3 Replies Latest reply on Jun 22, 2017 10:14 PM by Rick Gerard
    Using Redgiant trapcode tao
    omare98186230 Level 1
      So I purchased the trapcode suite and I started playing around with it (I have a fairly good experience with after effects) but whenever I try to play with the amplitude in the fractal displacement section, my object disappears. I can't find a solution or even a discussion about this anywhere and I don't understand if this is caused by my computer being too weak (MacBook pro 13 inch) or does it have something to do with the plugin.
      I know this is not a good place to ask this question but I'm truly desperate for any hints
        • 1. Re: Using Redgiant trapcode tao
          Paul Michelle Adobe Community Professional
          1)  Does it have something to do with your computer?   Well, does your computer meet the requirements for Trapcode Tao?
          2) Does it have something to with the plug-in?  impossible to say.  Tao's settings are interdependent meaning that the effect that "playing" with the amplitude setting depends on many other settings.
          You're asking if the problem is being caused by your computer or by the plug-in.
          Are sure the problem isn't you?
          What steps have you taken to to eliminate the possibility that the problem is being caused by you not knowing how to use Tao?
          • 2. Re: Using Redgiant trapcode tao
            Well according to their website my computer is suitable for it. And as I said I have a fairly good experience with after effects + I was following a tutorial exactly step by step it all works perfectly except for this part. Some people said they had the same issue in the comments section but I can't find it mentioned anywhere else.
            • 3. Re: Using Redgiant trapcode tao
              You are misreading the system requirements for TAO. A 13" MacBook Pro has integrated intel graphics and TAO and MIR will not work with that graphics card. You are just out of luck unless you purchase a computer with an appropriate GPU.
