17 Replies Latest reply on Jun 28, 2017 6:50 AM by Liphou
    Titling the entries of array of array
    Saeedfs Level 1
      Hi all'
      while studying the the array of array I DEFINE a as follow
      a=[
          [ A=[134, 500] , B=[134,457] , C=[134,420]],
          [ A=[150, 400] , B=[186,400] , C=[220,400]],
          [ A=[230, 420] , B=[230,436] , C=[230,457]],
      why the statement
      a[0].B;
      give undefined
      i expect to give me :
      134,457
      i get this idea from a response done by Peter Kahrel
      which learned lots from him
        • 1. Re: Titling the entries of array of array
          Trevorׅ Adobe Community Professional
          Hi
          Your A, B and C values are working as follows
          A=[134, 500];
          B=[134,457];
          C=[134,420];
          A=[150, 400];
          B=[186,400];
          C=[220,400];
          A=[230, 420];
          B=[230,436];
          C=[230,457];
          Therefore if you A ends up as [230, 420] which is the last value it was assigned.
          a[0] has the value of [[134, 500], [134,457], [134,420]]
          The structure that you are looking for is.
          a = [{
              A: [134, 500],
              B: [134, 457],
              C: [134, 420]
              A: [150, 400],
              B: [186, 400],
              C: [220, 400]
              A: [230, 420],
              B: [230, 436],
              C: [230, 457]
          An alternative but usually not recommended could be
          a = [[], [], [] ];
          a[0]['A'] = [134, 500];
          a[0]['B'] = [134, 457];
          a[0]['C'] = [134, 420];
          a[1]['A'] = [150, 400];
          a[1]['B'] = [186, 400];
          a[1]['C'] = [220, 400];
          a[2]['A'] = [230, 420];
          a[2]['B'] = [230, 436];
          a[2]['C'] = [230, 457];
          Or slightly better
          a = [[], [], [] ];
          a[0].A = [134, 500];
          a[0].B = [134, 457];
          a[0].C = [134, 420];
          a[1].A = [150, 400];
          a[1].B = [186, 400];
          a[1].C = [220, 400];
          a[2].A = [230, 420];
          a[2].B = [230, 436];
          a[2].C = [230, 457];
          HTH
          Trevor
          • 2. Re: Titling the entries of array of array
            Hi Saeed,
            think again.
            What you are doing is to assign values to variables a, A, B and C.
            You do the same statement three times with A, B and C.
            But you are using different values overwriting the one you are doing before.
            The last statement counts.
            So a[0] will result in: [ [230, 420] , [230,436] , [230,457] ]
            So a[1] in: [ [230, 420] , [230,436] , [230,457] ]
            So a[2] in: [ [230, 420] , [230,436] , [230,457] ]
            B is [230,436] ,
            thus a[0][1] is: [230,436]
            If you want to use array a like that:
            a[0].B
            a[1].B
            a[2].B
            where you expect different values for every statement you could use associative arrays or objects stored in array a.
            Or more simply put work directly with objects like that:
            var a =
                { A:[134, 500] , B:[134,457] , C:[134,420] },
                { A:[150, 400], B:[186,400] , C : [220,400] },
                { A:[230, 420] , B:[230,436] , C:[230,457] }
            a[0].B // results in: [134,457]
            a[0]["B"] // results in: [134,457]
            If you want longer variable names for A, B and C where white space or other characters are involved that are not allowed in variable names, you have to use a string and cannot use the dot notation:
            var a =
                { "My wonderful A":[134, 500] , "My fantastic B":[134,457] , "My extraordinary C":[134,420] },
                { "My wonderful A":[150, 400], "My fantastic B":[186,400] , "My extraordinary C" : [220,400] },
                { "My wonderful A":[230, 420] , "My fantastic B":[230,436] , "My extraordinary C":[230,457] }
            a[0]["My fantastic B"] // results in: [134,457];
            a[0]."My fantastic B" // Syntax error
            Initially I prepared a longer reply, but now that Trevor answered I leave it at that.
