5 Replies Latest reply on Jul 5, 2017 2:39 PM by christianl40356136
    Startprobleme von CC2017 Maus lädt und lädt
    christianl40356136
      Seit dem letzten Update auf CC2017 lässt sich das Programm nicht mehr bedienen. Die Maus zeiget immer den ladezustand an.
      Kann mir da jemand helfen?
      Danke
        • 1. Re: Startprobleme von CC2017 Maus lädt und lädt
          srishtib8795206 Adobe Employee
          Hi christianl,
          We are sorry about the inconvenience caused.
          I would request you to describe the issue in detail. When you say "The mouse always shew the state of charge" do you mean mouse is flickering or its not working at all.
          Along with that we would also require some more information like
          Operating system(exact version of Windows or MAC)
          Exact version of InDesign.
          Does this happens on launch or while working on it?
          And please share some screenshots if possible.
          Regards
          Srishti
          • 2. Re: Startprobleme von CC2017 Maus lädt und lädt
            christianl40356136 Level 1
            Hi Srishti!
            Thanks for the answere.
            Now the Details:
            The mouse is flickering when i go up to the Task.
            Operating System Windows10 Pro 64 Bit
            InDesign CC (2017) - I cannot go to more informations because the mouse is flickering and i can´t open another window.
            It is since the last upgrade.
            It is not possible to make a screenshot of the mouse flickering because it is to fast....
            • 3. Re: Startprobleme von CC2017 Maus lädt und lädt
              In the first step it would be help that i can remove the upgrade!?
              A new Installation of the cc 2017 dosn´t help.
              Thanks.
              • 4. Re: Startprobleme von CC2017 Maus lädt und lädt
                Hi christianl,
                As per your response I come to a conclusion that mouse is flickering when you click menus on top.
                If that is the case, please close InDesign and other Adobe applications, open programs and features in control panel and check if there is an application named as web companion by Lavasoft. It is a adware manufactured by Lavasoft and creates flickering menus error in InDesign and Illustrator.
                Please uninstall this application and relaunch InDesign and check how it performs.
                To uninstall the program
                • Open control panel, select Programs and Features
                • Find Web Companion on the list, and highlight it
                • Click on the Uninstall to start the removal
                • Select to restore your web browser, and click on Remove button (if you don’t want to restore your browser, you should take the step 3 to clean the associated settings in your browsers)
                • Wait until the removing process finished, and then restart your computer
                Regards
                Srishti
                • 5. Re: Startprobleme von CC2017 Maus lädt und lädt
                  Hi Srishti!
                  Yes this was the Problem. Now it works.
                  Many thanks for the Support.
                  Regards
                  Christian
