2 Replies Latest reply on May 23, 2006 12:04 PM by Newsgroup_User
    line(s) in dynamic field not printed
    Level 7
      hi:
      i'm having this problem on a project that already passed the deadline
      so, i'll really appreciate any suggestion/advice/idea
      MX2004
      dynamic field, no HTML, Arial, 8 points, no font embeded
      the text wraps differently in screen preview and printed page. i think
      it's normal due to differences in resolution between both devices (96
      dpi in screen and 72 in printer)
      so, having more lines in printed doc than screen, causes that sometimes
      the last(s) line isn't printed in the left column (each column is a field)
      note that the last line is moved to the right column when printed but
      the same doesn't occur with the remaining line of the precedent
      paragraph. it seems the printer driver can not split a paragraph when
      the field overflows!?
      you can take a look at for better understanding:
      http://personal.telefonica.terra.es/web/jdoe/flash/printing/line_not_printed.htm
      tia,
      jdoe
        • 1. Re: line(s) in dynamic field not printed
          DazFaz Level 1
          This is going to be a real shot in the dark.
          Try setting the text fields to pixel perfect in size. No .34 of a pixel widths or heights. Round up or down the size to the nearest whole pixel number.
          Ive had the same problem in screen before and its a bug in flash.
          • 2. Re: line(s) in dynamic field not printed
            Level 7
            i already have fields' dimensions & positions adjusted to integers as it
            improves the readibility in screen for small fonts but it doesn't seem
            to affect printing, at least regarding my problem
            thanks for your time
