• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Creating Variants of posters.
Community Beginner ,
Jun 27, 2017 Jun 27, 2017
I am currently creating around 150 posters for a company. Each poster needs to have bespoke logos and then need to be turned into a PDF. Can anyone recommend a method that would speed this job up?
Thanks!
Views
532
Translate
Translate
Report
Report
Community guidelines
community guidelines
Guru , Jun 27, 2017 Jun 27, 2017
  1. have the one illustrator file with each logo on a separate art board
  2. In indesign make a master page that has two layers, top one  called logo, below that later one called layout, in the logo layer draw a box where the logo will go
  3. repeat that master page to match the number of logos
  4. in indesign go to file, place, and make sure all is selected in the place options. indesign will now have a bush loaded with all of the artboards ( logos)
  5. place each logo into the box you made in the logo layer, apply ob
Votes
Translate
Translate
Community Expert ,
We need more information: What is a "bespoke logo" (that term not used in my circles). Are the logos created in InDesign or Illustrator? What else is on the poster? What version of InDesign? Include a screen capture of a typical poster.
Votes
Translate
Translate
Report
Report
Each logo is created in Illustrator and will mostly be around the same size. The logos sit in the same place on the poster on In-Design. I currently have a large illustrator file with all the logos on separate layers and use object layer options to change them in In-Design. The logo sits on the top right of the page.
Votes
Translate
Translate
Report
Report
Community Expert ,
And are they all the same size or do they vary?
Votes
Translate
Translate
Report
Report
Votes
Translate
Translate
Report
Report
Community Expert ,
Thank you for your replies, I meant, are the dimensions of the posters the same?
Votes
Translate
Translate
Report
Report
They are yes!
Votes
Translate
Translate
Report
Report
Guru ,
  5. place each logo into the box you made in the logo layer, apply object style to "scale to fit" (lock this layer when done)
  6. repeat step five on each other master page and apply the object style. naming the master pages so they match the name of the logo would help you here
  7. Now you can create pages, apply the page on the master that has the logo you want and on the "layout layer, make you layout. Since the layout layer is below in the stack, the layout will always be under the logo
  8. If you have to make edits to the logo, you can do in the illustrator file, update the link, and the object style will keep your art work fitting perfect within the space.
Thats how i would do it.
Votes
Translate
Translate
Report
Report
LATEST
This is certainly something I will have a look at, thank You very much
Votes
Translate
Translate
Report
Report
