5 Replies Latest reply on Jul 5, 2017 11:59 AM by winterm
    Bullets and indents
    bfcreativenyc1 Level 1
      What does the cross symbol mean before the copy starts after the bullet in the attached screenshot. That a particular indent has been established? How do you change it?
      Thanks!
        • 1. Re: Bullets and indents
          winterm Level 5
          It's a special character Indent to Here
          see for the complete list:
          https://indesignsecrets.com/free-guide-to-indesign-special-characters.php
          Special chars are searchable:
          • 2. Re: Bullets and indents
            Thanks. I've noticed that even though it appears to be aligned on the left when I print it doesn't look straight on the left side. Is there any way to tweak it to make sure it looks straight on the left side?
            Thanks!
            • 3. Re: Bullets and indents
              Actually the attached the screenshot to referenceScreen Shot 2017-07-05 at 11.07.27 AM.png
              • 4. Re: Bullets and indents
                BarbBinder Adobe Community Professional
                I'm unclear why you are using it for a bullet list in the first place. It's a manual fix: someone had to add the bullet, press the space bar 5 times, and then add the Right Indent to Here character...on every paragraph. InDesign has a bullet feature which uses tabs as the separator and creates the hanging indent for you. It's quicker to apply, and quicker to edit.
                It's not too late to create a style called bullet and then find that string and replace it with the bullet style.
                As for the alignment: it's the font. I don't see an appreciable difference in the alignment when I use spaces and a Right Indent to Here character vs using a tab in the Bullets and Numbering dialog box. Do you?
                • 5. Re: Bullets and indents
                  winterm Level 5
                  Agreed to Barb - I don't see either.
                  If you're still unsatisfied with the overall look, maybe you could play with kerning: Metrics vs Optical (can be found in Control and Character palettes). However, it does nothing with the first character in a line.
                  Hey, characters aren't bricks of identical shape, so you can't expect visually perfect alignment...
