1 Reply Latest reply on Jun 23, 2017 9:13 AM by frameexpert
    Custom shading using ExtendScript based on element attribute
    Peggy Cove
      I am rather new to ExtendScript, and working on a structured DITA FM document. In our tables, we use a background colour to highlight a specific type of information. Of course, this shading is contained only in the FM data, and is lost on roundtripping. For the <entry> elements of the cells that we want to be shaded, we have set the @outputclass=bgcolor.
      Now, I am trying to use ExtendScript to locate the elements with the appropriate attribute, and then apply the custom shading. I can't figure out how to get the shading applied once I find the element. I am sure I am missing something really basic, but am completely stuck.
      This is what I have so far...
      // Remove existing shading modifications from cells…
      var tbl = app.ActiveDoc.FirstTblInDoc
      while (tbl.ObjectValid() ) {
        var row, cell
        row = tbl.FirstRowInTbl
        while (row.ObjectValid() ) {
        cell = row.FirstCellInRow
        while (cell.ObjectValid() ) {
        //changing the cell definition so that color properties are taken from table format }
        cell.CellUseOverrideFill = false
        cell.CellUseOverrideShading = false
        cell = cell.NextCellInRow
        row = row.NextRowInTbl
        tbl = tbl.NextTblInDoc
      // Get the document’s root element…
      var elem = app.ActiveDoc.MainFlowInDoc.HighestLevelElement;
      // Launch a function that walks the tree and shades the cell when appropriate…
      walkTree(0, elem);
      app.ActiveDoc.Redisplay ();
      // A recursive function that walks the tree…
      function walkTree(level, elem){
          // Find elements where @outputclass has a value
           var allAtts = elem.Attributes;
           var AttVal = "";
           var i = 0;
           var attFound = false;
           while( !attFound && i < allAtts.length ) {
                if( allAtts[i].name == "outputclass" ) {
                     attFound = true;
                     if( allAtts[i].values.length > 0 ) {
                          AttVal = allAtts[i].values[0];
                i++;
          // For @outputclass=bgcolor, shade the cell
          if AttVal == "bgcolor") {   // THESE ARE THE FOUR LINES THAT DON'T WORK
              this.cell.CellOverrideShading == app.ActiveDoc.GetNamedColor("Background");
              this.cell.CellUseOverrideShading = true;
              this.cell.CellOverrideFill = 100;
              this.cell.CellUseOverrideFill = true;
        level = level++;
        var child = elem.FirstChildElement;
        while (child.ObjectValid()) {
        walkTree(level, child);
        child = child.NextSiblingElement;
      The script removes existing shading properly, but does not apply the new one.  Does anyone have any suggestions?
      ...C
        • 1. Re: Custom shading using ExtendScript based on element attribute
          frameexpert Level 4
          What does "this" refer to in the above code?
          Instead of "this", try referring to the cells like this:
          cell = elem.Object;
          cell.CellOverrideShading = app.ActiveDoc.GetNamedColor("Background");
          Also, the double equal sign is not correct on your first line.
