0 Replies Latest reply on Jun 28, 2017 1:07 PM by jack_p
    Try this if your table of contents doesn't appear in WebHelp output
    jack_p Level 1
      I'm passing on what worked for me.
      The background:
      - RoboHelp 2015, 12.0.4.460 (up to date at time of writing)
      - Small number of topics (less than 15)
      - Pushing all project files to our own server for web app deployment as a "help" button\
      - Project created using Web Application Help template (New Project > Web Application Help)
      The problem:
      - WebHelp output appears fine using the Preview function; table of contents is visible and works properly
      - WebHelp output is missing a table of contents when deployed in the app. The pane is blank.
      Initial hypothesis: Gremlins in server room!
      Revised hypothesis: Settings issue
      The solution:
      - Created a new TOC with the exact same contents as the original TOC
      - Explicitly specified the duplicate TOC as the TOC file to use for WebHelp:
          1. Open Outputs pod
          2. Right click WebHelp (Primary Output)
          3. Select Properties
          4. Select Content Categories
          5. Select Content <Default>
          6. Switch Table of Contents from <Default> to the duplicate TOC
      - Saved and re-deployed. IT WORKS! Partied like it was '99.
      I'm happy to answer any settings questions that would help narrow this solution for somebody.
      - Jack