            Regards,
            Uwe
            • 3. Re: Titling the entries of array of array
              Hi Trevor,
              why do you think, that an expression like that:
              var a = [ [], [], [] ];
              or perhaps like that ( which is the same ):
              var a = [ {}, {}, {} ];
              is not recommended?
              Regards,
              Uwe
              • 4. Re: Titling the entries of array of array
                Hi Uwe
                For performance it seems that using an associative array could in fact be way faster than using objects.
                See https://jsperf.com/performance-of-array-vs-object/248
                I did not do test myself.
                I was referring to setting up a small array which I think is more convenient to setup in one deceleration than using multiple assignments.
                Also in the jsx context one can use a.toSource()  with the object method but not with the associative array method.
                I shall try look later into the performance issues myself later.
                I could very well be wrong with my recommendation and I think you are correct to question it.
                Regards
                Trevor
                • 5. Re: Titling the entries of array of array
                  Saeedfs Level 1
                  Hi Trevor and Laubender,
                  Thank you both for your quick responses.
                  both answers is exactly what I was looking for.
                  Thank you very much again, Trevor and Laubender.
                  Regards,
                  Saeed
                  • 6. Re: Titling the entries of array of array
                    Peter's example is technically wrong How very rare. (OTOH it was only to highlight the particular order of pathpoint points and not framed as "actual code".)
                    • 7. Re: Titling the entries of array of array
                      Saeedfs Level 1
                      Peter's example  give a hint to answer the question "How to declare array of array" which has no solution if you in this forum.
                      Moreover when i tried to build Pascal's triangle it is straight  forward
                      n=10
                      a=pascalNumbers(n)
                      for (i=0;i<a[n].length;i++)
                           alert(a[n][i])
                      function pascalNumbers(n){
                          var pascal=[];
                          var row0=[1];
                          var row1=[1,1];
                                pascal.push(row0);
                                pascal.push(row1);
                          for (i=2;i<n+1;i++){
                              newRow=[];
                              newRow.push(1);
                              for (k=1;k<i;k++)
                                 newRow.push(pascal[i-1][k-1]+pascal[i-1][k]);
                              newRow.push(1);
                              pascal.push(newRow);
                          return pascal[n]
                      • 8. Re: Titling the entries of array of array
                        I would put it just put it
                        It was only to highlight the particular order of pathpoint points and not framed as "actual code".
                        • 9. Re: Titling the entries of array of array
                          Hi Saeed,
                          here a sample appliction for your pascal number generator:
                          var n=10;
                          var a=pascalNumbers(n);
                          var doc = app.documents.add
                                  documentPreferences :
                                      pageOrientation : PageOrientation.LANDSCAPE ,
                                      facingPages : false ,
                                      pageWidth : "297mm" ,
                                      pageHeight : "210mm"
                          var textFrame = doc.pages[0].textFrames.add
                                  geometricBounds : [ "20mm" , "20mm" , "190mm" , "277mm" ] ,
                                  appliedObjectStyle : "None" ,
                                  contents : a.join("\r")+"\r"
                          var story = textFrame.parentStory;
                          story.texts[0].justification = Justification.CENTER_ALIGN ;
                          // Convert contents to tables:
                          story.texts[0].paragraphs.everyItem().texts.everyItem().convertToTable( "," , "\r" );
                          // Removing empty rows:
                          story.tables.everyItem().rows[-1].remove();
                          // Uniform width of every cell in every table of the story:
                          story.tables.everyItem().cells.everyItem().width = textFrame.parentStory.tables[-1].cells[0].width;
                              var pascal = [];
                              var row0 = [ 1 ];
                              var row1 = [ 1,1 ];
                              var i , newRow , k , ;
                              pascal.push(row0);
                              pascal.push(row1);
                              for ( i=2; i<n+1; i++)
                                  newRow=[];
                                  newRow.push(1);
                                  for (k=1;k<i;k++)
                                  newRow.push(1);
                                  pascal.push( newRow );
                              return pascal
                              1
                              1,1
                              1,2,1
                              1,3,3,1
                              1,4,6,4,1
                              1,5,10,10,5,1
                              1,6,15,20,15,6,1
                              1,7,21,35,35,21,7,1
                              1,8,28,56,70,56,28,8,1
                              1,9,36,84,126,126,84,36,9,1
                              1,10,45,120,210,252,210,120,45,10,1
                          Uwe
                          • 10. Re: Titling the entries of array of array
                            Saeedfs Level 1
                            Hi Laubender,
                            i run your code but line 14 not working
                            i tried to write lines 14-21 on one single line but still not working,
                            what is the problem with my InDesign
                            • 11. Re: Titling the entries of array of array
                              Did you copy all lines of my code?
