5 Replies Latest reply on Jul 4, 2017 8:35 AM by Don Demont
    Phonegap Build Error
    Don Demont Level 1
      Can anyone guide me thru this Phonegap Build Process, I keep getting error? I also have a copy of error log report.
      See Below:
      Build
      Date: 2017-06-28 10:51:40 +0000
      PLUGIN
      OUTPUT
      Fetching
      plugin "cordova-plugin-whitelist" via npm
      Installing
      "cordova-plugin-whitelist" at "1.3.2" for android
                     This plugin is only applicable
      for versions of cordova-android greater than 4.0. If you have a previous
      platform version, you do *not* need this plugin since the whitelist will be
      built in.
      Fetching
      plugin "phonegap-plugin-push@1.10.0" via npm
      Installing
      "phonegap-plugin-push" at "1.10.0" for android
      Subproject
      Path: CordovaLib
      Fetching
      plugin "cordova-plugin-device" via npm
      Installing
      "cordova-plugin-device" at "1.1.6" for android
      Fetching
      plugin "cordova-plugin-inappbrowser" via npm
      Installing
      "cordova-plugin-inappbrowser" at "1.7.1" for android
      Fetching
      plugin "cordova-plugin-splashscreen" via npm
      Installing
      "cordova-plugin-splashscreen" at "4.0.3" for android
      Fetching
      plugin "cordova-plugin-geolocation" via npm
      Installing
      "cordova-plugin-geolocation" at "2.4.3" for android
      Fetching
      plugin "cordova-plugin-compat" via npm
      Installing
      "cordova-plugin-compat" at "1.1.0" for android
      Fetching
      plugin "cordova-plugin-network-information" via npm
      Installing
      "cordova-plugin-network-information" at "1.3.3" for android
      Fetching
      plugin "cordova-plugin-request-location-accuracy@2.2.0" via npm
      Installing
      "cordova-plugin-request-location-accuracy" at "2.2.0" for
      android
      Subproject
      Path: CordovaLib
      Fetching
      plugin "cordova-plugin-x-toast@2.6.0" via npm
      Installing
      "cordova-plugin-x-toast" at "2.6.0" for android
      Fetching
      plugin "cordova-plugin-media@3.0.0" via npm
      Installing
      "cordova-plugin-media" at "3.0.0" for android
      Fetching
      plugin "cordova-plugin-file" via npm
      Installing
      "cordova-plugin-file" at "4.3.3" for android
      Dependent
      plugin "cordova-plugin-compat" already installed on android.
      The
      Android Persistent storage location now defaults to "Internal".
      Please check this plugin's README to see if your application needs any changes
      in its config.xml.
      If
      this is a new application no changes are required.
      If
      this is an update to an existing application that did not specify an
      "AndroidPersistentFileLocation" you may need to add:
            "<preference
      name="AndroidPersistentFileLocation" value="Compatibility"
      1. to
        config.xml in order for the application to find previously stored files.
      Dependent
      Fetching
      plugin "cordova-plugin-googlemaps@1.3.9" via npm
      Installing
      "plugin.google.maps" at "1.3.9" for android
      Subproject
      Path: CordovaLib
                   In order to run this plugin, you
      need to obtain Google Maps API key for Android.
                   Visit
      https://github.com/mapsplugin/cordova-plugin-googlemaps/wiki/Installation
                   Check our release notes.
      https://github.com/wf9a5m75/phonegap-googlemaps-plugin/wiki/Release-Notes
      Fetching
      plugin "cordova-plugin-buildinfo@1.1.0" via npm
      Installing
      "cordova-plugin-buildinfo" at "1.1.0" for android
      Fetching
      plugin "cordova-plugin-vibration@2.1.4" via npm
      Installing
      "cordova-plugin-vibration" at "2.1.4" for android
      Fetching
      plugin "cordova-plugin-camera@2.4.0" via npm
      Installing
      "cordova-plugin-camera" at "2.4.0" for android
      Dependent
      Subproject
      Path: CordovaLib
      Fetching
      plugin "cordova-plugin-file-transfer@1.6.2" via npm
      Installing
      "cordova-plugin-file-transfer" at "1.6.2" for android
      Dependent
      plugin "cordova-plugin-file" already installed on android.
      Fetching
      plugin "cordova-plugin-mauron85-background-geolocation@2.2.5" via npm
      Installing
      "cordova-plugin-mauron85-background-geolocation" at "2.2.5"
      for android
      Subproject
      Path: CordovaLib
      COMPILE
      OUTPUT
      Subproject
      Path: CordovaLib
      Configuration
      on demand is an incubating feature.
      Incremental
      java compilation is an incubating feature.
      WARNING:
      Ignoring Android API artifact com.google.android:android:2.1_r1 for debug
      WARNING:
      WARNING:
      Ignoring Android API artifact com.google.android:android:2.1_r1 for release
      WARNING:
      :preBuild
      UP-TO-DATE
      :preDebugBuild
      UP-TO-DATE
      :checkDebugManifest
      :preReleaseBuild
      UP-TO-DATE
      :CordovaLib:preBuild
      UP-TO-DATE
      :CordovaLib:preDebugBuild
      UP-TO-DATE
      :CordovaLib:checkDebugManifest
      :CordovaLib:prepareDebugDependencies
      :CordovaLib:compileDebugAidl
      :CordovaLib:compileDebugNdk
      UP-TO-DATE
      :CordovaLib:compileLint
      :CordovaLib:copyDebugLint
      UP-TO-DATE
      :CordovaLib:mergeDebugShaders
      :CordovaLib:compileDebugShaders
      :CordovaLib:generateDebugAssets
      :CordovaLib:mergeDebugAssets
      :CordovaLib:mergeDebugProguardFiles
      :CordovaLib:packageDebugRenderscript
      UP-TO-DATE
      :CordovaLib:compileDebugRenderscript
      :CordovaLib:generateDebugResValues
      :CordovaLib:generateDebugResources
      :CordovaLib:packageDebugResources
      :CordovaLib:processDebugManifest
      :CordovaLib:generateDebugBuildConfig
      :CordovaLib:processDebugResources
      :CordovaLib:generateDebugSources
      :CordovaLib:incrementalDebugJavaCompilationSafeguard
      :CordovaLib:compileDebugJavaWithJavac
      - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      Note:
      Some input files use or override a deprecated API.
