3 Replies Latest reply on Jun 28, 2017 11:27 AM by priscillab55713955
    Date field and day field. Day field is not accurate...Help!
    priscillab55713955 Level 1
      Hi guys, I'm currently using the following script for my day
      // get the date from the "Date1"
      var d = new Date(this.getField("Date1").value);
      if (!isNaN(d.getDay()))
      switch (d.getDay())
      case 0:
      event.value = "Sun";
      break;
      case 1:
      event.value = "Mon";
      break;
      case 2:
      event.value = "Tue";
      break;
      case 3:
      event.value = "Wed";
      break;
      case 4:
      event.value = "Thu";
      break;
      case 5:
      event.value = "Fri";
      break;
      case 6:
      event.value = "Sat";
      break;
      default:
      event.value = "";
      else
      event.value = "";
      My problem here is that for exemple.. today the 28th says TUESDAY not Wednesday... I'm extremely confused. Any ideas?
        • 1. Re: Date field and day field. Day field is not accurate...Help!
          Joel_Geraci Adobe Community Professional
          Assuming the value of your field is a string, you need to parse it into a Date object using something like the code below. Adjust for the format of your date string.
          var d= util.scand("mm/dd/yyyy", this.getField("Date1").value);
          • 2. Re: Date field and day field. Day field is not accurate...Help!
            I would set my entry date field format to one of the standard date formats and use the util.scand method as mentioned to create a date object. You can then simplify your code by using the util.printd method to format the 3 character day of the week from the date object.
            Your script with error detection could be:
            var oDateField = this.getField("Date1");
            if(oDateField == null) {
            app.alert("Error accessing Date1 field", 0,1, "Field Error");
            } else {
            if(oDateField.valueAsString == ""){
              event.value = "";
            } else {
               var oDate = util.scand("dd-mmm-yyyy", oDateField.valueAsString);
              if(oDate == null) {
               app.alert("Date conversion error " + oDateField.valueAsStirng, 0,1, "Date Conversion Error");
              } else {
               event.value = util.printd("ddd", oDate);
              } // end date object null;
            } // end field value not null;
            } // end date field not null;
            This code catches bad field names and incorrect date strings. You will need to adjust the date format for the util.scand method to match the input field's date format.
            • 3. Re: Date field and day field. Day field is not accurate...Help!
              Thanks guys finaly got this working!!! Im in no way a java scripter so this helped tremendously.
              Again thank you!
