Hello,
What would be the best config with these drives for good fast 4K editing (source is h264) and exporting?
Drives:
250gb m.2 ssd for OS
250gb SSD sata III ssd
2tb 7200rpm HDD
500gb 5200rpm HDD (old, i know, but i have it from a previous build)
So, I'm thinking of:
OS and programs on the m.2
Cache AND scratch on the second sdd
Media on the harddrive
I'm thinking that putting the media on the harddrive might be the best solution (though not ideal?) since the size might be an issue for the SSD when it's also used for scratch and cache (thus storing preview files on the ssd)? I also read that pulling the media from another drive is better?
Where should I export to? The Second SSD, or the Media drive? Or just export to the older slow drive which isn't doing much?
Also: where should I keep my project files? Also on the 2tb drive? Those aren't written to as much as the cache and scratch I guess?
Thanks in advance for all the help and tips!
Moving to Hardware Forum​ for expert advice.
Puget recommends:
Primary SSD 2tb 7200rpm (good for OS and software, but takes a few sec. to boot up.)
OS & Software
Secondary NVMe/RAID 250gb m.2 (fastest for media playback)
Project files
Tertiary SSD 250gb SSD sata III ssd (cache, mostly for making room for m.2 storage)
Media Cache & Scratch
Optional Platter/SSD 500gb 5200rpm HDD (slowest for backup)
Storage & Archive
Though i'll keep my os where it is now (on the m.2)
The article states that h264 media should do fine on platters.
If i'm experiencing stutters etc... I might move the project files and media over to the scratch disk, if available size permits it?
Benny
That is a waste of your fastest drive. Put your OS/Application on the SATA III drive as once it boots it really runs from memory. Then put you project files on that fastest drive. backup and archive to hard disk drives
