I have never had a problem with my CS6 photoshop - then out of the blue it now crashes every time I try and use the transform tool. I have completely uninstalled and reinstalled all of my adobe software and the issue still remains. I have also tried to remove all downloaded fonts ( I also ran into issues trying to reset them to the defaults so I had to go in and delete them all manually )
Any suggestions on how to fix this are greatly appreciated.
I am running windows 10 and this is the error that comes up.
Faulting application name: Photoshop.exe, version: 13.0.1.34, time stamp: 0x5269b25c
Faulting module name: atig6txx.dll, version: 22.19.162.4, time stamp: 0x58fe9f06
Exception code: 0xc0000005
Fault offset: 0x00000000000196db
Faulting process id: 0x3d4
Faulting application start time: 0x01d2f3b28188894a
Faulting application path: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Photoshop.exe
Faulting module path: C:\WINDOWS\System32\DriverStore\FileRepository\c0313676.inf_amd64_96bbc33bec5c7fae\atig6txx.dll
Report Id: 198d966f-a1f5-4362-9be0-61009c512e79
Faulting package full name:
Faulting package-relative application ID:
*Also final note the adobe forums won't load on chrome - I keep getting a system error page.
It can be a problem of video card drivers.
You can disable GPU support for now and see if it works (after restarting Photoshop).
Its looking like that might be the case. It was already disabled in photoshop when I went into the settings due a "detected error with my display driver"
Thanks for pointing me in the right direction!
I have my GPU already switched off, and it's still happening. Any other suggestions?
Translated Report (Full Report Below)
Process: Adobe Photoshop 2022 [10794]
Path: /Applications/Adobe Photoshop 2022/Adobe Photoshop 2022.app/Contents/MacOS/Adobe Photoshop 2022
Identifier: com.adobe.Photoshop
Version: 23.2.2 (23.2.2)
Code Type: X86-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2022-03-30 08:48:09.5321 -0700
OS Version: macOS 12.2.1 (21D62)
Report Version: 12
Anonymous UUID: 75B196F3-5CA5-370F-3CE2-31FB033E7D95
Sleep/Wake UUID: F7C5BD4B-C36C-4CF4-814F-03F2F9BA4620
Time Awake Since Boot: 77000 seconds
Time Since Wake: 2945 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Main Thread Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00000000000000b8
Exception Codes: 0x0000000000000001, 0x00000000000000b8
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [10794]
VM Region Info: 0xb8 is not in any region. Bytes before following region: 4410208072
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
UNUSED SPACE AT START
__TEXT 106de7000-10f063000 [130.5M] r-x/r-x SM=COW ...hotoshop 2022
Thread 0 Crashed:: Main Thread Dispatch queue: com.apple.main-thread
0 Adobe Photoshop 2022 0x10934e6e4 0x106de7000 + 39220964
1 Adobe Photoshop 2022 0x108db0a18 0x106de7000 + 33331736
2 Adobe Photoshop 2022 0x1097b3e1c 0x106de7000 + 43830812
3 Adobe Photoshop 2022 0x108489e0c 0x106de7000 + 23735820
4 Adobe Photoshop 2022 0x109a0f9b2 0x106de7000 + 46303666
5 Adobe Photoshop 2022 0x109a0f8b3 0x106de7000 + 46303411
