1 Reply Latest reply on Jun 28, 2017 10:07 AM by ryanskihead
    push.on('registration', no reaction on Android
    christianb79310854
      Hello.
      I use phonegap build to generate my app. I used the plugin one year, but now it doesnt work anymore..
      My App ID is 1046875
      Here is my config.xml Part:
      <preference name="phonegap-version" value="cli-6.5.0" />
      <plugin name="phonegap-plugin-push" source="npm">
                  <param name="SENDER_ID" value="xxx" />
              </plugin>
              <plugin name="cordova-plugin-calendar" />
              <plugin name="cordova-plugin-file" />
              <plugin name="cordova-plugin-file-transfer" />
              <plugin name="cordova-plugin-file-opener2" />
              <plugin name="cordova-plugin-inappbrowser" />
              <plugin name="cordova-plugin-network-information" />
              <plugin name="cordova-plugin-statusbar" />
              <plugin name="cordova-plugin-device" />
              <plugin name="cordova-plugin-whitelist" />
      My Sender ID from Google is correct and I use every plugin in the newest version.
      There is my complete init code, which works without any errors (test alerts are working good).
      var init = {
          initialize: function() {
              console.log('init.initialize');
              if (document.location.protocol == "file:") {
                  // file protocol indicates phonegap
                  document.addEventListener("deviceready", init.onDeviceReady, false);
              } else {
                  // browser on localhost, no phonegap
                  init.onDomReady();
          onDeviceReady: function() {
              $.support.cors = true;
              console.log('init.onDeviceReady ❤ running on DEVICE');
              init.run();
              document.addEventListener("online", onOnline, false);
              document.addEventListener("offline", onOffline, false);
              var push = PushNotification.init({
                  android: {
                      senderID: "xxx"
                  ios: {
                      alert: "true",
                      badge: true,
                      sound: 'true'
                  windows: {}
              push.on('registration', function(data) {
                  final_token = data.registrationId;
                  window.localStorage.setItem("token", final_token);
                  alert(final_token); <!-- THIS ERROR DOESNT HAPPEN
                  var os = 1;
                  if(final_token.length == 64) {
                      os = 1;
                      //Apple
                  } else {
                      os = 2;
                      //Android
                  $.ajax({
                      type: 'GET',
                      url: 'xxxxxx/api.php?rquest=set_device',
                      data:  { os: os, token: final_token },
                      crossDomain: true,
                      cache: false,
                      success: function(response) {
              push.on('notification', function(data) {
                  alert(data.title + ': ' + data.message);
              window.requestFileSystem(LocalFileSystem.PERSISTENT, 0, onFileSystemSuccess, onFail);
          onDomReady: function() {
              console.log('init.onDomReady ❤ running on DESKTOP');
              init.run();
          run: function() {
              console.log('init.run');
      init.initialize();
      Does anyone have a clue or maybe a way to debug?
      Is it possible, that any other plugin crashed?
      I red more then 20 topics and nothing helped..
      Thanks a lot!
