Hi, I'm having issues opening an illustrator file, it gives me the following error "Adobe PDF File Format is having difficulties. Object label badly formatted".
That is an .ai file I'm trying to open, not .pdf.
Any ideas how to fix this? I uploaded the file here, maybe somebody can check it out - https://failiem.lv/u/khs2typr
Create a new file and then place the other file in it.
This will ruin much of your editability, especially the text.
You will need to place it cia FIle > PLace in order to get all artboards/pages.
Try to open the file in Acrobat.
Choose Edit > Edit Text & Images
Edit > Select All and using ctrl or right mouse click: Edit Using > Adobe Illustrator
Rename the extension to .pdf. If it has an .ai extension your file will not open in Acrobat. If renamed to .pdf it opens fine.