6 Adobe Photoshop 2022 0x109a0f8b3 0x106de7000 + 46303411
7 Adobe Photoshop 2022 0x109a0f8b3 0x106de7000 + 46303411
8 Adobe Photoshop 2022 0x109a0f8b3 0x106de7000 + 46303411
9 Adobe Photoshop 2022 0x109a0f8b3 0x106de7000 + 46303411
10 Adobe Photoshop 2022 0x109a0f8b3 0x106de7000 + 46303411
11 Adobe Photoshop 2022 0x1099dd0d2 0x106de7000 + 46096594
12 Adobe Photoshop 2022 0x1099dd1a1 0x106de7000 + 46096801
13 Adobe Photoshop 2022 0x108b7d213 0x106de7000 + 31023635
14 Adobe Photoshop 2022 0x107d41d90 0x106de7000 + 16100752
15 Adobe Photoshop 2022 0x108b7db0a 0x106de7000 + 31025930
16 Adobe Photoshop 2022 0x109930c9e 0x106de7000 + 45391006
17 Adobe Photoshop 2022 0x1099da6ac 0x106de7000 + 46085804
18 Adobe Photoshop 2022 0x1099da771 0x106de7000 + 46086001
19 Adobe Photoshop 2022 0x1098d8fc1 0x106de7000 + 45031361
20 Adobe Photoshop 2022 0x1098d8ded 0x106de7000 + 45030893
21 Foundation 0x7ff81caab6d0 __NSFireTimer + 67
22 CoreFoundation 0x7ff81bc1d84f __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20
23 CoreFoundation 0x7ff81bc1d33e __CFRunLoopDoTimer + 927
24 CoreFoundation 0x7ff81bc1ce9d __CFRunLoopDoTimers + 307
25 CoreFoundation 0x7ff81bc03420 __CFRunLoopRun + 1922
26 CoreFoundation 0x7ff81bc025dd CFRunLoopRunSpecific + 563
27 HIToolbox 0x7ff82483f4f1 RunCurrentEventLoopInMode + 292
28 HIToolbox 0x7ff82483f247 ReceiveNextEventCommon + 587
29 HIToolbox 0x7ff82483efe5 _BlockUntilNextEventMatchingListInModeWithFilter + 70
30 AppKit 0x7ff81e631d88 _DPSNextEvent + 886
31 AppKit 0x7ff81e6303f4 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1411
32 Adobe Photoshop 2022 0x1098d7962 0x106de7000 + 45025634
33 AppKit 0x7ff81e622919 -[NSApplication run] + 586
34 Adobe Photoshop 2022 0x1098d8d32 0x106de7000 + 45030706
35 Adobe Photoshop 2022 0x1098db516 0x106de7000 + 45040918
36 Adobe Photoshop 2022 0x1099dc2ac 0x106de7000 + 46092972
37 Adobe Photoshop 2022 0x10c7e2ca9 0x106de7000 + 94354601
38 Adobe Photoshop 2022 0x106dec3c2 0x106de7000 + 21442
39 dyld 0x11dbe74fe start + 462
Thread 1:: Dispatch queue: com.apple.root.default-qos
0 libsystem_kernel.dylib 0x7ff81bb00aba mach_msg_trap + 10
1 libsystem_kernel.dylib 0x7ff81bb00e2b mach_msg + 59
2 CoreFoundation 0x7ff81bc04af2 __CFRunLoopServiceMachPort + 319
3 CoreFoundation 0x7ff81bc031cb __CFRunLoopRun + 1325
4 CoreFoundation 0x7ff81bc025dd CFRunLoopRunSpecific + 563
5 CoreFoundation 0x7ff81bc8a62e CFRunLoopRun + 40
6 libdispatch.dylib 0x7ff81b985ad8 _dispatch_call_block_and_release + 12
7 libdispatch.dylib 0x7ff81b986cc9 _dispatch_client_callout + 8
8 libdispatch.dylib 0x7ff81b9893bf _dispatch_queue_override_invoke + 801
9 libdispatch.dylib 0x7ff81b9963ba _dispatch_root_queue_drain + 343
10 libdispatch.dylib 0x7ff81b996b5a _dispatch_worker_thread2 + 160
11 libsystem_pthread.dylib 0x7ff81bb3a02e _pthread_wqthread + 256
12 libsystem_pthread.dylib 0x7ff81bb38ffb start_wqthread + 15
Thread 2:: HB Kill Signal Processor
0 libsystem_kernel.dylib 0x7ff81bb0545e kevent + 10
1 Adobe Photoshop 2022 0x10c7dff27 0x106de7000 + 94342951
2 Adobe Photoshop 2022 0x10c7e027c 0x106de7000 + 94343804
3 libsystem_pthread.dylib 0x7ff81bb3d4f4 _pthread_start + 125