                              In my code line 14 is doing something else.
                              It's a closing curly brace.
                              Maybe you missed it, but function pascalNumbers() now returns the whole array.
                              And the result—array a—is needed to feed contents of the text frame.
                              So you have to do the two lines:
                              var n=10; and var a=pascalNumbers(n);
                              before everything else.
                              Regards,
                              Uwe
                              • 12. Re: Titling the entries of array of array
                                Saeedfs Level 1
                                i am very sorry YOU ARE correct,
                                • 13. Re: Titling the entries of array of array
                                  Saeedfs Level 1
                                  Hi Laubender,
                                    your code writing is very neat so it is readable.
                                  actually i would like to insert the pascal numbers in hexagon .
                                  your replay Gide me to begin from zero.
                                  onotherhand BEFORE your replay i start firs thing manually then i call other script.
                                  this my work till now
                                  addDocumentWithPrimaryTextFrames();
                                   addFirstPolygon();
                                   numberOfObjects=numberOfObjectAtTheBase();
                                  var objectsArray=[]
                                  objectsArray.push(app.selection[0]);
                                  addObjectHorizentaly(numberOfObjects-11)
                                  for(i=numberOfObjects-12;i>0;i--)
                                          addObjectVirticaly();
                                          addObjectHorizentaly(i);
                                  pascalNumbers();
                                  function numberOfObjectAtTheBase(){
                                       object=app.selection[0];
                                       a=object.paths[0].pathPoints[0].anchor ;
                                       b=object.paths[0].pathPoints[4].anchor ;
                                       c=moveArray(a,b);
                                       myDocument=app.activeDocument;
                                       myBounds = myDocument.pages[0].bounds;
                                       numberOfObjects=Math.floor((myBounds[2]-myBounds[0])/c[0]);
                                       return numberOfObjects;
                                  function addObjectVirticaly(){
                                          a=object.paths[0].pathPoints[2].anchor ;
                                          c=moveArray(a,b);
                                          newobject=object.duplicate(undefined, c);
                                          objectsArray.push(newobject);
                                          newobject.select();
                                  function addObjectHorizentaly(numberOfObjects){
                                           firstObjectInTheRow=app.selection[0];
                                          for (i=1;i<numberOfObjects;i++){
                                                  c=moveArray(a,b);
                                                  newobject.select();
                                      firstObjectInTheRow.select();
                                  function moveArray(a,b){
                                     x1= a[0]
                                     x2= b[0]
                                     y1=a[1]
                                     y2= b[1]
                                     x=x2-x1
                                     y=y2-y1
                                     return [x,y]
                                  function objectIndex(){
                                          myPage=myDocument.pages[0];
                                          myPageItems=myPage.allPageItems;
                                          myPageItems[-1].select();
                                          for (i=objectsArray.length-1;i>-1;i--){
                                                objectsArray[i].select();
                                               // insertPascalNumber(i);
                                               // alert("pageItems"+i+"selected");
                                                //objectsArray[i].contents=i
                                  function pascalNumbers(){
                                      m=objectsArray.length;
                                      N=numberOfRowsInPascalTriangle(m);
                                      // fill the top cell
                                      crruntcells=objectsArray.length-1;
                                      objectsArray[crruntcells].select();
                                      insertPascalNumber(1);
                                      // fill the secon row
                                      crruntcells-=1;
                                       crruntcells-=1;
                                       // fill the rest of rows
                                      lastRow=[1,1];
                                      crruntRow=[];
                                      for (i=3;i<N+1;i++){
                                      // fill the first cell in the row i
                                                   crruntcells-=1;
                                                     crruntRow.push(1);
