2 Replies Latest reply on Jun 23, 2017 4:00 PM by Naoki-Hada
    [Q] CEP plugin response issue when Illustrator is in background. Any solution?
    Naoki-Hada Level 1
      This is refined question with minimized issue code from following.
      [Q] Illustrator seems forgeting what selected after 50 sec on Mac. How to avoid?
      It happens only on background about 1-2 times in 1 minutes.
      Regularly evalScript() takes 20-50 ms, but it got slow 2-5 sec.
      It's like stop breathing in sleep.
      While this stop breathing happening, bring Illustrator back on foreground and
      do massive number of evalScript() call made, it become almost does not responds at all.
      It's like a heart attack.
      When the heart attack happened, the cure is call $.gc() from ExtendScript Tool Kit.
      So following code has $.gc() included, but it seems not working from CEP code.
      It might be related with following
      Re: ID CC 2014 plus ExtendScript (Yosemite) slow to the point of not working...
      The solution may not work as current code is targeting end user environment.
      But if we can identified bottle neck process, we may be able to do something.
      So is there any way we can do to prevent above stop breathing issue?
      I think it could be minor issue, but it may lead to the heart attack issue.
      Screenshot:
      pollCounter = 319 is issue.
      every 1 sec polling.
      pollCounter = 201 and 212 has issue.
      Test code is from modified from following.
      CEP-Resources/CEP_7.x/Samples/CEP_HTML_Invisible_Extension-7.0 at master · Adobe-CEP/CEP-Resources · GitHub
      Modified part in index.html
      index.html
      var illustrator = null;
      var pollCounter = 0; // for throttling
      var pollVariable = null;
      var csi = new CSInterface();
      function AiSupport(enabled) {
          this.inPoll    = false; // waiting for poll() response
          this.isMac     = (navigator.platform == "MacIntel");
      window.onload = function() {
      var host = csi.getHostEnvironment();
          if (host.appId == "ILST") {
              loadJSX("AiActionsTest.jsx"); // min version
              illustrator = new AiSupport(false);
          pollVariable = setInterval(function() {
          poll();
           // }, 100); // 100ms
           }, 1000); // 1000ms
      window.onunload = function() {
      function loadJSX(fileName) {
          var csInterface = new CSInterface();
          var extensionRoot = csInterface.getSystemPath(SystemPath.EXTENSION) + "/jsx/";
          csInterface.evalScript('$.evalFile("' + extensionRoot + fileName + '")');
      function poll() {
          //console.log('poll()');
          pollCounter++;
          pollAi();
      function pollAi() {
          if (AiSupport.inPoll) {
              console.log('pollAi(): Skip to avoid duplicate request');
          } else {
              AiSupport.inPoll = true;
              console.log("pollAi(): getCurrentTool() request: pollCounter=", pollCounter);
              console.time("pollAi"); // performance measurement (NodeJs)
              csi.evalScript("aiGetSelectionType()", function (response) { // bypass for performance
                  console.timeEnd("pollAi"); // performance measurement (NodeJs)
               console.log('response = ' + response);
                  // other business logic
                  AiSupport.inPoll = false;
      function gcAi() {
          console.log('gcAi()');
          console.time("gcAi"); // performance measurement (NodeJs)
          csi.evalScript("$.gc()", function (response) {
              console.timeEnd("gcAi"); // performance measurement (NodeJs)
      AiActionsTest.jsx
      // return selection data type
      function aiGetSelectionType(){
          // $.writeln("aiGetSelectionType()"); // debug only
          $.hiresTimer; // reset
          $.gc(); // Garbage collector
          var result = "Unsupported";
          try{
              if(documents.length){
                  var _sel = activeDocument.selection; // TextRange when Text chars are selected // faster than app.selection
                  if("TextRange" == _sel.typename){ // Text char selected: OK: verifed working
                      var _target = _sel;
                      result = "TextRange";
                  }else if(0 != _sel.length){ // Array: Single and Multiple items case
                      // $.writeln("Number of selection = ", _sel.length); // debug only
                      for(var i=0; i<_sel.length; i++){
                          if(i == 0){
                              result = _sel[i].typename;
                          }else{
                              if(result != _sel[i].typename){
                                  //$.writeln("Got Mixed"); // debug only
                                  result = "Mixed";
                                  break;
                  }else{ // No selection
                      // $.writeln("No selection == > Global mode"); // debug only
                      result = "NoSelection";
              }else{
                  // no doc opened
          }catch(e){
              $.writeln("EXCEPTION: ", e);
              if(aiDebugAlertException) alert("EXCEPTION: " + e);
          $.writeln("aiGetSelectionType: result = ", result, " ", $.hiresTimer, " \xB5s"); // micro second
          return result;
      I'll appreciate any tips and suggestion.
      I made minimum code package to reproduce this issue.
      Please let me know for the test code package.
      Thank you,
      Naoki
        • 1. Re: [Q] CEP plugin response issue when Illustrator is in background. Any solution?
          Ten A Adobe Community Professional
          I don't have any solution about that. However, We can use another callback mechanism.
          Why don't you try to plugplugInterface like below?
          1. Remove your evalScripts 2nd argument(callback function).
          2. Add below event listener and new callback function.
          //Javascript (HTML)
          csi.addEventListener("getCallback", getReturnValue);
          function getReturnValue(response) { // bypass for performance
            console.log('response = ' + response.data);
          3. Replace last line(return result;) of your aiGetSelectionType function to below code.
          //Extendscript
          var xLib = new ExternalObject("lib:\PlugPlugExternalObject");
          } catch (e) {
            alert(e);
          var eventObj = new CSXSEvent();
          eventObj.type = "getCallback";
          eventObj.data = result; //result must be String
          if (app.activeDocument.selection.length>0){
            eventObj.data = app.activeDocument.selection[0].reflect.properties.length.toString();
          xLib.unload();
          eventObj.dispatch();
          You can reference below project.
          https://github.com/ten-A/CreativeSuiteSDK_Experimentals/tree/master/net.sytes.chuwa.callba cktest
          • 2. Re: [Q] CEP plugin response issue when Illustrator is in background. Any solution?
            Naoki-Hada Level 1
            Ten A
            Thank you very much for the tips and code.
            I've tested with the PlugPlugExternalObject event handler.
            Code itself worked fine.
            But the response slowness still happening.
            Another trying was disabling App Nap on Illustrator as commented previous post.
            > Following seems working from short term testing and did not show any slowness..
            >That is command to run in Terminal.
            >After done, Illustrator need to restart.
            >Turn off App Nap for Illustrator (not default setting)
            >defaults write com.adobe.illustrator NSAppSleepDisabled -bool true
            >Resume default: App Nap for Illustrator
            >defaults write com.adobe.illustrator NSAppSleepDisabled -bool false
            If there's other option other than above OS settings, it would be better.
            Thank you,
            Naoki
