2 Replies Latest reply on May 23, 2006 2:39 AM by 2m
    Random Function
    Tolk
      Is there a simple way of producing random numbers without repitition in flash.
      I.e. I have a range of numbers I want it to choose randomly from but without withdrawing the same number twice?
      Is this a valid method (from a programming point of view): Have an array of the values then every time a position is chosen randomly on the array it is removed (placed elsewhere) so that it cannot be called twice?
      Thanks for any help!
        • 1. Re: Random
          Level 7
          Hi!
          Yeah, you could do it that way, or you could do the random process in
          advance. Below is some code that might be of use...
          function getRandom(a,b):Number {
          return Math.round(Math.random()*(b-a))+a;
          function createRandomNrList(minValue:Number, maxValue:Number):Array {
          var L:Array = new Array();
          var FinalList:Array = new Array();
          var nr = minValue;
          while (nr <= maxValue) {
          L.push(nr++);
          trace(L);
          while (L.length > 0) {
          var r = getRandom(0,L.length-1);
          FinalList.push(L.splice(r,1)[0]);
          return FinalList;
          function getRandomNumber(RandomNrList:Array):Number {
          return Number(RandomNrList.pop());
          var RandomList = createRandomNrList(20,30);
          while (RandomList.length > 0) {
          trace(getRandomNumber(RandomList));
          /Jensen/
          "Tolk" <webforumsuser@macromedia.com> wrote in message
          news:e4uh52$duh$1@forums.macromedia.com...
          > flash.
          > without
          > of
          > is
          • 2. Re: Random Function
            2m Level 2
            I don't know about valid methods from a programming point of view, but that's what I do in such a case and it has served me fine.