                                     // fill the rest except the last
                                              for (j=1;j<i-1;j++)
                                                     pascal=lastRow[j-1]+lastRow[j]
                                                     crruntRow.push(pascal);
                                                     crruntcells-=1;
                                                     insertPascalNumber(pascal);
                                     // fill in the last
                                                  crruntcells-=1;
                                                     crruntRow.push(1);
                                       // reinitialize the rows
                                                    lastRow.splice(0)
                                                  for (k=0;k<crruntRow.length;k++)
                                                  lastRow.push(crruntRow[k]);
                                                  crruntRow.splice(0);
                                  function numberOfRowsInPascalTriangle(N)
                                          i=1;
                                          count = 0;
                                          while( N>0)
                                              count+=1;
                                              N-=i;
                                              i+=1;
                                          return count;
                                  function insertPascalNumber(n){
                                          myPolygon=app.selection[0];
                                          myPolygonTextFrame=myPolygon.textFrames.add();
                                          myPolygonTextFrame.visibleBounds=myPolygon.visibleBounds;
                                          myPolygonTextFrame.textFramePreferences.verticalJustification = VerticalJustification.CENTER_ALIGN;
                                          myPolygonTextFrame.contents=(n).toFixed();
                                          myPolygon.textFrames[0].paragraphs[0].
                                          applyParagraphStyle(app.activeDocument.paragraphStyles.item("Number",true));
                                  function addDocumentWithPrimaryTextFrames(){
                                  //Store value:
                                  var storedPreset = app.documentPresets[0].createPrimaryTextFrame;
                                  //Let's set it to true:
                                  app.documentPresets[0].createPrimaryTextFrame = true;
                                  //Add the document, name the master as you wish etc.pp. :
                                  app.documents.add
                                          documentPrefreneces :
                                                  facingPages : false
                                                  pageWidth : "210 mm"
                                                  pageHeight : "297 mm"
                                  //Reset to stored value:
                                  app.documentPresets[0].createPrimaryTextFrame = storedPreset;
                                  function addFirstPolygon(){
                                          //Given a page "myPage", create a new polygon at the bottom left corner
                                          //the size is 10.5mm W × 21mm H...
                                          myPage=app.activeDocument.pages[0]
                                          var myPolygon = myPage.polygons.add();
                                          //Rotate a polygon "myPolygon" around its center point.
                                          var myRotateMatrix =
                                                  app.transformationMatrices.add({counterclockwiseRotationAngle:90});
                                                  myPolygon.transform(CoordinateSpaces.pasteboardCoordinates,
                                                  AnchorPoint.centerAnchor, myRotateMatrix);
                                          myPolygon.geometricBounds=[263,12.7,284,23.2]
                                          myPolygon.select();
                                  I have issues on this
                                  first the function on line 24 does not calculate polygon exactly so i do tolerance that number.
                                  • 14. Re: Titling the entries of array of array
                                    Saeedfs Level 1
                                    Hi Laubender,
                                    many thanks to you and all people in this forum who give help.
                                    you gave me an idea of application i am looking for.This application working well except for the prime number.
                                    Here is the application
                                    //add document
                                    // calculate the number of polygon at the bottom of the page
                                    //  objectsArray is to contain polygon from bottom in order up
                                        var objectsArray=[];
                                    //add the polygon starting from the bottom
                                        addObjectHorizentaly(numberOfObjects-18)
                                        for(i=numberOfObjects-19;i>0;i--)
                                    //insert the pascal in the polygons
                                        pascalNumbers();
                                    // color the polygon one some criteria such as color odd numbers , even numbers , prime number....
