8 Replies Latest reply on Jun 24, 2017 2:27 PM by ali m.r7155227
    Wiggle Stroke Width Issue
    ali m.r7155227 Level 1
      Hi, since I'm still learning After Effects, I'm not sure how to make this Effect work. I just want it to start at a key-frame from 0 (or not visible) and end with a key-frame with 0 again after passing over the letters. The attached screen shot shows my set-up. Thank you!
        • 1. Re: Wiggle Stroke Width Issue
          That's not how it works. It does exactly what it says - it wiggles the stroke width based on the input phase. If you really want to control the fade, you have to add another traditional animator for opacity or stroke width and keyframe that instead.
          Mylenium
          • 2. Re: Wiggle Stroke Width Issue
            Mike_Abbott Level 4
            I'm not 100% certain of what you're aiming for, but...
            Create your text.
            Apply a stroke in the character panel - but set the stroke width to zero.
            Twirl down the text layer to see the  'Animate' menu.
            Animate > Stroke width
            Stroke width = your choice of value
            Twirl down Range Selector 1
            Animate Offset from -100 to 100% over time.
            • 3. Re: Wiggle Stroke Width Issue
              Thanks Mike! This works but it's not as smooth as "Wiggly Stroke Width" effect. If you apply that effect to a text, the way the stroke moves over the text is very smooth, wave like. The method you told me does what I want (from 0 to 100) but because it's not the "Wiggly" effect, the stroke passes over each letter like a typewriter effect.
              • 4. Re: Wiggle Stroke Width Issue
                I actually made what I wanted it by just playing with the key-frames until it passed over the letters. Video attached
                • 5. Re: Wiggle Stroke Width Issue
                  Thanks! I just played with the settings until I got close to what I liked.
                  • 6. Re: Wiggle Stroke Width Issue
                    Mike_Abbott Level 4
                    Ok - I now understand what you want - very simple to change. Here are the instructions in full again with a minor modification - in case you want to mark this answer:
                    Create your text.
                    Twirl down Range Selector 1:
                              Advanced > Set the Shape to Smooth
                    If you want a smaller section of the text to have the stroke highlight, reduce the Range selector End parameter value, and the animate offset from the negative of the end value to 100. For example: if you want to highlight 25% of the text at any one time, set:
                    End = 25%
                    Animate offset from -25% to +100%
                    • 7. Re: Wiggle Stroke Width Issue
                      Thanks again but when I apply the stroke I don't see the options to change the width to zero. I use to see this option in the character panel but now it's gone and I don't know how to get it back.
                      • 8. Re: Wiggle Stroke Width Issue
                        Thanks Mike! This is exactly the effects I was trying to apply. Thank you!
                        BTW, the stroke width option was hidden in the character panel, I just had to drag the edge of the panel to see it.
