6 Replies Latest reply on Jun 28, 2017 6:19 AM by Nipun Asthana
    How to select system font
    abdis99807366 Level 1
      It seems I can only select font from TypeKit but I would like to select a system font FS Elliot bold.
        • 1. Re: How to select system font
          are you creating an canvas/html5 project?
          is that font installed on your computer where you're creating that project?
          • 2. Re: How to select system font
            ClayUUID Adobe Community Professional
            The dropdown in the textfield properties labeled "Family:" should list every font installed on your system when you click it. What are you seeing?
            • 3. Re: How to select system font
              Colin Holgate MVP & Adobe Community Professional
              The web font globe menu should have Google Fonts as well as TypeKit. You can't give away fonts, so the web fonts are only the ones that you're licensed to use. If you choose from the regular font list, the ones in your system, it will look correct to you and correct to anyone who also has the same font.
              Using static text fields would solve the problem, then it can be any font you have installed. If the text has to be dynamic you would need to use a font from the web font list, or know for sure that the user has that font.
              • 4. Re: How to select system font
                Preran Adobe Employee
                Hi Abdis,
                Let us know if the answers provided managed to solve your issue. Feel free to mark the closest answer as correct.
                Preran
                • 5. Re: How to select system font
                  Hi all,
                  I think I confused myself and would like to re-word my question as follows:
                  How can I select a font name that exist on my system but will ultimately be hosted online. This is my current workflow.
                  I have FS Elliot font (with various weights) on my mac (see screenshot1)troubleshoot_animate_fonts1.jpg.
                  I am interested in the Bold.
                  Within Animate, it appears I have to select the font family and then the style.
                  The ultimate goal is to host the font online (through Google Doubleclick Studio assets folder) and use CSS font family like this in my template code:
                  When I publish the Animate project, I keep having to do this
                  Am looking for a way to avoid step 4 so designers/animator don't have to go into code and make this required change.
                  • 6. Re: How to select system font
                    Nipun Asthana Adobe Employee
                    Hi Abdi,
                    You can use the following code in frame-script to avoid changing the text in the external file.
                         this.cta_text.font = "13px 'FS Elliot Bold'";
                    in general: this.<text instance name>.font = "<text size> <font-family name as in css>";
                    2 people found this helpful
