3 Replies Latest reply on Jun 27, 2017 4:36 PM by ashleyv75042719
    Photoshop CC 2017 crashing
    ashleyv75042719
      Hello helpers,
           I've recently spent the past 2 days troubleshooting why Photoshop is determined to keep crashing. I've read up on several discussion threads and tried several different 'fixes' to no avail. I'm trying to 'Automate' a customised action to process a batch of files. Things I've tried include, not necessarily in this order;
      1) Turning off 'Show Messages'
      2) Turning off 'Use Graphics Processor'
      3) Checked to see if I have a Nvidia graphics card - but I do not!
      4) Turning off 'Allow Extensions to Connect to the Internet'
      5) Turning off 'Load Extensions Panels'
      6) Checked the 'Scratch Disk' is local and has enough free space (currently 155GB)
      7) Ensured Photoshop is up to date (See below)
      8) Ensured 'Photoshop Memory' is adequate - 4837MB (70% should be fine?)
      9) Ensured 'Efficiency' is at least 95% - currently 100%
      10) Inserting a tilde in front of the 'Spaces' folder
      From what I've read, there does not appear to be a proper fix? Different things appear to work for different people, for different lengths of time? The only thing remaining is to hear back from the 3rd party plugin developer regarding the QIA Plugin (See below). I've just ran the Default Action 'Sepia Toning (Layer)' about 6 times with 20 images and cannot make it trip up! Maybe I need to re-write the actions recipe from scratch?
      I have the two faults listed at the end of this message.
      Any help would be appreciated!
      Adobe Photoshop Version: 2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967  x64
      Number of Launches: 12
      Version: 10 or greater
      System architecture: Intel CPU Family:6, Model:14, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2
      Physical processor count: 4
      Processor speed: 2496 MHz
      Built-in memory: 8073 MB
      Free memory: 4033 MB
      Memory available to Photoshop: 6911 MB
      Memory used by Photoshop: 70 %
      History Thumbnails: Enabled.
      Touch Bar: Enabled.
      Alias Layers: Disabled.
      Modifier Palette: Enabled.
      Highbeam: Enabled.
      Image tile size: 1024K
      Image cache levels: 4
      Font Preview: Medium
      TextComposer: Latin
      Display: 1
      Display Bounds: top=0, left=0, bottom=1200, right=1920
      Display: 2
      Display Bounds: top=0, left=1920, bottom=1440, right=2820
      OpenGL Drawing: Enabled.
      OpenGL Allow Old GPUs: Not Detected.
      OpenGL Drawing Mode: Normal
      OpenGL Allow Normal Mode: True.
      OpenGL Allow Advanced Mode: True.
      AIFCoreInitialized=1
      AIFOGLInitialized=1
      OGLContextCreated=1
      NumGLGPUs=1
      NumCLGPUs=1
      NumNativeGPUs=0
      glgpu[0].GLVersion="4.1"
      glgpu[0].IsIntegratedGLGPU=0
      glgpu[0].GLMemoryMB=1024
      glgpu[0].GLName="Intel(R) HD Graphics 530"
      glgpu[0].GLVendor="Intel"
      glgpu[0].GLVendorID=32902
      glgpu[0].GLDriverVersion="21.20.16.4551"
      glgpu[0].GLRectTextureSize=16384
      glgpu[0].GLRenderer="Intel(R) HD Graphics 530"
      glgpu[0].GLRendererID=6418
      glgpu[0].HasGLNPOTSupport=1
      glgpu[0].GLDriver="igdumdim64,igd10iumd64,igd10iumd64,igd12umd64,igdumdim32,igd10iumd32,ig d10iumd32,igd12umd32"
      glgpu[0].GLDriverDate="20161118000000.000000-000"
      glgpu[0].CanCompileProgramGLSL=1
      glgpu[0].GLFrameBufferOK=1
      glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.30 - Build 21.20.16.4551"
      glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1447 ]
      glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
      glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
      glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
      glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
      glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
      glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
      glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
      glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[64]
      glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
      glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
      glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=0
      clgpu[0].CLPlatformVersion="2.0 "
      clgpu[0].CLDeviceVersion="2.0 "
      clgpu[0].IsIntegratedCLGPU=1
      clgpu[0].CLMemoryMB=3221
      clgpu[0].CLName="Intel(R) HD Graphics 530"
      clgpu[0].CLVendor="Intel(R) Corporation"
      clgpu[0].CLVendorID=32902
      clgpu[0].CLDriverVersion="21.20.16.4551"
      clgpu[0].CLBandwidth=9.67295e+09
      clgpu[0].CLCompute=163.878
      License Type: Subscription
      Serial number: 96040278839907838185
      GUIDBucket:
        bucket: 172
        test: DocumentPanel
      Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\
      Temporary file path: C:\Users\ashley\AppData\Local\Temp\
      Photoshop scratch has async I/O enabled
      Scratch volume(s):
