After I select a white background with the magic wand, how do I replace it with transparency?
Several ways, but all require that you're not working on a background layer. Click on the lock icon on the background layer in the layer panel to change it to a normal layer.
1. Press the delete key to erase the area selected - this is not the best option.
2. Hold the alt/opt key and click on the layer mask icon at the bottom of the layer panel. This is a better way to do it, as it's non destructive. You can then edit the mask by painting with black or white.
