4 Replies Latest reply on Jul 1, 2017 2:47 PM by wespor
    Shuffle Words
    wespor
      Hi, I need to shuffle words in paragraphs. I found the script below but it shuffles paragraphs themselves, I'm not quite savvy enough to modify it myself just yet. Any pointers?
      I use InDesign to efficiently plan social media posts for many accounts and repeating hashtags can get you shadowbanned. I have a list of 100~ relevant tags I'd like to randomize and copy/paste selections from.
      var mRAND = Math.random,
          LOCS = [LocationOptions.AFTER, LocationOptions.BEFORE];
      function shuffleSelectedParagraphs()
          var s = app.selection && app.selection[0],
              ps = s && s.hasOwnProperty('paragraphs') && s.paragraphs,
              n = ps && ps.length,
              i = n, j, k, d;
          if( n < 2 ) throw Error("Please select at least two paragraphs.");
          var sto = ps[0].parentStory,
              ip0 = ps[0].insertionPoints.firstItem().index,
              ip1 = ps[n-1].insertionPoints.lastItem().index,
              EOF = ps[n-1].characters.lastItem().contents != '\r';
          if( s = s.hasOwnProperty('appliedFont') ) app.selection = [];
          if( EOF ) ps[n-1].insertionPoints.lastItem().contents = '\r';
          while( i-- )
              do{ j = ~~(n*mRAND()) }while( i==j )
              k = ~~(2*mRAND());
              if( 2*k-1 != j-i ) ps[i].move(LOCS[k],ps[j]);
          if( EOF ) sto.characters.lastItem().contents = '';
          if( !s ) return;
          sto.insertionPoints[ip0].select();
          sto.insertionPoints[ip1].select(SelectionOptions.ADD_TO);
      try{ shuffleSelectedParagraphs() }catch(_){alert(_.message);}
        • 1. Re: Shuffle Words
          Not a solution but a reasonable workaround for the current script: put each word in a separate paragraph by changing all spaces to a return. Run the script. Change returns back to spaces.
          • 2. Re: Shuffle Words
            Trevorׅ Adobe Community Professional
            A somewhat sloppy implementation.
            function shufflePargraphWords(paragraph) {
                paragraph = app.selection[0];
                if (!paragraph || !paragraph.hasOwnProperty('paragraphs')) {
                    return 'no selection';
                paragraph = paragraph.paragraphs[0];
                var a, temp, n, words, firstWord, x, level;
                paragraph.insertionPoints[-1].contents = ' ';
                app.findGrepPreferences = app.changeGrepPreferences = null;
                app.findGrepPreferences.findWhat = '\\S+\\s*';
                words = paragraph.findGrep().slice();
                len = words.length;
                while (len) {
                    x = (Math.random() * len--) | 0;
                    temp = words[len];
                    words[len] = words[x];
                    words[x] = temp;
                len = words.length;
                n = len - 1;
                level = $.level;
                $.level = 0;
                while (len--) {
                    try {
                        words[len].move(LocationOptions.AT_END, paragraph);
                    } catch (e) {}
                $.level = level;
                if (paragraph.characters[-1].contents === ' ') {
                    paragraph.characters[-1].remove();
                return 'Shuffled';
            app.doScript(shufflePargraphWords, ScriptLanguage.JAVASCRIPT, undefined, UndoModes.ENTIRE_SCRIPT, 'Shuffled Words');
            HTH
            Trevor
            • 3. Re: Shuffle Words
              Marc Autret Level 4
              Hi wespor,
              To keep more consistent with the original shuffle-paragraph routine—http://forums.adobe.com/message/3834317#3834317—you may also try this:
              function shuffleSelectedWords()
                  const mRAND = Math.random;
                  var s = app.properties.selection && app.selection[0],
                      ws = s && s.hasOwnProperty('words') && s.words,
                      n = ws && ws.length;
                  if( n < 2 ) throw Error("Please select at least two words.");
                  var sto = ws[0].parentStory,
                      ip0 = ws[0].insertionPoints.firstItem().index,
                      ip1 = ws[n-1].insertionPoints.lastItem().index;
                  if( s=s.hasOwnProperty('appliedFont') ) app.selection = [];
                  ws = ws.everyItem().contents;
                  for( var t ; n ; (t=ws.splice(~~(n--*mRAND()),1)[0]), ws.push(t) );
                  ws = ws.join(' ');
                  sto.insertionPoints.itemByRange(ip0,ip1).contents = ws;
                  if( !s ) return;
                  sto.insertionPoints[ip0+ws.length].select(SelectionOptions.ADD_TO);
              try{ shuffleSelectedWords() }catch(_){ alert(_.message) }
              Note. — This code should be a bit faster since it doesn't hit the DOM during the shuffling stage (to the price of losing character style ranges.)
              Marc
              • 4. Re: Shuffle Words
                wespor Level 1
                Thank you, that is awesome! Trying to figure out how to reverse engineer that and sort by Alphabetical order next. I need to shuffle between the two.