        Startup, 237.9G, 155.0G free
      Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-ins\
      Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\
      Installed components:
         A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
         ACE.dll   ACE 2017/01/26-01:10:02   79.579975   79.579975
         AdbePM.dll   PatchMatch 2016/11/03:19:48:57   1.578146   1.578146
         AdobeLinguistic.dll   Adobe Linguisitc Library   10.0.0
         AdobeOwl.dll   Adobe Owl   5.2.11
         AdobePDFL.dll   PDFL 2016/08/10-16:53:20   79.195992   79.195992
         AdobePIP.dll   Adobe Product Improvement Program   7.4.1.60.45263
         AdobeSVGAGM.dll   AdobeSVGAGM   79.579975   79.579975
         AdobeXMP.dll   Adobe XMP Core 2016/09/14-01:09:01   79.159824   79.159824
         AdobeXMPFiles.dll   Adobe XMP Files 2016/09/14-01:09:01   79.159824   79.159824
         AdobeXMPScript.dll   Adobe XMP Script 2016/09/14-01:09:01   79.159824   79.159824
         adobe_caps.dll   Adobe CAPS   10,0,0,6
         AGM.dll   AGM 2017/01/26-01:10:02   79.579975   79.579975
         ahclient.dll    AdobeHelp Dynamic Link Library   2.2.0.1
         AIDE.dll   AIDE 2016/05/27-01:08:49   79.574279   79.574279
         amtlib.dll   AMTLib (64 Bit)   10.0.0.119 BuildVersion: 10.0; BuildDate: Thu Dec 22 2016 3:0:7)   1.000000
         ARE.dll   ARE 2017/01/26-01:10:02   79.579975   79.579975
         AXE8SharedExpat.dll   AXE8SharedExpat 2015/03/13-23:40:54   79.562390   79.562390
         AXEDOMCore.dll   AXEDOMCore 2015/03/13-23:40:54   79.562390   79.562390
         Bib.dll   BIB 2017/01/26-01:10:02   79.579975   79.579975
         BIBUtils.dll   BIBUtils 2017/01/26-01:10:02   79.579975   79.579975
         boost_date_time.dll   photoshopdva   10.0.0
         boost_signals.dll   photoshopdva   10.0.0
         boost_system.dll   photoshopdva   10.0.0
         boost_threads.dll   photoshopdva   10.0.0
         cg.dll   NVIDIA Cg Runtime   3.0.00007
         cgGL.dll   NVIDIA Cg Runtime   3.0.00007
         CITThreading.dll   Adobe CITThreading   2.1.0.1   2.1.0.1
         CoolType.dll   CoolType 2017/01/26-01:10:02   79.579975   79.579975
         dnssd.dll   Bonjour   3,0,0,2
         dvaaudiodevice.dll   photoshopdva   10.0.0
         dvacore.dll   photoshopdva   10.0.0
         dvacrashhandler.dll   Adobe Audition CC 2017   10.0.0
         dvamarshal.dll   photoshopdva   10.0.0
         dvamediatypes.dll   photoshopdva   10.0.0
         dvametadata.dll   photoshopdva   10.0.0
         dvametadataapi.dll   photoshopdva   10.0.0
         dvametadataui.dll   photoshopdva   10.0.0
         dvaplayer.dll   photoshopdva   10.0.0
         dvatransport.dll   photoshopdva   10.0.0
         dvaui.dll   photoshopdva   10.0.0
         dvaunittesting.dll   photoshopdva   10.0.0
         dynamiclink.dll   photoshopdva   10.0.0
         ExtendScript.dll   ExtendScript 2016/12/13-13:10:33   80.1089815   80.1089815
         icucnv40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
         icudt40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
         icuuc40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
         igestep30.dll   IGES Reader   9.3.0.113
         imslib.dll   IMSLib DLL   10.0.0.11
         JP2KLib.dll   JP2KLib 2017/04/05-14:24:38   79.266006   79.266006
         libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
         libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
         libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
         LogSession.dll   LogSession   7.4.1.60.45263
         mediacoreif.dll   photoshopdva   10.0.0
         MPS.dll   MPS 2016/09/14-15:20:26   79.577269   79.577269
         pdfsettings.dll   Adobe PDFSettings   1.04
         Photoshop.dll   Adobe Photoshop CC 2017   18.1.1
         Plugin.dll   Adobe Photoshop CC 2017   18.1.1
         PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   7.0.0
         PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   7.0.0.67
         PSArt.dll   Adobe Photoshop CC 2017   18.1.1
         PSViews.dll   Adobe Photoshop CC 2017   18.1.1
         SCCore.dll   ScCore 2016/12/13-13:10:33   80.1089815   80.1089815
         SVGRE.dll   SVGRE   79.579975   79.579975
         svml_dispmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
         tbb.dll   Intel(R) Threading Building Blocks for Windows   4, 4, 2016, 0412
         tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   4, 4, 2016, 0412
         TfFontMgr.dll   FontMgr   9.3.0.113
         TfKernel.dll   Kernel   9.3.0.113
         TFKGEOM.dll   Kernel Geom   9.3.0.113
         TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
         updaternotifications.dll   Adobe Updater Notifications Library   10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   10.0.0.1
         VulcanControl.dll   Vulcan Application Control Library   5.3.0.16
         VulcanMessage5.dll   Vulcan Message Library   5.3.0.16
         WRServices.dll   WRServices Thu Jan 07 2016 04:50:10   Build 0.21960   0.21960
