Help! With the most recent update of Lightroom, the print window doesn't actually have a "Print" button! I'm trying to make a pdf of a contact sheet. I even tried "Save as pdf…" in Print Settings, but it didn't save.
Also, Import doesn't show my main user to select photos to import! So I had to go through "Select Source" etc. etc.
Adobe…if it ain't broke, don't fix it!
The "Print" button disappears whenever you have "Print Job" set to export a JPG, rather than "To Printer". Could that be it?
(This option simply reflects the last remembered print settings; it is functionally no different than before AFAICT.)
Import should also reflect the last used Import settings, unless/until you change something or recall an import preset. It is possible to hide panels in the interface, though.
I am not completely clear what you mean by "my main user" - but the presentation of
...Copy link to clipboard
I am not completely clear what you mean by "my main user" - but the presentation of drives and virtual library locations etc is OS dependent; for example on Windows, "My Documents" exists nowhere on disk under that exact name; this is a more of a sort of a non-geographical figment. LR is really interested in actual, solid, explicit folder paths.
If you have a source location which you frequently want to import images from, it is convenient to record everything - selection of Move / Copy / Add, Source (and Destination options if applicable), and Renaming (if applicable) - into a named import preset. Then to recall that preset and customise settings from there if / as needed, each time.
Doing this takes away the need to interact with most of the Import settings, and helps with consistent repeatability too.
