing the line desc8.putString( idNm, """Line02.jpg""" );  would be the one to change.
            Also once it's finished is it fairly easy to re-implement it back into an action?
            Thanks!
            var idExpr = charIDToTypeID( "Expr" );
                var desc7 = new ActionDescriptor();
                var idUsng = charIDToTypeID( "Usng" );
                    var desc8 = new ActionDescriptor();
                    var iddirectory = stringIDToTypeID( "directory" );
                    desc8.putPath( iddirectory, new File( "/Users/jacksonnotier/Desktop/Dark Peony/JPG_Sequences/PS/Line_02" ) );
                    var idsubdirectory = stringIDToTypeID( "subdirectory" );
                    desc8.putString( idsubdirectory, """Line_02""" );
                    var idNm = charIDToTypeID( "Nm  " );
                    var idsequenceRenderSettings = stringIDToTypeID( "sequenceRenderSettings" );
                        var desc9 = new ActionDescriptor();
                        var idAs = charIDToTypeID( "As  " );
                            var desc10 = new ActionDescriptor();
                            var idEQlt = charIDToTypeID( "EQlt" );
                            desc10.putInteger( idEQlt, 5 );
                            var idMttC = charIDToTypeID( "MttC" );
                            var idNone = charIDToTypeID( "None" );
                            desc10.putEnumerated( idMttC, idMttC, idNone );
                        var idJPEG = charIDToTypeID( "JPEG" );
                        desc9.putObject( idAs, idJPEG, desc10 );
                    desc8.putObject( idsequenceRenderSettings, idsequenceRenderSettings, desc9 );
                    var idminDigits = stringIDToTypeID( "minDigits" );
                    desc8.putInteger( idminDigits, 7 );
                    var idstartNumber = stringIDToTypeID( "startNumber" );
                    desc8.putInteger( idstartNumber, 0 );
                    var iduseDocumentSize = stringIDToTypeID( "useDocumentSize" );
                    desc8.putBoolean( iduseDocumentSize, true );
                    var idallFrames = stringIDToTypeID( "allFrames" );
                    desc8.putBoolean( idallFrames, true );
                    var idrenderAlpha = stringIDToTypeID( "renderAlpha" );
                    var idalphaRendering = stringIDToTypeID( "alphaRendering" );
                    desc8.putEnumerated( idrenderAlpha, idalphaRendering, idNone );
                    var iduseDocumentFrameRate = stringIDToTypeID( "useDocumentFrameRate" );
                    desc8.putBoolean( iduseDocumentFrameRate, true );
                var idvideoExport = stringIDToTypeID( "videoExport" );
                desc7.putObject( idUsng, idvideoExport, desc8 );
            executeAction( idExpr, desc7, DialogModes.NO );
            • 3. Re: PS Script - Render Video into Image Sequence multiple times
              Yes, that's it. I think you want to get rid of all the quotes and replace it with a variable.
              Yes you can use it in an action. You just record the action and play the script.
