30 Replies Latest reply on Jul 5, 2017 4:23 AM by haithamd86457119
    Photoshop cs6 Problem at 3D
    haithamd86457119
      Hello there,
      I have a problem in my 3D ,
      I cann't use 3D in photoshop ,
      what should i do ????
        • 1. Re: Photoshop cs6 Problem at 3D
          c.pfaffenbichler Level 9
          What are the image’s Color Mode and bit depth?
          How exactly does the 3D option fail?
          • 2. Re: Photoshop cs6 Problem at 3D
            davescm Adobe Community Professional
            Hi
            Your screen shot shows your Graphics Processor is not being used (it is greyed out). In CS6 the requirements for 3D are that the GPU meets the minimum requirements and that the version is CS6 Extended.
            Can you go to Help - System Info click on copy and then paste that information into a post here.
            Dave
            2 people found this helpful
            • 3. Re: Photoshop cs6 Problem at 3D
              haithamd86457119 Level 1
              I Download this version from ur website after asking you that i want photoshop cs6 and you told me to dowload this
              k....Now what should i do
              Did I should download or do somthing
              • 4. Re: Photoshop cs6 Problem at 3D
                As per my last post can you go to Help - System Info click on copy and then paste that information into a post here
                Dave
                • 5. Re: Photoshop cs6 Problem at 3D
                  What Photoshop CS6 license do you own? Normal or Ectended?
                  • 6. Re: Photoshop cs6 Problem at 3D
                    Test screen name
                    I don't Know
                    you can tell How can I know then i will told you
                    Davescm
                    How can go to system info?
                    • 7. Re: Photoshop cs6 Problem at 3D
                      Refer back to your original order to find out what you paid for. Were you able to use 3D in the previous years since you purchased Photoshop CS6?
                      Dave told you: Help - System Info. That is, look on the Help menu.
                      • 8. Re: Photoshop cs6 Problem at 3D
                        Davescm
                        then
                        Then paste into a forum post
                        Dave
                        • 9. Re: Photoshop cs6 Problem at 3D
                          Adobe Photoshop Version: 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00) x32
                          Operating System: Windows 7 32-bit
                          Version: 6.1 Service Pack 1
                          System architecture: Intel CPU Family:15, Model:6, Stepping:5 with MMX, SSE Integer, SSE FP, SSE2, SSE3, HyperThreading
                          Physical processor count: 1
                          Logical processor count: 2
                          Processor speed: 3000 MHz
                          Built-in memory: 3062 MB
                          Free memory: 1556 MB
                          Memory available to Photoshop: 1664 MB
                          Memory used by Photoshop: 60 %
                          Image tile size: 128K
                          Image cache levels: 4
                          The GPU Sniffer crashed on 29/06/2017 at 02:05:15 م
                          Display: 1
                          Display Bounds:=  top: 0, left: 0, bottom: 900, right: 1440
                          No video card detected
                          Serial number: Tryout Version
                          Application folder: C:\Program Files\Adobe\Adobe Photoshop CS6\
                          Temporary file path: C:\Users\Essam\AppData\Local\Temp\
                          Photoshop scratch has async I/O enabled
                          Scratch volume(s):
                            Startup, 73.2G, 42.4G free
                          Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6\Required\
                          Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6\Plug-ins\
                          Additional Plug-ins folder: not set
                          Installed components:
                             A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
                             ACE.dll   ACE 2012/01/18-15:07:40   66.492997   66.492997
                             adbeape.dll   Adobe APE 2012/01/25-10:04:55   66.1025012   66.1025012
                             AdobeLinguistic.dll   Adobe Linguisitc Library   6.0.0
                             AdobeOwl.dll   Adobe Owl 2012/02/09-16:00:02   4.0.93   66.496052
                             AdobePDFL.dll   PDFL 2011/12/12-16:12:37   66.419471   66.419471
                             AdobePIP.dll   Adobe Product Improvement Program   6.0.0.1654
                             AdobeXMP.dll   Adobe XMP Core 2012/02/06-14:56:27   66.145661   66.145661
                             AdobeXMPFiles.dll   Adobe XMP Files 2012/02/06-14:56:27   66.145661   66.145661
                             AdobeXMPScript.dll   Adobe XMP Script 2012/02/06-14:56:27   66.145661   66.145661
                             adobe_caps.dll   Adobe CAPS   6,0,29,0
                             AGM.dll   AGM 2012/01/18-15:07:40   66.492997   66.492997
                             ahclient.dll    AdobeHelp Dynamic Link Library   1,7,0,56
                             aif_core.dll   AIF   3.0   62.490293
                             aif_ocl.dll   AIF   3.0   62.490293
                             aif_ogl.dll   AIF   3.0   62.490293
                             amtlib.dll   AMTLib   6.0.0.75 (BuildVersion: 6.0; BuildDate: Mon Jan 16 2012 18:00:00)   1.000000
                             ARE.dll   ARE 2012/01/18-15:07:40   66.492997   66.492997
                             AXE8SharedExpat.dll   AXE8SharedExpat 2011/12/16-15:10:49   66.26830   66.26830
                             AXEDOMCore.dll   AXEDOMCore 2011/12/16-15:10:49   66.26830   66.26830
                             Bib.dll   BIB 2012/01/18-15:07:40   66.492997   66.492997
                             BIBUtils.dll   BIBUtils 2012/01/18-15:07:40   66.492997   66.492997