         wu3d.dll   U3D Writer   9.3.0.113
      Required plug-ins:
         3D Studio 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
         Accented Edges 18.1.1 - from the file “Filter Gallery”
         Adaptive Wide Angle 18.1.1 - from the file “Adaptive Wide Angle”
         Angled Strokes 18.1.1 - from the file “Filter Gallery”
         Average 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Average”
         Bas Relief 18.1.1 - from the file “Filter Gallery”
         BMP 18.1.1 - from the file “Standard MultiPlugin”
         Camera Raw 9.10.1 - from the file “Camera Raw”
         Camera Raw Filter 9.10.1 - from the file “Camera Raw”
         Chalk && Charcoal 18.1.1 - from the file “Filter Gallery”
         Chrome 18.1.1 - from the file “Filter Gallery”
         Cineon 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Cineon”
         Clouds 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Clouds”
         Collada 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
         Color Halftone 18.1.1 - from the file “Standard MultiPlugin”
         Colored Pencil 18.1.1 - from the file “Filter Gallery”
         CompuServe GIF 18.1.1 - from the file “Standard MultiPlugin”
         Conté Crayon 18.1.1 - from the file “Filter Gallery”
         Craquelure 18.1.1 - from the file “Filter Gallery”
         Crop and Straighten Photos 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “CropPhotosAuto”
         Crop and Straighten Photos Filter 18.1.1 - from the file “Standard MultiPlugin”
         Crosshatch 18.1.1 - from the file “Filter Gallery”
         Crystallize 18.1.1 - from the file “Standard MultiPlugin”
         Cutout 18.1.1 - from the file “Filter Gallery”
         Dark Strokes 18.1.1 - from the file “Filter Gallery”
         De-Interlace 18.1.1 - from the file “Standard MultiPlugin”
         Dicom 18.1.1 - from the file “Dicom”
         Difference Clouds 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Clouds”
         Diffuse Glow 18.1.1 - from the file “Filter Gallery”
         Displace 18.1.1 - from the file “Standard MultiPlugin”
         Dry Brush 18.1.1 - from the file “Filter Gallery”
         Eazel Acquire 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “EazelAcquire”
         Entropy 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
         Export Color Lookup Tables 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Export3DLUT”
         Extrude 18.1.1 - from the file “Standard MultiPlugin”
         FastCore Routines 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “FastCore”
         Fibers 18.1.1 - from the file “Standard MultiPlugin”
         Film Grain 18.1.1 - from the file “Filter Gallery”
         Filter Gallery 18.1.1 - from the file “Filter Gallery”
         Flash 3D 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
         Fresco 18.1.1 - from the file “Filter Gallery”
         Glass 18.1.1 - from the file “Filter Gallery”
         Glowing Edges 18.1.1 - from the file “Filter Gallery”
         Google Earth 4 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
         Graphic Pen 18.1.1 - from the file “Filter Gallery”
         Halftone Pattern 18.1.1 - from the file “Filter Gallery”
         HDRMergeUI 18.1.1 - from the file “HDRMergeUI”
         HSB/HSL 18.1.1 - from the file “Standard MultiPlugin”
         IFF Format 18.1.1 - from the file “Standard MultiPlugin”
         IGES 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
         Ink Outlines 18.1.1 - from the file “Filter Gallery”
         JPEG 2000 18.1.1 - from the file “JPEG2000”
         Kurtosis 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
         Lens Blur 18.1.1 - from the file “Lens Blur”
         Lens Correction 18.1.1 - from the file “Lens Correction”
         Lens Flare 18.1.1 - from the file “Standard MultiPlugin”
         Liquify 18.1.1 - from the file “Liquify”
         Matlab Operation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “ChannelPort”
         Maximum 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
         Mean 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
         Measurement Core 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MeasurementCore.8me”
         Median 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
         Mezzotint 18.1.1 - from the file “Standard MultiPlugin”
         Minimum 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
         MMXCore Routines 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MMXCore”
         Mosaic Tiles 18.1.1 - from the file “Filter Gallery”
         Multiprocessor Support 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MultiProcessor Support”
         Neon Glow 18.1.1 - from the file “Filter Gallery”
         Note Paper 18.1.1 - from the file “Filter Gallery”
         NTSC Colors 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “NTSC Colors”
         Ocean Ripple 18.1.1 - from the file “Filter Gallery”
         OpenEXR 18.1.1 - from the file “Standard MultiPlugin”
         Paint Daubs 18.1.1 - from the file “Filter Gallery”