4 libsystem_pthread.dylib 0x7ff81bb3900f thread_start + 15
Thread 3:: com.adobe.ngl-ProcessNglIngestEvents-0x700007c16000
0 libsystem_kernel.dylib 0x7ff81bb03506 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x7ff81bb3da69 _pthread_cond_wait + 1224
2 libc++.1.dylib 0x7ff81ba9cf53 std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >) + 93
3 Adobe Photoshop 2022 0x10b9446e8 0x106de7000 + 79025896
4 Adobe Photoshop 2022 0x10b8b8227 0x106de7000 + 78451239
5 Adobe Photoshop 2022 0x10b8b817a 0x106de7000 + 78451066
6 Adobe Photoshop 2022 0x10b8b839e 0x106de7000 + 78451614
7 libsystem_pthread.dylib 0x7ff81bb3d4f4 _pthread_start + 125
8 libsystem_pthread.dylib 0x7ff81bb3900f thread_start + 15
Thread 4:: com.adobe.ngl-MonitorSuccessEventsThread-0x700007c99000
3 Adobe Photoshop 2022 0x10b947aa0 0x106de7000 + 79039136
Thread 5:: VM IO Processor
2 Adobe Photoshop 2022 0x1098a2a9b 0x106de7000 + 44808859
3 Adobe Photoshop 2022 0x1098a21cb 0x106de7000 + 44806603
4 Adobe Photoshop 2022 0x1098a2338 0x106de7000 + 44806968
5 libsystem_pthread.dylib 0x7ff81bb3d4f4 _pthread_start + 125
6 libsystem_pthread.dylib 0x7ff81bb3900f thread_start + 15
Thread 6:: com.adobe.ngl-RecurringLogPosting-0x700007b93000
3 Adobe Photoshop 2022 0x10b8a350e 0x106de7000 + 78365966
Thread 7:: VulcanMsgRecv
0 libsystem_kernel.dylib 0x7ff81bb04022 __recvfrom + 10
1 VulcanMessage5.dylib 0x11192a8c0 0x1118b5000 + 481472
2 VulcanMessage5.dylib 0x11192d824 0x1118b5000 + 493604
3 VulcanMessage5.dylib 0x1119048fd 0x1118b5000 + 325885
4 VulcanMessage5.dylib 0x1118fe96f 0x1118b5000 + 301423
5 VulcanMessage5.dylib 0x11190052e 0x1118b5000 + 308526
6 VulcanMessage5.dylib 0x111900149 0x1118b5000 + 307529
7 VulcanMessage5.dylib 0x11190627b 0x1118b5000 + 332411
8 VulcanMessage5.dylib 0x111905e81 0x1118b5000 + 331393
9 VulcanMessage5.dylib 0x111905d9d 0x1118b5000 + 331165
10 VulcanMessage5.dylib 0x1118c3334 0x1118b5000 + 58164
11 VulcanMessage5.dylib 0x1119160e1 0x1118b5000 + 397537
12 VulcanMessage5.dylib 0x1119343c9 0x1118b5000 + 521161
13 libsystem_pthread.dylib 0x7ff81bb3d4f4 _pthread_start + 125
14 libsystem_pthread.dylib 0x7ff81bb3900f thread_start + 15
Thread 8:: com.apple.NSURLConnectionLoader
5 CFNetwork 0x7ff8207ff6b2 0x7ff8205b0000 + 2422450
6 Foundation 0x7ff81ca622d9 __NSThread__start__ + 1025
Thread 9:: com.adobe.ngl-RecurringProfileAndAuthStateCheck-0x700008134000
3 Adobe Photoshop 2022 0x10b8a675f 0x106de7000 + 78378847
Thread 10:: com.adobe.ngl-AuthStatusFileWatcher-0x7000081b7000
6 Adobe Photoshop 2022 0x10b9135ef 0x106de7000 + 78824943
7 Adobe Photoshop 2022 0x10b882c13 0x106de7000 + 78232595
8 Adobe Photoshop 2022 0x10b8b8227 0x106de7000 + 78451239
9 Adobe Photoshop 2022 0x10b8b817a 0x106de7000 + 78451066
10 Adobe Photoshop 2022 0x10b8b839e 0x106de7000 + 78451614
11 libsystem_pthread.dylib 0x7ff81bb3d4f4 _pthread_start + 125
12 libsystem_pthread.dylib 0x7ff81bb3900f thread_start + 15
Thread 11:: PS SAM Task Queue
2 libc++.1.dylib 0x7ff81ba9cec2 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18
3 Adobe Photoshop 2022 0x10a813e6b 0x106de7000 + 61001323