                             boost_date_time.dll   DVA Product   6.0.0
                             boost_signals.dll   DVA Product   6.0.0
                             boost_system.dll   DVA Product   6.0.0
                             boost_threads.dll   DVA Product   6.0.0
                             cg.dll   NVIDIA Cg Runtime   3.0.00007
                             cgGL.dll   NVIDIA Cg Runtime   3.0.00007
                             CIT.dll   Adobe CIT   2.0.5.19287   2.0.5.19287
                             CoolType.dll   CoolType 2012/01/18-15:07:40   66.492997   66.492997
                             data_flow.dll   AIF   3.0   62.490293
                             dvaaudiodevice.dll   DVA Product   6.0.0
                             dvacore.dll   DVA Product   6.0.0
                             dvamarshal.dll   DVA Product   6.0.0
                             dvamediatypes.dll   DVA Product   6.0.0
                             dvaplayer.dll   DVA Product   6.0.0
                             dvatransport.dll   DVA Product   6.0.0
                             dvaunittesting.dll   DVA Product   6.0.0
                             dynamiclink.dll   DVA Product   6.0.0
                             ExtendScript.dll   ExtendScript 2011/12/14-15:08:46   66.490082   66.490082
                             FileInfo.dll   Adobe XMP FileInfo 2012/01/17-15:11:19   66.145433   66.145433
                             filter_graph.dll   AIF   3.0   62.490293
                             hydra_filters.dll   AIF   3.0   62.490293
                             icucnv40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
                             icudt40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
                             image_compiler.dll   AIF   3.0   62.490293
                             image_flow.dll   AIF   3.0   62.490293
                             image_runtime.dll   AIF   3.0   62.490293
                             JP2KLib.dll   JP2KLib 2011/12/12-16:12:37   66.236923   66.236923
                             libeay32.dll   The OpenSSL Toolkit   0.9.8g
                             libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
                             libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   10.0
                             LogSession.dll   LogSession   2.1.2.1640
                             mediacoreif.dll   DVA Product   6.0.0
                             MPS.dll   MPS 2012/02/03-10:33:13   66.495174   66.495174
                             msvcm80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
                             msvcm90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
                             msvcp100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
                             msvcp71.dll   Microsoft® Visual Studio .NET   7.10.3077.0
                             msvcp80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
                             msvcp90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
                             msvcr100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
                             msvcr71.dll   Microsoft® Visual Studio .NET   7.10.3052.4
                             msvcr80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
                             msvcr90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
                             pdfsettings.dll   Adobe PDFSettings   1.04
                             Photoshop.dll   Adobe Photoshop CS6   CS6
                             Plugin.dll   Adobe Photoshop CS6   CS6
                             PlugPlug.dll   Adobe(R) CSXS PlugPlug Standard Dll (32 bit)   3.0.0.383
                             PSArt.dll   Adobe Photoshop CS6   CS6
                             PSViews.dll   Adobe Photoshop CS6   CS6
                             SCCore.dll   ScCore 2011/12/14-15:08:46   66.490082   66.490082
                             ScriptUIFlex.dll   ScriptUIFlex 2011/12/14-15:08:46   66.490082   66.490082
                             shfolder.dll   Microsoft(R) Windows (R) 2000 Operating System   5.50.4027.300
                             ssleay32.dll   The OpenSSL Toolkit   0.9.8g
                             tbb.dll   Intel(R) Threading Building Blocks for Windows   3, 0, 2010, 0406
                             tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   3, 0, 2010, 0406
                             TfFontMgr.dll   FontMgr   9.3.0.113
                             TfKernel.dll   Kernel   9.3.0.113
                             TFKGEOM.dll   Kernel Geom   9.3.0.113
                             TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
                             updaternotifications.dll   Adobe Updater Notifications Library   6.0.0.24 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   6.0.0.24
                             WRServices.dll   WRServices Friday January 27 2012 13:22:12   Build 0.17112   0.17112
                             wu3d.dll   U3D Writer   9.3.0.113
                          Required plug-ins:
                             3D Studio 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Accented Edges 13.0
                             Adaptive Wide Angle 13.0
                             ADM 3.11x01
                             Angled Strokes 13.0
                             Average 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Bas Relief 13.0
                             BMP 13.0
                             Camera Raw 7.0
                             Chalk & Charcoal 13.0
                             Charcoal 13.0
                             Chrome 13.0
                             Cineon 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Clouds 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Collada 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Color Halftone 13.0
                             Colored Pencil 13.0
                             CompuServe GIF 13.0
                             Conté Crayon 13.0
                             Craquelure 13.0