         Palette Knife 18.1.1 - from the file “Filter Gallery”
         Patchwork 18.1.1 - from the file “Filter Gallery”
         Paths to Illustrator 18.1.1 - from the file “Standard MultiPlugin”
         PCX 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “PCX”
         Photocopy 18.1.1 - from the file “Filter Gallery”
         Photoshop 3D Engine 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Photoshop3DEngine”
         Photoshop Touch 14.0 - from the file “PSDX”
         Picture Package Filter 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “ChannelPort”
         Pinch 18.1.1 - from the file “Standard MultiPlugin”
         Pixar 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Pixar”
         Plaster 18.1.1 - from the file “Filter Gallery”
         Plastic Wrap 18.1.1 - from the file “Filter Gallery”
         PLY 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
         PNG 18.1.1 - from the file “Standard MultiPlugin”
         Pointillize 18.1.1 - from the file “Standard MultiPlugin”
         Polar Coordinates 18.1.1 - from the file “Standard MultiPlugin”
         Portable Bit Map 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “PBM”
         Poster Edges 18.1.1 - from the file “Filter Gallery”
         PRC 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
         Radial Blur 18.1.1 - from the file “Standard MultiPlugin”
         Radiance 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Radiance”
         Range 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
         Render Color Lookup Grid 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Export3DLUT”
         Reticulation 18.1.1 - from the file “Filter Gallery”
         Ripple 18.1.1 - from the file “Standard MultiPlugin”
         Rough Pastels 18.1.1 - from the file “Filter Gallery”
         Save for Web 18.1.1 - from the file “Save for Web”
         ScriptingSupport 18.1.1 - from the file “ScriptingSupport”
         Shake Reduction 18.1.1 - from the file “Shake Reduction”
         Shear 18.1.1 - from the file “Standard MultiPlugin”
         Skewness 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
         Smart Blur 18.1.1 - from the file “Standard MultiPlugin”
         Smudge Stick 18.1.1 - from the file “Filter Gallery”
         Solarize 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Solarize”
         Spaces 18.1.1 - from the file “Spaces”
         Spatter 18.1.1 - from the file “Filter Gallery”
         Spherize 18.1.1 - from the file “Standard MultiPlugin”
         Sponge 18.1.1 - from the file “Filter Gallery”
         Sprayed Strokes 18.1.1 - from the file “Filter Gallery”
         Stained Glass 18.1.1 - from the file “Filter Gallery”
         Stamp 18.1.1 - from the file “Filter Gallery”
         Standard Deviation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
         STL 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
         Sumi-e 18.1.1 - from the file “Filter Gallery”
         Summation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
         Targa 18.1.1 - from the file “Standard MultiPlugin”
         Texturizer 18.1.1 - from the file “Filter Gallery”
         Tiles 18.1.1 - from the file “Standard MultiPlugin”
         Torn Edges 18.1.1 - from the file “Filter Gallery”
         Twirl 18.1.1 - from the file “Standard MultiPlugin”
         U3D 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
         Underpainting 18.1.1 - from the file “Filter Gallery”
         Vanishing Point 18.1.1 - from the file “VanishingPoint”
         Variance 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
         Virtual Reality Modeling Language | VRML 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
         Water Paper 18.1.1 - from the file “Filter Gallery”
         Watercolor 18.1.1 - from the file “Filter Gallery”
         Wave 18.1.1 - from the file “Standard MultiPlugin”
         Wavefront|OBJ 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
         WIA Support 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “WIASupport”
         Wind 18.1.1 - from the file “Standard MultiPlugin”
         Wireless Bitmap 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “WBMP”
         ZigZag 18.1.1 - from the file “Standard MultiPlugin”
      Optional and third party plug-ins:
             Save as 2nd 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\2nd_Setup64.8bf”
            ____________________ 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Separator-II-364.8bf”
            Centroids 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Lin_Centroid64.8bf”
            Euclidean Distance 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Mor_EDM64.8bf”
            Fill Holes 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Mor_FillHoles64.8bf”
            Morphology - EDM 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Mor_EDM_Morphology64.8bf”
            Morphology - Legacy 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Mor_General64.8bf”
            Outlines 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Mor_Outline64.8bf”