4 Adobe Photoshop 2022 0x10a812aad 0x106de7000 + 60996269
5 Adobe Photoshop 2022 0x10c716f68 0x106de7000 + 93519720
6 libsystem_pthread.dylib 0x7ff81bb3d4f4 _pthread_start + 125
7 libsystem_pthread.dylib 0x7ff81bb3900f thread_start + 15
Thread 12:: UXP Database Thread
3 dynamic-torqnative 0x1223d46ec 0x122313000 + 792300
4 dynamic-torqnative 0x1223d3e21 0x122313000 + 790049
5 dynamic-torqnative 0x1223d77d2 0x122313000 + 804818
Thread 13:: LibUV Loop Thread
1 dynamic-torqnative 0x1233be5ee 0x122313000 + 17479150
2 dynamic-torqnative 0x1233c0c45 uv_run + 359
3 dynamic-torqnative 0x1236328c5 0x122313000 + 20052165
4 dynamic-torqnative 0x123632b13 0x122313000 + 20052755
Thread 14:: Third Party - UXP JavaScript Thread
Thread 15:: First Party - UXP JavaScript Thread
3 dynamic-torqnative 0x1224042a3 0x122313000 + 987811
4 dynamic-torqnative 0x1223d46c6 0x122313000 + 792262
5 dynamic-torqnative 0x1223d3e21 0x122313000 + 790049
6 dynamic-torqnative 0x1223d77d2 0x122313000 + 804818
Thread 16:: UI Worker 1
3 Adobe Photoshop 2022 0x108367630 0x106de7000 + 22545968
4 Adobe Photoshop 2022 0x1083671a9 0x106de7000 + 22544809
5 Adobe Photoshop 2022 0x108368a3e 0x106de7000 + 22551102
Thread 17:: V8 DefaultWorke
2 dynamic-torqnative 0x12366a214 0x122313000 + 20279828
3 dynamic-torqnative 0x123669850 0x122313000 + 20277328
4 dynamic-torqnative 0x123660a17 0x122313000 + 20240919
Thread 18:: V8 DefaultWorke
Thread 19:: V8 DefaultWorke
Thread 20:: V8 DefaultWorke
Thread 21:: V8 DefaultWorke
Thread 22:: V8 DefaultWorke
Thread 23:: V8 DefaultWorke
Thread 24:: V8 DefaultWorke
Thread 25:: V8 DefaultWorke
Thread 26:: V8 DefaultWorke
Thread 27:: V8 DefaultWorke
Thread 28:: V8 DefaultWorke
Thread 29:: V8 DefaultWorke
Thread 30:: V8 DefaultWorke
Thread 31:: V8 DefaultWorke
Thread 32:
2 LogSession 0x11185e8ee 0x11171e000 + 1313006
3 LogSession 0x1117e646d 0x11171e000 + 820333
4 LogSession 0x1117e0f16 0x11171e000 + 798486
5 LogSession 0x11185dce7 0x11171e000 + 1309927
Thread 33:
3 LogSession 0x111817949 0x11171e000 + 1022281
4 LogSession 0x1118174aa 0x11171e000 + 1021098
Thread 34:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x7ff81bb08e4a __select + 10
1 CoreFoundation 0x7ff81bc2becd __CFSocketManager + 630
2 libsystem_pthread.dylib 0x7ff81bb3d4f4 _pthread_start + 125
3 libsystem_pthread.dylib 0x7ff81bb3900f thread_start + 15
Thread 35:
2 dynamic-torqnative 0x1233cacfe uv_cond_wait + 9
3 dynamic-torqnative 0x1233ba178 0x122313000 + 17461624
4 libsystem_pthread.dylib 0x7ff81bb3d4f4 _pthread_start + 125
5 libsystem_pthread.dylib 0x7ff81bb3900f thread_start + 15
Thread 36:
Thread 37:
Thread 38:
Thread 39:: General Background Service
Thread 40:: LEC-IngestPoll
3 Adobe Photoshop 2022 0x1099f743b 0x106de7000 + 46203963
4 Adobe Photoshop 2022 0x10701f6b1 0x106de7000 + 2328241
5 Adobe Photoshop 2022 0x106ff808e 0x106de7000 + 2166926
6 Adobe Photoshop 2022 0x106ff9401 0x106de7000 + 2171905
Thread 41:: ACPLSDKWorkerThread2
0 libsystem_kernel.dylib 0x7ff81bb033da __semwait_signal + 10
1 libsystem_c.dylib 0x7ff81ba188a9 nanosleep + 196
2 libc++.1.dylib 0x7ff81baa6c11 std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > const&) + 73
