3 Replies Latest reply on Jul 3, 2017 6:47 AM by jesúsg
    problema en la importacion.
      Hola, buenas tardes, llevo dos dias que cuando voy a importar raws en color, al importarlos me los convierte directamente en blanco y negro y no se que hacer.
      Podria alguien ayudarme?
        • 1. Re: problema en la importacion.
          johnrellis Most Valuable Participant
          Google translation: Hi, good afternoon, I've been working with raws for two days, when I import them, it turns them directly into black and white and I do not know what to do.
          Could anyone help me?
          1. In the Import window, in the Apply During Import panel on the right, make sure Develop Settings is set to None:
          2. If that doesn't help, then select one of the photos and go to Develop. Give the menu command Develop > Set Default Settings
          and click Restore Adobe Default Settings:
          • 2. Re: problema en la importacion.
            WobertC Adobe Community Professional
            It is possible you have a Preset defined in the Import dialog-
            The "Develop Settings" are better to show  [None]
            Can you Reset the photos by selecting them and clicking [Reset All] in the Quick Develop panel?
            • 3. Re: problema en la importacion.
              jesúsg Level 1
              Problema Solucionado, Muchísimas gracias por su atención.
