What exactly does doc.TextSelection contain? How can I print its contents? and can anyone provide an example script using which one can essentially perform the equivalent of "selecting" the entire contents of a paragraph to perform some operations on it?
Hi varuns44789478,
A TextSelection property uses a TextRange structure, which is an array of two text locations (TextLoc). A TextLoc itself is an array of a paragraph object and an offset. It is a little tricky to understand, but it starts to make sense if you think about it for a while. The TextLoc is like an insertion point in the document, so it can be identified by the parent paragraph and the character offset from the beginning of the paragraph. A selection in a document is effectively a ran
...Copy link to clipboard
Hi varuns44789478,
A TextSelection property uses a TextRange structure, which is an array of two text locations (TextLoc). A TextLoc itself is an array of a paragraph object and an offset. It is a little tricky to understand, but it starts to make sense if you think about it for a while. The TextLoc is like an insertion point in the document, so it can be identified by the parent paragraph and the character offset from the beginning of the paragraph. A selection in a document is effectively a range between two text locations, hence the TextRange structure.
Here is basic code that would select an entire paragraph, assuming you already had the paragraph object:
var tr = new TextRange();
tr.beg.obj = tr.end.obj = pgf;
tr.beg.offset = 0;
tr.end.offset = Constants.FV_OBJ_END_OFFSET;
doc.TextSelection = tr;
As far as "printing" a text range, there is no direct way. You have to be creative. Below is a script that I use to print various things related to the current selection in a document or book. Just select something and run it. I hope this helps some.
Russ
function cm_ReportIds(doMsgBox, doConsole)
var msg = "";
var doingBook = false;
var file = app.ActiveDoc;
if(!file.ObjectValid())
file = app.ActiveBook;
doingBook = true;
alert ("No active document or book.");
return;
msg += "----------------------------------------\n";
if(doingBook)
msg += "ACTIVE BOOK: ";
else
msg += "ACTIVE DOCUMENT: \n\n"
msg += file.Name + "\n(ID: " + file.id + ")\n";
msg += "----------------------------------------\n\n";
msg += "CURRENT ELEMENT SELECTION (er = file.ElementSelection):\n\n";
var er = file.ElementSelection;
if(!er.beg.parent.ObjectValid() &&
!er.beg.child.ObjectValid() &&
!er.end.parent.ObjectValid() &&
!er.end.child.ObjectValid())
msg += "(No valid element selection)\n";
else
msg += "er.beg.parent (element): ";
if(er.beg.parent.ObjectValid())
msg += "<" + er.beg.parent.ElementDef.Name + "> (ID: " + er.beg.parent.id + ")\n";
else msg += "-NONE-\n";
msg += "er.beg.child (element): ";
if(er.beg.child.ObjectValid())
msg += "<" + er.beg.child.ElementDef.Name + "> (ID: " + er.beg.child.id + ")\n";
msg += "er.beg.offset: " + er.beg.offset + "\n\n";
msg += "er.end.parent (element): " ;
if(er.end.parent.ObjectValid())
msg += "<" + er.end.parent.ElementDef.Name + "> (ID: " + er.end.parent.id + ")\n";
msg += "er.end.child (element): ";
if(er.end.child.ObjectValid())
msg += "<" + er.end.child.ElementDef.Name + "> (ID: " + er.end.child.id + ")\n";
msg += "er.end.offset: " + er.end.offset + "\n";
if(!doingBook)
msg += "CURRENT TEXT SELECTION (tr = file.TextSelection):\n\n";
var tr = file.TextSelection;
if(tr.beg.obj.ObjectValid())
msg += "tr.beg.obj (pgf ID): " + tr.beg.obj.id + "\n";
msg += "tr.beg.obj (pgf format): " + tr.beg.obj.Name + "\n";
msg += "tr.beg.offset: " + tr.beg.offset + "\n\n";
msg += "tr.end.obj (pgf ID): " + tr.end.obj.id + "\n";
msg += "tr.end.obj (pgf format): " + tr.end.obj.Name + "\n";
msg += "tr.end.offset: " + tr.end.offset + "\n";
else msg += "(No valid text selection)\n";
msg += "CURRENT GRAPHIC SELECTION:\n\n";
var graphic = file.FirstSelectedGraphicInDoc;
var path = "";
if(graphic.ObjectValid())
msg += "Selected graphic object: ";
if(graphic.constructor.name == "AFrame")
msg += "Anchored frame (ID: " + graphic.id + ")\n";
var elem = graphic.Element;
if(elem.ObjectValid())
msg += "Anchored frame element: <" +
elem.ElementDef.Name + "> (ID: " + elem.id + ")\n";
msg += "First graphic object in the frame: ";
graphic = graphic.FirstGraphicInFrame;
msg += graphic.constructor.name + " (ID: " + graphic.id + ")\n";
if(graphic.constructor.name == "Inset")
path = graphic.InsetFile;
else msg += "(none detected)";
else
msg += "Parent anchored frame: ";
graphic = graphic.FrameParent;
if(graphic.ObjectValid() && graphic.constructor.name == "AFrame")
msg += " ID: " + graphic.id + "\n";
if(path != "")
msg += "\nReferenced graphic filepath:\n" + path + "\n";
else msg += "(No valid graphic selection)\n";
if(doMsgBox)
alert(msg);
if(doConsole)
while(msg.length > 0)
Err(msg.substring(0, 255));
msg = msg.substring(255, msg.length);
Hi Russ,
This helps a lot.
Varun
I am not sure exactly what you mean by printing the TextSelection, but here is a function that will retrieve the text so you can do something with it:
var doc = app.ActiveDoc;
// Display the selected text in an alert dialog box.
alert (getText (doc.TextSelection, doc));
function getText (textObj, doc) {
// Gets the text from the text object.
var text = "", textItems, i;
// Get a list of the strings in the text object or text range.
if (textObj.constructor.name !== "TextRange") {
textItems = textObj.GetText(Constants.FTI_String);
} else {
textItems = doc.GetTextForRange(textObj, Constants.FTI_String);
// Concatenate the strings.
for (i = 0; i < textItems.len; i += 1) {
text += (textItems.sdata);
return text; // Return the text
By printing the contents I mean being able to print the values of the TextSelection object attributes