                                        colorPascal();
                                         c=moveArray(a,b);
                                            c=moveArray(a,b);
                                            newobject.select();
                                                    c=moveArray(a,b);
                                                    newobject.select();
                                       x1= a[0]
                                       x2= b[0]
                                       y1=a[1]
                                       y2= b[1]
                                       x=x2-x1
                                       y=y2-y1
                                       return [x,y]
                                         crruntcells-=1;
                                         crruntcells-=1;
                                         lastRow=[1,1];
                                         crruntRow=[];
                                         crruntcells-=1;
                                         crruntRow.push(1);
                                         for (j=1;j<i-1;j++)
                                                       crruntcells-=1;
                                    // fill in the last
                                         crruntcells-=1;
                                          crruntRow.push(1);
                                         lastRow.splice(0)
                                    function numberOfRowsInPascalTriangle(N){
                                         i=1;
                                         count = 0;
                                         while( N>0)
                                                count+=1;
                                                N-=i;
                                                i+=1;
                                         return count;
                                    //Store value:
                                         app.documents.add
                                                            facingPages : false,
                                                            pageWidth : "210 mm",
                                         addFirstPolygon();
                                            //or the size is 6mm W × 12mm H..
                                            //myPolygon.geometricBounds=[263,12.7,275,18.7]
                                            myPolygon.geometricBounds=[ 272.25,12.7,284.25,18.7]
                                            myPolygon.select();
                                    function colorPascal(){
                                            myPolygons=myPage.polygons;
                                            for ( i=0;i<myPolygons.length;i++)
                                                   if (isEven(Number(myPolygons[i].textFrames[0].contents)))
                                                   //if (is3multiple(Number(myPolygons[i].textFrames[0].contents)))
                                                   //if (is5multiple(Number(myPolygons[i].textFrames[0].contents)))
                                                   //if (is7multiple(Number(myPolygons[i].textFrames[0].contents)))
                                                   //if (isPrime(Number(myPolygons[i].textFrames[0].contents)))
                                                        myPolygons[i].textFrames[0].fillColor="C=15 M=100 Y=100 K=0";
                                    function isEven(anyInteger){
                                        if(Math.floor(anyInteger/2)*2==anyInteger)
                                          return true;
                                        else
                                          return false;
                                    function is3multiple(anyInteger){
                                        if(Math.floor(anyInteger/3)*3==anyInteger)
                                          return true;
                                        else
                                          return false;
                                    function is5multiple(anyInteger){
                                        if(Math.floor(anyInteger/5)*5==anyInteger)
                                          return true;
                                        else
                                          return false;
                                    function is7multiple(anyInteger){
                                        if(Math.floor(anyInteger/7)*7==anyInteger)
                                          return true;
                                        else
                                          return false;
                                    function isPrime(anyInteger){
                                        if (anyInteger==1)
                                               return false;
                                        if(anyInteger==2||anyInteger==3)
                                               return true;
                                         else
                                               for (i=2;i<=Math.floor(anyInteger/2);i++)
                                                   if(Math.floor(anyInteger/i)*i==anyInteger)
                                                      return false;
                                                   else
                                                      isPrime=true;
                                          return isPrime;
                                    it produce the flowing
                                    • 15. Re: Titling the entries of array of array
                                      Liphou Level 2
                                      hi Saeedfs, (post 9 de Laubender)
                                      pour moi il y juste une petit erreur là (ligne 45) :
                                       var i , newRow , k, ;
                                      correction :
                                       var i , newRow , k;
                                      A+
                                      • 16. Re: Titling the entries of array of array
                                        That's my error…
                                        Regards,
                                        Uwe
                                        • 17. Re: Titling the entries of array of array
                                          Liphou Level 2
                                          Yes, il est compliqué de faire suivre les postes .... (un détail).
                                          Merci  à vous tous, lire tous ces postes apporte beaucoup à ma compréhension des script.
                                          Regards
                                          Philippe