           ____________________ 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Separator-VI-264.8bf”
           Area Fraction 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Mea_Global64.8bf”
           Arithmetic 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Mat_General64.8bf”
           Brightness 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Mea_Brightness64.8bf”
           Calibrate Density 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Mea_DensityCalib64.8bf”
           Calibrate Magnification 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Mea_Calibrate64.8bf”
           Clustering 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Mea_Clustering64.8bf”
           Count 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Fea_CountMarks64.8bf”
           Skeletonize 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Mor_Skeletonize64.8bf”
           Thicken Skeleton 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Mor_Thicken64.8bf”
           Total Line Length 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Mea_TotalLength64.8bf”
          ____________________ 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Separator-VII-164.8bf”
          ____________________ 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Separator-VIII-164.8bf”
          Apply Color Table 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Col_ApplyCLUT64.8bf”
          Color by Value 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Fea_ColorByValue64.8bf”
          Color Space Transform 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Col_ColorSpace64.8bf”
          Conditional Smoothing 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Pro_ConditionalSmooth64.8bf”
          Cycloid Grid 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Lin_Cycloids64.8bf”
          Fourier Transform (FFT) 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\FFT_Forward64.8bf”
          Histogram Shaping 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Adj_HistoShape64.8bf”
          Homomorphic Compression 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Adj_Homomorphic64.8bf”
          Hybrid Median 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Ran_HybridMedian64.8bf”
          Label Features 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Fea_Label64.8bf”
          Line Grids 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Lin_LineGrids64.8bf”
          Local Equalization 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Pro_LocalEQ64.8bf”
          Measure All Features 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Fea_MeasureAll64.8bf”
          Measure All Regions 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Fea_Regions64.8bf”
          Morphology - Brightness 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Ran_GrayMorph64.8bf”
          Morphology - Color 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Ran_ColorMorph64.8bf”
          Parallel Lines 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Lin_Parallel64.8bf”
          Point Grids 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Lin_PointGrids64.8bf”
          Principal Components 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Mul_PCA64.8bf”
          Pruned Skeleton 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Mor_Prune64.8bf”
          Radial Lines 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Lin_Radial64.8bf”
          Reject Features 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Fea_Cutoff64.8bf”
          Select Features 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Fea_Select264.8bf”
          Select Skeleton Components 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Thr_Skeleton64.8bf”
         ____________________ 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Separator-I64.8bf”
         ____________________ 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Separator-II-064.8bf”
         ____________________ 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Separator-VII-064.8bf”
         ____________________ 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Separator-VIII-064.8bf”
         Apply Filter and Inverse FFT 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\FFT_Filter+Inverse64.8bf”
         AutoLevel 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Adj_AutoLevel64.8bf”
         Background Removal 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Adj_RemoveBackground64.8bf”
         Bilevel Thresholding 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Thr_BiLevel64.8bf”
         Boolean 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Mat_BooleanGeneral64.8bf”
         Color Tolerance 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Thr_HSIRange64.8bf”
         Contours 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Thr_Contour64.8bf”
         Convolution 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\FFT_Convolution64.8bf”
         Cross Correlation 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\FFT_CrossCorrelate64.8bf”