3 Adobe Photoshop 2022 0x10a3891b8 0x106de7000 + 56238520
4 Adobe Photoshop 2022 0x10a38a3be 0x106de7000 + 56243134
Thread 42:
2 SelectivePalette 0x1272d0b38 gpr_cv_wait + 120
3 SelectivePalette 0x127175aa5 grpc_impl::Server::Wait() + 133
4 SelectivePalette 0x126ee3247 RunServer() + 1207
5 SelectivePalette 0x126eed1a8 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (*)()> >(void*) + 40
Thread 43:: default-executor
3 SelectivePalette 0x1270ed77a grpc_core::Executor::ThreadMain(void*) + 234
4 SelectivePalette 0x1272d309c grpc_core::(anonymous namespace)::ThreadInternalsPosix::ThreadInternalsPosix(char const*, void (*)(void*), void*, bool*, grpc_core::Thread::Options const&)::'lambda'(void*)::__invoke(void*) + 156
Thread 44:: resolver-executor
Thread 45:: grpc_global_timer
2 SelectivePalette 0x1272d0b26 gpr_cv_wait + 102
3 SelectivePalette 0x1270ffb91 timer_thread(void*) + 881
Thread 46:: grpc_health_check_service
3 SelectivePalette 0x1271264d0 (anonymous namespace)::non_polling_poller_work(grpc_pollset*, grpc_pollset_worker**, long long) + 208
4 SelectivePalette 0x127124c91 cq_next(grpc_completion_queue*, gpr_timespec, void*) + 497
5 SelectivePalette 0x127166781 grpc_impl::CompletionQueue::AsyncNextInternal(void**, bool*, gpr_timespec) + 49
6 SelectivePalette 0x127168521 grpc::DefaultHealthCheckService::HealthCheckServiceImpl::Serve(void*) + 97
7 SelectivePalette 0x1272d309c grpc_core::(anonymous namespace)::ThreadInternalsPosix::ThreadInternalsPosix(char const*, void (*)(void*), void*, bool*, grpc_core::Thread::Options const&)::'lambda'(void*)::__invoke(void*) + 156
8 libsystem_pthread.dylib 0x7ff81bb3d4f4 _pthread_start + 125
9 libsystem_pthread.dylib 0x7ff81bb3900f thread_start + 15
Thread 47:: grpcpp_sync_server
0 libsystem_kernel.dylib 0x7ff81bb071ae poll + 10
1 SelectivePalette 0x1270ea831 pollset_work(grpc_pollset*, grpc_pollset_worker**, long long) + 1297
2 SelectivePalette 0x127124c91 cq_next(grpc_completion_queue*, gpr_timespec, void*) + 497
3 SelectivePalette 0x127166781 grpc_impl::CompletionQueue::AsyncNextInternal(void**, bool*, gpr_timespec) + 49
4 SelectivePalette 0x127176dfa grpc_impl::Server::SyncRequestThreadManager::PollForWork(void**, bool*) + 106
5 SelectivePalette 0x127181d3f grpc::ThreadManager::MainWorkLoop() + 447
6 SelectivePalette 0x127182891 grpc::ThreadManager::WorkerThread::WorkerThread(grpc::ThreadManager*)::$_0::__invoke(void*) + 17
Thread 48:: BridgeTalk
2 ScriptingSupport 0x12cadb8b8 ScObjects::Thread::wait(unsigned int) + 56
3 ScriptingSupport 0x12cabdd52 ScObjects::BridgeTalkThread::run() + 290
4 ScriptingSupport 0x12cadb467 ScObjects::Thread::go(void*) + 151
Thread 49:: TaskSchedulerServiceThread
1 Chromium Embedded Framework 0x30f2f9ad9 0x30cd19000 + 39717593
2 Chromium Embedded Framework 0x30f2f75bd 0x30cd19000 + 39708093
3 Chromium Embedded Framework 0x30f2f67be 0x30cd19000 + 39704510
4 Chromium Embedded Framework 0x30f277ad5 0x30cd19000 + 39185109
5 Chromium Embedded Framework 0x30f2abe84 0x30cd19000 + 39399044
6 Chromium Embedded Framework 0x30f2be316 0x30cd19000 + 39473942