      Note:
      Recompile with -Xlint:deprecation for details.
      :CordovaLib:processDebugJavaRes
      UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForDebug
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForDebug
      :CordovaLib:mergeDebugJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForDebug
      :CordovaLib:transformNative_libsWithSyncJniLibsForDebug
      :CordovaLib:bundleDebug
      :CordovaLib:preReleaseBuild
      UP-TO-DATE
      :CordovaLib:checkReleaseManifest
      :CordovaLib:prepareReleaseDependencies
      :CordovaLib:compileReleaseAidl
      :CordovaLib:compileReleaseNdk
      UP-TO-DATE
      :CordovaLib:copyReleaseLint
      UP-TO-DATE
      :CordovaLib:mergeReleaseShaders
      :CordovaLib:compileReleaseShaders
      :CordovaLib:generateReleaseAssets
      :CordovaLib:mergeReleaseAssets
      :CordovaLib:mergeReleaseProguardFiles
      :CordovaLib:packageReleaseRenderscript
      UP-TO-DATE
      :CordovaLib:compileReleaseRenderscript
      :CordovaLib:generateReleaseResValues
      :CordovaLib:generateReleaseResources
      :CordovaLib:packageReleaseResources
      :CordovaLib:processReleaseManifest
      :CordovaLib:generateReleaseBuildConfig
      :CordovaLib:processReleaseResources
      :CordovaLib:generateReleaseSources
      :CordovaLib:incrementalReleaseJavaCompilationSafeguard
      :CordovaLib:compileReleaseJavaWithJavac
      Note:
      Note:
      :CordovaLib:processReleaseJavaRes
      UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForRelease
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForRelease
      :CordovaLib:mergeReleaseJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForRelease
      :CordovaLib:transformNative_libsWithSyncJniLibsForRelease
      :CordovaLib:bundleRelease
      :prepareComAndroidSupportSupportCompat2600Alpha1Library
      :prepareComAndroidSupportSupportCoreUi2600Alpha1Library
      :prepareComAndroidSupportSupportCoreUtils2600Alpha1Library
      :prepareComAndroidSupportSupportFragment2600Alpha1Library
      :prepareComAndroidSupportSupportMediaCompat2600Alpha1Library
      :prepareComAndroidSupportSupportV132340Library
      :prepareComAndroidSupportSupportV42600Alpha1Library
      :prepareComGoogleAndroidGmsPlayServicesBase1100Library
      :prepareComGoogleAndroidGmsPlayServicesBasement1100Library
      :prepareComGoogleAndroidGmsPlayServicesGcm1026Library
      :prepareComGoogleAndroidGmsPlayServicesIid1026Library
      :prepareComGoogleAndroidGmsPlayServicesLocation1100Library
      :prepareComGoogleAndroidGmsPlayServicesMaps1100Library
      :prepareComGoogleAndroidGmsPlayServicesTasks1100Library
      :prepareMeLeolinShortcutBadger1112Library
      :prepareProjectCordovaLibUnspecifiedDebugLibrary
      :compileDebugAidl
      :mergeDebugResources
      :processDebugResourcesWarning:
      AndroidManifest.xml already defines debuggable (in
      http://schemas.android.com/apk/res/android); using existing value in manifest.
      Note:
      Note:
      Note:
      Some input files use unchecked or unsafe operations.
      Note:
      Recompile with -Xlint:unchecked for details.
      :compileDebugNdk
      UP-TO-DATE
      :compileDebugSources
      :mergeDebugShaders
      :mergeDebugAssets
      :transformClassesWithDexForDebug
      FAILED
      FAILURE:
      Build failed with an exception.
      What went wrong:
      Execution
      failed for task ':transformClassesWithDexForDebug'.
      com.android.build.api.transform.TransformException:
      com.android.ide.common.process.ProcessException:
      java.util.concurrent.ExecutionException: com.android.dex.DexException: Multiple
      dex files define Lcom/google/android/gms/iid/zzc;
      Try:
      Run
      with --stacktrace option to get the stack trace. Run with --info or --debug
      option to get more log output.
      BUILD
      FAILED
      Total
      time: 6.777 secs
      Error:
      /project/gradlew: Command failed with exit code 1 Error output:
      Note:
      Note:
      Note:
      Note:
      Warning:
      Note:
      Note:
      Note:
      Note:
      FAILURE:
      What went wrong:
      Execution
      Try:
      Run
          at ChildProcess.whenDone
      (/project/cordova/node_modules/cordova-common/src/superspawn.js:169:23)
          at emitTwo (events.js:106:13)
          at ChildProcess.emit (events.js:191:7)
          at maybeClose
      (internal/child_process.js:877:16)
          at Process.ChildProcess._handle.onexit
      (internal/child_process.js:226:5)