         Custom 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Pro_Custom64.8bf”
         Deconvolution (PSF in 2nd) 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\FFT_Deconvolve64.8bf”
         Edge Lines 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Pro_FindEdges64.8bf”
         Edge Orientation 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Pro_SobelDir64.8bf”
         Edge Refinement 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Pro_SharpenSteps64.8bf”
         Find Spots 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Ran_TopHat64.8bf”
         Grain Size (ASTM) 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Mea_GrainSize64.8bf”
         Histogram Brightness 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Mea_Histogram64.8bf”
         Histogram Orientation 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Mea_Orientation64.8bf”
         Isolate Pen Color 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Thr_PenColor64.8bf”
         Mask by 2nd 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Mat_Mask64.8bf”
         Neighborhood Rank 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Ran_Neighborhood64.8bf”
         Plot (Distribution) 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Fea_Distribution64.8bf”
         Plot (Scatter) 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Fea_Plot64.8bf”
         Profiles 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Mea_Profiles64.8bf”
         Range 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Ran_Range64.8bf”
         Select by 2nd 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Mat_FeatureAnd64.8bf”
         Show Power Spectrum 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\FFT_PowerSpectrum64.8bf”
         Texture 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Pro_TextureFractal64.8bf”
         Threshold HSI 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Thr_HSI64.8bf”
         Threshold Levels 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Thr_Levels64.8bf”
         Ultimate Points 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Mor_EDM_UEP64.8bf”
         Variance 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Pro_Variance64.8bf”
         Watershed Segmentation 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Mor_EDM_Watershed64.8bf”
      Duplicate and Disabled plug-ins:
         ____________________ 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Separator-III-064.8bf”
         ____________________ 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Separator-IV-064.8bf”
         ____________________ 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\QIA Plug-Ins\Separator-VI-064.8bf”
      Plug-ins that failed to load: NONE
      Extensions:
         Recent Files  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
         com.adobe.inapp.purchase  2.10.56 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_10_56\purchase.html”
         New Document  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\fnft.html”
         Libraries  2.10.56 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_10_56\index.html”
         Start  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
         com.adobe.experimentation.extension  2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.experimentation.extension\index.html”
         Adobe Color Themes  6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
         Export As  3.0.8 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
         Device Preview  1.3.2 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSPanel\panel.html”
         com.adobe.preview.loader  1.3.2 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSLoader\loader.html”
      Installed TWAIN devices: NONE
      Faulting application name: Adobe Spaces Helper.exe, version: 0.0.0.0, time stamp: 0x58fefe7b
      Faulting module name: libcef.dll, version: 3.2924.1537.0, time stamp: 0x584a4ed5
      Exception code: 0xc0000005
      Fault offset: 0x000000000018b0a6
      Faulting process id: 0x2e64
      Faulting application start time: 0x01d2eee7d48d8638
      Faulting application path: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-ins\Spaces\Adobe Spaces Helper.exe
      Faulting module path: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-ins\Spaces\libcef.dll
      Report Id: 23cec97b-3945-4c26-ab48-e115a030c433
      Faulting package full name:
      Faulting package-relative application ID:
      Faulting application name: Photoshop.exe, version: 18.1.1.252, time stamp: 0x58fefd04
      Faulting module name: ntdll.dll, version: 10.0.15063.0, time stamp: 0xb79b6ddb
      Fault offset: 0x000000000002cacf
      Faulting process id: 0x37c
      Faulting application start time: 0x01d2eee7a7b696f9
      Faulting application path: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Photoshop.exe
      Faulting module path: C:\WINDOWS\SYSTEM32\ntdll.dll
      Report Id: dcb65d46-ed4a-4ffc-9abf-c3535d4e1ef5
