Hello! I am new to video and video editing. I have seen a similar question in the forums, but I do not understand any of the terminology given to solve the problem. Novice here!
I am near the end of editing (actually re-editing) my first video project. The first time around, I downloaded (imported?) the video clips just fine, and everything edited perfectly except for one clip that lost audio halfway through. What's up with that?
This time, all the clips are downloaded/imported just fine, I am near the end of the project, and the last two clips went blackscreen after being cut. The master is fine, they went onto the timeline fine, and after being trimmed the video itself disappeared and only the audio is available. What's up with that?
Please help by using little words. 'Explain it to me like I'm a two-year old' (Denzel Washington, "Philadelphia"). A two-year old without a smart phone!
Thanks!!
Miss Parker,
This happens to me all the time. It's a memory allocation problem, and it's easy to fix. Basically, the more editing you do without 1) rendering and/or 2) saving as a video file, the more your computer has to keep track of. The following should solve the problem, and while a bit more time consuming, it'll make your job easier.
1. When your video starts disappearing, use Ctrl + Z to back up to the point where you can see all your audio/video.
2. Render your materials by hitting the Re
...Copy link to clipboard
Hard to say without knowing a lot more about your operating system, your processor, the source of your videos, the length of your individual videos, the length of your project, etc.
In other words, it's not something we can easily and consistently reproduce, so we'd need to troubleshoot your situation to find it why it's happening on your computer with your particular video.
Miss Parker,
2. Render your materials by hitting the Render button. (....be patient while rending takes place.)
3. Re-add the materials the you Ctrl + Z 'ed out. That should do the trick.
4. If rending doesn't work, go back to Step 1 (and get to the point where you can see all of your video again) and instead of clicking the Render button, click the Export & Share in the upper right corner.
5. Load the exported file, and finish your editing.
If it happens again, re-step the same process.
Ahhh, thank you, WillBeGoode! Thank you, Steve, for responding! These steps, WillBG, are easy to follow, and when I re-opened the program today all of the video appeared. Since I just learned that Adobe will not support me because I have APE 14, your responses mean a great deal to me. I am grateful.
This was not the case for me...whatsoever. I have delt with this numerous times, and it just happened AGAIN to me a couple minutes ago just as I was finishing a project. I had the video rendered, was color grading a section of the last clip I added in, zoomed out on my timeline, and surprise, no more video. However all of the audio is still there, perfectly cut and in place, just without video above it. This is beyond frustrating, it's affecting my upload schedule, and I've had enough. The clips also don't show up when you try to salvage them with auto save. I even hit command "S" every 5-10 minutes to be sure I don't lose it and it happens anyways. What do I do??
Webmaster,
You have responded to a very old topic. If the issue was common, it would be a busy topic and not dead for a couple years.
The hard truth is that this behaviour is so infrequent that it suggests hardware issues. Those are hard to solve in a forum like this.
Can you provide more detail about your system,CPU, version, memory, hard disk space, project, project settings, source video, etc.?
hmmm....is there any way to extend the memory allocation for this program?
I find that I can barely make 10 edits before video clips start disappearing.
thanks all 😃
I think something might be wrong with your configuration or resources, nb.
Hey all, I know my question is odd but really wanted to know that is it good choice to use Kinemaster Mod APK for video editing instead of Adobe After Effects or any other software? It's just a question. Thanks
Why are you asking this question in this thread on the Premiere Elements forum?
This happened to me with a proxy file. I manually replaced it with the oroiginal (non-proxy) and the problem went away.
By @yoavp94359601
You posted in the Premiere Elements forum.
