4 Replies Latest reply on Jun 28, 2017 2:29 PM by pixxxel schubser
    Renaming Sub-Layer
    PrepressPro1 Level 4
      I have this tiny script to rename a Sub-layer which works the first time I use it, then it adds to the existing sub-layer name when I run it after the first time.
      var docRef = activeDocument;
      var sel = docRef.selection;
      for (var i=0; i < sel.length; i++)
           sel[i].name = "CUTTER_B" + sel[i].name;
      Any way to get this to consistently rename the sub-layer?
        • 1. Re: Renaming Sub-Layer
          pixxxel schubser MVP & Adobe Community Professional
          Hi PrepressPro1
          your code only works with page items - not with sublayers.
          Unfortunately you didn't answer one month ago.
          select by layer name
          "… is this "sublayer" really a sublayer? Or a grouped item instead? …"
          Same question again.
          For selected page items you can do something like this
          for (var i=0; i < sel.length; i++) {
              var nme = sel[i].name.replace("CUTTER_B","");
              sel[i].name = "CUTTER_B" + nme;
          Have fun
          • 2. Re: Renaming Sub-Layer
            It is an object on a sub-layer. Sorry for the hiatus in my posting. Projects get back burnered with the press of production work.  Thank you for your reply.
            • 3. Re: Renaming Sub-Layer
              Here is the sub-layer before running the scrip with the object selected.
              After the script is run.
              It still adds the name instead of replacing the name.
              • 4. Re: Renaming Sub-Layer
                That makes no difference. Same procedere as for page items
                var sel = docRef.activeLayer;
                //var sel = docRef.selection;
                //for (var i=0; i < sel.length; i++) {
                    //var nme = sel[i].name.replace("CUTTER_B","");
                    var nme = sel.name.replace("CUTTER_B","");
                    sel.name = "CUTTER_B" + nme;
                    //sel[i].name = "CUTTER_B" + nme;
                Have fun
                Or if I understood you wrong: Would you replace the whole name with Cutter_B?
                Then: sel.name = "CUTTER_B"
