• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Photoshop - perform spatial integration on an image
Engaged ,
Jun 26, 2017 Jun 26, 2017
Does anyone have a suggestion on how to perform spatial integration on an image in Photoshop using the built-in filters?
b(0,j) = a(0,j);
for ( i=1; i<width; i++)
b(i,j) = a(i,j) + b(i-1,j);
or
b(j,0) = a(j,0);
b(j,i) = a(j,i) + b(j,i-1);
where:
     b is row or column of image  b(i,j) or b(j,i)
     i  is index within the row or column
     j is orthogonal to i so it is index of column or row.
Is there a layer tool that might do this?  Plugin?  I can do with jsx but is pain!!!!!
RONC
Views
634
Translate
Translate
Report
Report
Community guidelines
community guidelines
Engaged , Jun 28, 2017 Jun 28, 2017
I figured how to do using Photoshop javascript and will try to remember to document when I have debugged and looked at speed.  Document will appear in scripting forum if I deem useable time wise.
Thanks for help.
RONC
Votes
Translate
Translate
Adobe
LEGEND ,
I'm not sure what you are trying to do, but perhaps the average blure will do? After all, it's the median value of all pixels and you can always scale it by the number of pixels, as far as you know them.
Mylenium
Votes
Translate
Translate
Report
Report
Engaged ,
Mylenium,
Average blur is what I started with but found that has to be called once to get each i index i value.  Also have to select for each i index value.  This a tremendous waste of computation time and people in front of screen time.
  I really appreciate you response.
RONC
Votes
Translate
Translate
Report
Report
Community Expert ,
Votes
Translate
Translate
Report
Report
Engaged ,
Dave,
Thanks for response.
Custom filter is even worse trying to emulate what I want and it is only 5 pixels in width.
Someone should rename this filter to User defined Convolution Filter(limited).   Custom filter says nothing!!!!!!  HiPass also is INCORRECT title.
RONC
Votes
Translate
Translate
Report
Report
Community Expert ,
Sorry Ronc
I had not looked closely enough at your code . Now that I see exactly what you are doing I don't know of a filter that would replicate that.
Incidentally, I agree on the "Custom Filter" label - although I doubt it will change - it has been there for years.
Dave
Votes
Translate
Translate
Report
Report
Engaged ,
Dave,
I'll bet what I'm asking for is used in the the BOX blur filter.  Anyway the internals are addressable from JSX?
I think Custom Filter was in Filter Factory about an Adobe century ago.
Regards,
RONC
Votes
Translate
Translate
Report
Report
Community Expert ,
If the Filter Factory filter would do it, maybe Filter Foundary will work.
It's a more modern version Filter Factory, although not an exact replacement, most of the code that worked in filter factory works in it.
The major downside is it only works in the 32 bit version of photoshop on windows unless you have a relativity old version of mac os x or mac os.
Telegraphics - Free plugins for Photoshop & Illustrator...and other software
Votes
Translate
Translate
Report
Report
Engaged ,
The reference to Filter Factory was off topic referring to the Custom Filter.  I think there is a x64 version out there but I've overused my memory for a bit.
Thanks for trying.
RONC
Votes
Translate
Translate
Report
Report
Engaged ,
LATEST
Thanks for help.
RONC
Votes
Translate
Translate
Report
Report