                             Crop and Straighten Photos 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Crop and Straighten Photos Filter 13.0
                             Crosshatch 13.0
                             Crystallize 13.0
                             Cutout 13.0
                             Dark Strokes 13.0
                             De-Interlace 13.0
                             Dicom 13.0
                             Difference Clouds 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Diffuse Glow 13.0
                             Displace 13.0
                             Dry Brush 13.0
                             Eazel Acquire 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Embed Watermark 4.0
                             Entropy 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Extrude 13.0
                             FastCore Routines 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Fibers 13.0
                             Film Grain 13.0
                             Filter Gallery 13.0
                             Flash 3D 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Fresco 13.0
                             Glass 13.0
                             Glowing Edges 13.0
                             Google Earth 4 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Grain 13.0
                             Graphic Pen 13.0
                             Halftone Pattern 13.0
                             HDRMergeUI 13.0
                             IFF Format 13.0
                             Ink Outlines 13.0
                             JPEG 2000 13.0
                             Kurtosis 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Lens Blur 13.0
                             Lens Correction 13.0
                             Lens Flare 13.0
                             Liquify 13.0
                             Matlab Operation 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Maximum 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Mean 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Measurement Core 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Median 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Mezzotint 13.0
                             Minimum 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             MMXCore Routines 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Mosaic Tiles 13.0
                             Multiprocessor Support 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Neon Glow 13.0
                             Note Paper 13.0
                             NTSC Colors 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Ocean Ripple 13.0
                             Oil Paint 13.0
                             OpenEXR 13.0
                             Paint Daubs 13.0
                             Palette Knife 13.0
                             Patchwork 13.0
                             Paths to Illustrator 13.0
                             PCX 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Photocopy 13.0
                             Photoshop 3D Engine 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Picture Package Filter 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Pinch 13.0
                             Pixar 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Plaster 13.0
                             Plastic Wrap 13.0
                             PNG 13.0
                             Pointillize 13.0
                             Polar Coordinates 13.0
                             Portable Bit Map 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Poster Edges 13.0
                             Radial Blur 13.0
                             Radiance 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Range 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Read Watermark 4.0
                             Reticulation 13.0
                             Ripple 13.0
                             Rough Pastels 13.0
                             Save for Web 13.0
                             ScriptingSupport 13.0
                             Shear 13.0
                             Skewness 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Smart Blur 13.0
                             Smudge Stick 13.0
                             Solarize 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Spatter 13.0
                             Spherize 13.0
                             Sponge 13.0
                             Sprayed Strokes 13.0
                             Stained Glass 13.0
                             Stamp 13.0
                             Standard Deviation 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Sumi-e 13.0
                             Summation 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Targa 13.0
                             Texturizer 13.0
                             Tiles 13.0
                             Torn Edges 13.0
                             Twirl 13.0
                             U3D 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Underpainting 13.0
                             Vanishing Point 13.0
                             Variance 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Variations 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Water Paper 13.0
                             Watercolor 13.0
                             Wave 13.0
                             Wavefront|OBJ 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             WIA Support 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             Wind 13.0
                             Wireless Bitmap 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                             ZigZag 13.0
                          Optional and third party plug-ins: NONE
                          Plug-ins that failed to load: NONE
                          Flash:
                             Mini Bridge
                             Kuler
                          Installed TWAIN devices: NONE
                          • 10. Re: Photoshop cs6 Problem at 3D
                            Do You meen that?
