Since I updated the standalone player to 24, and even to thise day at 26, I've been having a problem with the standalone player.
it adds ' -relaunched' to the end of any file that opens with it.
This causes it to show a white screen.
I can drag the files on to the standalone flash player, and they'll work fine.
But running a swf file adds ' -relaunched' to the end of the file name as far as flash player is concerned, and it just opens to a white screen.
How do I go about removing the appended text when opening flash files?
I don't want to have to open the Flash folder, run flashplayer_##_sa.exe (which simply runs ' -relaunched' as a file name, so it is probably some kind of launch command), then open the folder with the flash file, then drag the file on to the flash projector every time I want to run a swf or flv, etcetera. !
The symptoms you're describing are pretty weird. What operating system are we talking about?
Yeah, I've been having the same issue since your rough estimate (obviously it worked fine at some point before).
The standalone projector always appends the -relaunched parameter whenever it opens, so associating it with .swf or .flv files will end up in just opening to a white screen. Requires a second manual opening of the file once it's open.
Personally using Windows 10 build 15063.483.