7 Chromium Embedded Framework 0x30f2ee467 0x30cd19000 + 39670887
Thread 50:: TaskSchedulerForegroundWorker
2 Chromium Embedded Framework 0x30f28e480 0x30cd19000 + 39277696
3 Chromium Embedded Framework 0x30f28e591 0x30cd19000 + 39277969
4 Chromium Embedded Framework 0x30f2a74f8 0x30cd19000 + 39380216
5 Chromium Embedded Framework 0x30f2a7d83 0x30cd19000 + 39382403
6 Chromium Embedded Framework 0x30f2a7a34 0x30cd19000 + 39381556
Thread 51:: TaskSchedulerForegroundBlockingWorker
Thread 52:: TaskSchedulerBackgroundWorker
6 Chromium Embedded Framework 0x30f2a79a4 0x30cd19000 + 39381412
Thread 53:: Chrome_IOThread
5 Chromium Embedded Framework 0x30e26fa44 0x30cd19000 + 22374980
Thread 54:: NetworkConfigWatcher
5 Foundation 0x7ff81ca6966e -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 216
6 Chromium Embedded Framework 0x30f256a80 0x30cd19000 + 39049856
7 Chromium Embedded Framework 0x30f2559e7 0x30cd19000 + 39045607
8 Chromium Embedded Framework 0x30f277ad5 0x30cd19000 + 39185109
9 Chromium Embedded Framework 0x30f2be316 0x30cd19000 + 39473942
10 Chromium Embedded Framework 0x30f2ee467 0x30cd19000 + 39670887
Thread 55:: DnsConfigService
3 Chromium Embedded Framework 0x30f2f67d7 0x30cd19000 + 39704535
5 Chromium Embedded Framework 0x30f2be316 0x30cd19000 + 39473942
6 Chromium Embedded Framework 0x30f2ee467 0x30cd19000 + 39670887
Thread 56:: TaskSchedulerBackgroundBlockingWorker
Thread 57:: CompositorTileWorker1/174851
2 Chromium Embedded Framework 0x30f2ed6d5 0x30cd19000 + 39667413
3 Chromium Embedded Framework 0x310277178 0x30cd19000 + 55959928
4 Chromium Embedded Framework 0x30f2bd774 0x30cd19000 + 39470964
5 Chromium Embedded Framework 0x30f2ee467 0x30cd19000 + 39670887
Thread 58:: AudioThread
3 Chromium Embedded Framework 0x30f28e33f 0x30cd19000 + 39277375
4 Chromium Embedded Framework 0x30f25589d 0x30cd19000 + 39045277
5 Chromium Embedded Framework 0x30f277ad5 0x30cd19000 + 39185109
Thread 59:: TaskSchedulerSingleThreadForegroundBlocking0
4 Chromium Embedded Framework 0x30f2a74ea 0x30cd19000 + 39380202
6 Chromium Embedded Framework 0x30f2a7a94 0x30cd19000 + 39381652
Thread 60:: TaskSchedulerSingleThreadBackgroundBlocking1
6 Chromium Embedded Framework 0x30f2a7a04 0x30cd19000 + 39381508
Thread 61:: TaskSchedulerSingleThreadSharedBackgroundBlocking2
5 Chromium Embedded Framework 0x30f2a7b22 0x30cd19000 + 39381794
6 Chromium Embedded Framework 0x30f2a79d4 0x30cd19000 + 39381460
Thread 62:: TaskSchedulerSingleThreadSharedForegroundBlocking3
6 Chromium Embedded Framework 0x30f2a7a64 0x30cd19000 + 39381604
Thread 63:: NetworkConfigWatcher
Thread 64:: CacheThread_BlockFile
Thread 65:: grpcpp_sync_server
Thread 66:: com.apple.NSEventThread
5 AppKit 0x7ff81e79ffd8 _NSEventThread + 132
Thread 67:: grpc_global_timer
Thread 68:: cr_scratch
3 Camera Raw 0x322aacc6b 0x321c5a000 + 15019115
4 Camera Raw 0x32277d8f1 0x321c5a000 + 11679985
Thread 69:: BGThread (AMD Radeon Pro Vega 48)
3 Camera Raw 0x322b618f3 0x321c5a000 + 15759603
Thread 70:
0 libsystem_kernel.dylib 0x7ff81bb00af6 semaphore_wait_trap + 10
1 libtbb.dylib 0x1106dd698 0x1106c6000 + 95896
2 libtbb.dylib 0x1106dd539 0x1106c6000 + 95545