                            • 11. Re: Photoshop cs6 Problem at 3D
                              Why do you not answer my question about what license you paid for?  You make it difficult to help you.
                              • 12. Re: Photoshop cs6 Problem at 3D
                                A couple of things from that file:
                                Photoshop is not detecting your graphics card. A compatible graphics card to a minimum standard is required to run Photoshop 3D . Some info here:
                                FAQ: What features use the GPU and how do I troubleshoot GPU issues?
                                You licence type shows "Tryout version". Have you got a licence for it. Bearing in mind that Adobe no longer sell CS6 licences you may not want to spend a great deal of effort trying to get that trial version to work.
                                Dave
                                • 13. Re: Photoshop cs6 Problem at 3D
                                  Test screen NAme
                                  this a trial i didnot  Bought it;
                                  DAve;
                                  Yes I use the trial What should I do now To solve this problem?
                                  • 14. Re: Photoshop cs6 Problem at 3D
                                    davescm has raised the point: Is it worth trouble-shooting the issue when the trial will expire after 30 days anyway?
                                    On this page the tested GPUs are listed for Photoshop CC (not all of which may work out for CS6):
                                    Photoshop graphics processor (GPU) card FAQ
                                    • 15. Re: Photoshop cs6 Problem at 3D
                                      No the trial didnot  expire
                                      26 day remain
                                      • 16. Re: Photoshop cs6 Problem at 3D
                                        ....What should I do now To solve this problem?
                                        You need to look at your graphics card and the links that I and c.pfaffenbichler gave you
                                        Dave
                                        • 17. Re: Photoshop cs6 Problem at 3D
                                          Sorry, I will not help if you do not have a license. This is a 30 day trial and for me the ONLY purposes of trials are (1) to give time to solve license issues (2) to try before buying. CS6 can no longer be purchased. Some people think the purpose of trials is to study, teach, or complete small projects. I do not agree.
                                          Perhaps you are not aware that CS6 is no longer sold. The only available version is CC. This has a 7 day trial. You should read the system requirements carefully, because you need an even more powerful graphics card now. If there is any part of the system requirements you do not understand, please ask us, we are happy to help with that.
                                          • 18. Re: Photoshop cs6 Problem at 3D
                                            I did not claim it did, I stated it will.
                                            • 19. Re: Photoshop cs6 Problem at 3D
                                              DAVE;
                                              YOU mean that I should Buy a graphic card to solve this problem?
                                              • 20. Re: Photoshop cs6 Problem at 3D
                                                haithamd86457119  wrote
                                                DAVE;
                                                No - I do not mean that. Your trial will expire at then end of 30 days and you cannot now purchase a CS6 license.
