• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Editing object that is in multiple frames of video using after effects
New Here ,
Jun 27, 2017 Jun 27, 2017
Hi!
I am not sure if this is even possible. But, I am editing a video and there is a close up of someone writing on a piece of paper. Is it possible to cut out of the logo at the top of this paper even though it is in multiple frames (probably not more than 3 seconds.) Thanks!
Views
289
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Sure.  If you can show us a frame of the shot, we can suggest the most efficient way to do it, too.
Votes
Translate
Translate
Report
Report
Community Expert ,
The proper technique depends entirely on the shot. After Effects is commonly used to replace things in a shot. If there is camera movement you will need to do some kind of motion tracking, or with some shots, you stabilize the motion, then replace the element, then add the motion to the replacement layer and restore the motion to the stabilized shot. If something like the persons hand moves in front of the thing you want to replace you'll need to do some rotoscoping by either duplicating one of the layers or using a track matte. These are all common tasks that are done in many different compositing apps including After Effects. In every case the technique is basically the same, match movement and add layers. Here's an example where the blank screen on a TV is replaced with some footage. This is a relatively complex problem to solve and the demonstrated technique is one of many different techniques that could have been used to fix this shot:
The tv screen would be the paper, the footage would be the fix for the logo. If you show us the shot you are working on we can suggest the most efficient way for you to create your FVX shot.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Jul 25, 2017 Jul 25, 2017
LATEST
Hi SamanthaG,
Are you still facing this problem? If not, let us know how you solved it. If so, please let us know so we can assist you further.
Kevin
Votes
Translate
Translate
Report
Report
