8 Replies Latest reply on Jul 17, 2017 3:53 PM by priyanks97293812
    coldfusion 2016 install on Centos 7 apache control script
    InfoCon_Brian Level 1
      I am trying to install
      Coldfusion 2016 on a CentOS 7 Linux machine  with an Apache Web Server
      also, same problem with Coldfusion 8 on a CentOS 7 Linux machine  with an Apache Web Server
      The install script prompts for the "apache control script",
      The script does NOT exist.
      CentOS now controls the services via systemctrl
      How do I get the install to work?
      Any ideas?
      I have skipped the web server configuration part of the install.
      Apache will just displays coldfusion scripts as text.
      I have tried using wsconfig, but doesn't work. (The 'ok' button is greyed out.
      I have tried to hack the httpd.conf file, but that doesn't not work.
      Any ideas?
      I have modified the httpd.comf
      to use mod_run. still not working.
      I have extracted the mod_jrun "so" files
      as outline in this link
      https://www.apachelounge.com/viewtopic.php?p=5352
        • 1. Re: coldfusion 2016 install on Centos 7 apache control script
          priyanks97293812 Adobe Employee
          Could you please confirm, if you are using CentOS built-in Apache.
          You can run the connector command from \coldfusion2016\cfusion\runtime\bin. Use the below command.
          ./wsconfig -ws Apache -bin /usr/sbin/httpd -script /usr/sbin/apachectl -dir /etc/httpd/conf/ -v
          Priyank
          • 2. Re: coldfusion 2016 install on Centos 7 apache control script
            Could you please confirm, if above command works for you.
            Priyank
            • 3. Re: coldfusion 2016 install on Centos 7 apache control script
              sorry for the delay.
              The command sort of "worked".
              Apache will not start.  I have been trying to diagnose
              the problem.
              It appears to be an error with the mod_jk.conf file.
              Log states that apache can NOT write to a file.
              wsconfig.log
                    at com.adobe.coldfusion.connector.connectorinstaller.ApacheInstaller.restartWS(ApacheInstall er.java:595)
                      at com.adobe.coldfusion.connector.connectorinstaller.ApacheInstaller.installConnector(Apache Installer.java:324)
                      at com.adobe.coldfusion.connector.connectorinstaller.ConnectorInstaller.installConnector(Con nectorInstaller.java:432)
                      at com.adobe.coldfusion.connector.connectorinstaller.ConnectorInstaller.doIt(ConnectorInstal ler.java:372)
                      at com.adobe.coldfusion.connector.connectorinstaller.ConnectorInstaller.main(ConnectorInstal ler.java:887)
              [Thu Jul 13 11:37:29.104311 2017] [auth_digest:notice] [pid 27576] AH01757: generating secret for digest authentication ...
              [Thu Jul 13 11:37:29.106949 2017] [lbmethod_heartbeat:notice] [pid 27576] AH02282: No slotmem from mod_heartmonitor
              [Thu Jul 13 11:37:29.266555 2017] [mpm_prefork:notice] [pid 27576] AH00163: Apache/2.4.6 (CentOS) PHP/7.1.6 configured -- resuming normal operations
              [Thu Jul 13 11:37:29.266644 2017] [core:notice] [pid 27576] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
              [Thu Jul 13 11:37:35.031354 2017] [mpm_prefork:notice] [pid 27576] AH00170: caught SIGWINCH, shutting down gracefully
              [Thu Jul 13 11:38:11.892368 2017] [core:notice] [pid 27644] SELinux policy enabled; httpd running as context system_u:system_r:httpd_t:s0
              [Thu Jul 13 11:38:11.895152 2017] [suexec:notice] [pid 27644] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
              [Thu Jul 13 11:38:11.895388 2017] [jk:error] [pid 27644] (13)Permission denied: mod_jk: could not open JkLog file /opt/coldfusion2016/config/wsconfig/1/mod_jk.log
              AH00016: Configuration Failed
              • 4. Re: coldfusion 2016 install on Centos 7 apache control script
                the problem.
                wsconfig.log
                • 5. Re: coldfusion 2016 install on Centos 7 apache control script
                  I can see that SELinux is enabled in your server. Please check the ColdFusion lockdown guide for more details about the SELinux. TO fix this problem, you have to make a manual change.
                  Go to /etc/httpd/conf/ and open mod_jk.conf and comment the "JkLog file /opt/coldfusion2016/config/wsconfig/1/mod_jk.log" and start Apache. It will work.
                  Priyank
                  • 6. Re: coldfusion 2016 install on Centos 7 apache control script
                    Hello,
                    I have disabled the firewall and selinux.
                    I now get connection reset, everytime I access the page.
                    I look through the error logs and in message:
                    [core:notice] [pid 12395]  AH00052: pid 16454 exit signal Segmetation fault (11).
                    repeated over and over.
                    It seems like there is a problem with the either coldfusion or java.
                    The only thing I am programing in is Coldfusion.
                    Any ideas?
                    Brian Erickson
                    • 7. Re: coldfusion 2016 install on Centos 7 apache control script
                      Hello,
                      Any ideas?
                      Brian Erickson
                      • 8. Re: coldfusion 2016 install on Centos 7 apache control script
                        Hi Brian,
                        Can you please contact me at cf.install@adobe.com and mentioned this forum thread.
                        Priyank