                                                To get Photoshop CC (the only version now available on subscription) with 3D requires a modern card and a  64 bit operating system
                                                Photoshop system requirements
                                                Dave
                                                • 21. Re: Photoshop cs6 Problem at 3D
                                                  K .........if I Download photoshop cc I will use 3D even in a trial
                                                  or the 3D used only in the purchase even in any version
                                                  • 22. Re: Photoshop cs6 Problem at 3D
                                                    You can try downloading the Photoshop CC trial . If your system meets the requirements then all facilities will work. However - your original system info suggests you are using a 32 bit operating system. To use 3D in Photoshop CC a 64 bit operating system is required along with a suitable graphics card.
                                                    Dave
                                                    • 23. Re: Photoshop cs6 Problem at 3D
                                                      you mean that I should buy another comp. with 64 bit ?
                                                      To could use 3D in any version?
                                                      • 24. Re: Photoshop cs6 Problem at 3D
                                                        rayek.elfin Level 4
                                                        Let's bring order to all the confusion:
                                                        • You have a 32bit Windows 7 machine. This means that Photoshop can only use 2gb of ram, no matter how much you have installed.
                                                        • You only have 4GB ram total. That isn't a lot, and will limit the performance of Photoshop no matter 64bit or not.
                                                        • Your machine probably has some sort of Intel integrated graphics - which is the worst out there. Photoshop often struggles on these type of machines, and many users report issues with 3d acceleration. Even if you do get it to work, it will be slow and sluggish.
                                                        • An integrated Intel graphics chip shares your precious ram with the CPU (the computer's main processor). This is never great for performance, and this means the graphics chip requires your ram to work - eating more ram in the process. Your machine is now left with even LESS ram. On a 4gb machine this makes things worse for any memory-hungry application (like Photoshop).
                                                        • Your CPU is an Intel i5 Clarkdale that was introduced in 2010. It is still considered a high-mid range CPU, which isn't bad for Photoshop. Not great, but not bad.
                                                        • Your machine is probably at least 5 years old. That probably means you have a slow hard drive. This slows down the operation of your machine.
                                                        In a nutshell, you have THREE problems:
                                                        1. You are running a 32bit system, which is terrible for Photoshop. It can work, but it is quite limiting.
                                                        2. The integrated Intel graphics chip is problematic for any 3d work.
                                                        3. You have barely sufficient ram to run Photoshop reasonably well.
                                                        You options are:
                                                        1. Install a 64bit version of Windows and Increase the amount of ram to at least 8gb. Update to Windows 10 - it performs better than Windows 7 or at least equally well (my personal experience as well as based on others)
                                                        2. if this machine of yours is a desktop machine, purchase and install a dedicated graphics card. Anything between $100 and $200 from either Nvidia or AMD will do, as long as it has 2GB of dedicated video ram.
                                                        3. install an SSD drive, and ideally install your Windows on that. Photoshop will use this as a scratch drive, and this will also be much faster. Ideally, have a dedicated drive for Photoshop's scratch drive.
                                                        In the end, it might be less expensive to upgrade to a new machine. But no matter what, AVOID INTEL INTEGRATED GRAPHICS!!! Get a video card/chip with DEDICATED video ram!! And at least 8GB, and a 64bit Windows.
                                                        • 25. Re: Photoshop cs6 Problem at 3D
                                                          gener7 Adobe Community Professional & MVP
                                                          3D features are disabled on 32-bit platforms and on computers having less than 512MB of VRAM. Video features are not supported on 32-bit Windows systems
                                                          Photoshop System Requirements | QBS Software
                                                          • 26. Re: Photoshop cs6 Problem at 3D
                                                            Thanks for this Good information Although It was slightly depressed.
                                                            If I want to buy a new comp. What is the Specifications  that you Recommends to me
                                                            as if I want to use After effect and some programme not only photoshop.
                                                            and Is there a company that was Good that you Recommends to me.
                                                            • 27. Re: Photoshop cs6 Problem at 3D
                                                              For video and photographic work, a serious high end computer is recommended, not a consumer/office computer. It depends how many thousands of dollars you have to spend, the computer can use all your budget !
                                                              • 28. Re: Photoshop cs6 Problem at 3D
        Don't care about that ... tell me the suitable  computer for me and suitable for that things that I Told you then if i have money I will buy it If not I will save money till buy it....tell me more than one choice please then tell me who is the best of them
