8 Replies Latest reply on Jul 6, 2017 5:17 AM by adityal16589180
    PhoneGap Build Plugins not working
      For last 3 days I am struggling with PhonegapBuild Plugins
      Below are my observations
      1. All Plugins were working 3 days before (On both iOS and Android)
      2. Then I created a new provisioning profile and p12 for including APNS Notifications
      3. Deleted all the old provisioning profiles and p12 (That was a mistake I feel)
      4. After that no plugin is working on both iOS and Android Device
      5. I can see all the plugins successfully loaded on PhoneGap Build Website Plugins Tab and App Building without error.
      Devices Used:
      Iphone 6s - iOS v10.3.1
      Samsung - Android 4.1.2
      AppID: 2689758
      Here, all the javascript alerts are working from DeviceReady, except when I reach the call to Device plugin or Notification Plugin, nothing happens.
      As the same observations are there on Android device as that of iOS, I hope my provisioning profile and p12 are correct.
      Troubleshooting steps tried:
      1. I deleted the app completely and re-uploaded but still not working
      2. I checked that I have included both Cordova.js and phonegap.js at root in index.html without copying the file itself to my root folder
      <script type="text/javascript" src="cordova.js"></script>
      <script type="text/javascript" src="phonegap.js"></script>
      1. config.xml is stored at the root folder
      Below are the plugins used
      <preference name="android-build-tool" value="gradle" />
        <plugin name="cordova-plugin-calendar" source="npm" />
          <plugin name="cordova-plugin-device" source="npm" />
        <plugin name="cordova-plugin-contacts" source="nom" />
          <plugin name="cordova-plugin-globalization" source="npm" />
          <plugin name="phonegap-plugin-push" spec="1.5" source="npm">
          <param name="SENDER_ID" value=“xxxxxxxxxxxx” />
      1. Is there something that I am missing from setup perspective ?
      2. Is there a chance I am having some syntax problem in code ?
      Message was edited by: aditya lele Additional Observation Here: When I hydrate the App I am observing wierd error Message "Whoops, looks like an error occured." failed to copy Cordova.js With 2 buttons Retry and Go Back If I hit Retry then it loads again with same error. I downloaded the .ipa file and unpacked it and found an load_failed.html and load_failed.js files in it. Files stored at below link <script src="https://gist.github.com/anonymous/e41d8beeeb678824bcbca77460b2373e.js"></script>
