Hi all. I am new to illustrator. I've searched the web and these forums and tried a number of different techniques, but have not had success. see reference image:
I want the ellipse / stroke to trim or hide in the portion behind the grey, so that when I hide the grey text layers the circle has a padding from intersecting with the original white text. *note the text and offset path have an effect of "arc lower" and are in their own group.
How I arrived here:
1) Ellipse tool with stroke and zero fill
2) text tool
3) effects > warp > arc lower
4) create outlines from type
5) offset path
I appreciate any assistance!
Thank you
What you can do: apply an opacity of 0% to only the grey fill.
Then group everything and in the transparency panel make a knockout group.
You have to expand the appearance and cut things up using Pathfinder operations.
Mylenium
expand the ellipse? cut the ellipse with which pathfinder operations?
I tried moving the stroked ellipse to the group featuring the greyed outline text, it applied the same effect warp>arc lower to the circle. Not good.
If I left the stoked ellipse out of the greyed outline group and tried to group - it gave me the error "can't make a group of objects" that are within different groups.
What am I missing?
You just need to group everything but the background..
that's what I needed. Thank you!