Thread 71:
Thread 72:
Thread 73:
Thread 74:
Thread 75:
Thread 76:
Thread 77:
Thread 78:
Thread 79:
Thread 80:
Thread 81:
Thread 82:
Thread 83:
Thread 84:
Thread 85:: UI Worker 2
Thread 86:: Background DOM Loader Thread - UXP JavaScript Thread
Thread 87:: UI Worker 3
Thread 88:: UI Worker 4
Thread 89:: com.apple.CFStream.LegacyThread
5 CoreFoundation 0x7ff81bc802e4 _legacyStreamRunLoop_workThread + 251
Thread 90:
5 Foundation 0x7ff81cb5feda -[NSConnection run] + 126
Thread 91:: CEPMonitorThread
5 Foundation 0x7ff81caf5bad -[NSConcreteTask waitUntilExit] + 334
6 PlugPlugOwl 0x110ac003c 0x1109ec000 + 868412
7 Foundation 0x7ff81ca622d9 __NSThread__start__ + 1025
Thread 92:
3 dvacore 0x37ee6fcfb 0x37ebb5000 + 2862331
4 dvacore 0x37ee6f5fe 0x37ebb5000 + 2860542
5 dvacore 0x37ee6d54c 0x37ebb5000 + 2852172
6 dvacore 0x37ee6a12d 0x37ebb5000 + 2838829
7 boost_threads 0x371643d48 0x371642000 + 7496
Thread 93:
1 dvatransport 0x37187c146 0x37185a000 + 139590
2 dvatransport 0x37187bd35 0x37185a000 + 138549
3 dvatransport 0x37187b9e1 0x37185a000 + 137697
4 dvatransport 0x371871d0c SkyConnectionEnv::MainLoop() + 172
5 dvatransport 0x3718715a9 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
6 boost_threads 0x371643d48 0x371642000 + 7496
Thread 94:
2 dvatransport 0x37187be06 0x37185a000 + 138758
4 dvatransport 0x371887c1f 0x37185a000 + 187423
5 dvacore 0x37ed22210 boost_asio_detail_posix_thread_function + 16
Thread 95:
Thread 96:
Thread 97:
Thread 98:: JavaScriptCore bmalloc scavenger
3 JavaScriptCore 0x7ff835256695 void std::__1::condition_variable_any::wait<std::__1::unique_lock<bmalloc::Mutex> >(std::__1::unique_lock<bmalloc::Mutex>&) + 85
4 JavaScriptCore 0x7ff83525ae3b bmalloc::Scavenger::threadRunLoop() + 443
5 JavaScriptCore 0x7ff83525a969 bmalloc::Scavenger::threadEntryPoint(bmalloc::Scavenger*) + 9
6 JavaScriptCore 0x7ff83525c017 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (*)(bmalloc::Scavenger*), bmalloc::Scavenger*> >(void*) + 39
Thread 99:: com.apple.coreanimation.render-server
2 QuartzCore 0x7ff822cc565e CA::Render::Server::server_thread(void*) + 493
3 QuartzCore 0x7ff822cc5461 thread_fun(void*) + 25
Thread 100:
1 dynamic-torqnative 0x122567cff 0x122313000 + 2444543
2 dynamic-torqnative 0x12256a14a 0x122313000 + 2453834
3 dynamic-torqnative 0x1225646eb 0x122313000 + 2430699
4 dynamic-torqnative 0x122564603 0x122313000 + 2430467
5 dynamic-torqnative 0x12255aadc 0x122313000 + 2390748
Thread 101:
2 dynamic-torqnative 0x122572bee 0x122313000 + 2489326
3 dynamic-torqnative 0x12256a10c 0x122313000 + 2453772
4 dynamic-torqnative 0x1225646eb 0x122313000 + 2430699
5 dynamic-torqnative 0x122564603 0x122313000 + 2430467
6 dynamic-torqnative 0x122568674 0x122313000 + 2446964
Thread 102:: Font Initialization
Thread 103:: DeepFont
Thread 104:
Thread 105:
Thread 106:
Thread 107:
Thread 108:
Thread 109:
Thread 110:
Thread 111:
Thread 112:
Thread 113:
Thread 114:
Thread 115:
Thread 116:: Background Save
2 Adobe Photoshop 2022 0x109302afb 0x106de7000 + 38910715
3 Adobe Photoshop 2022 0x10897226c 0x106de7000 + 28881516
4 Adobe Photoshop 2022 0x108971cc9 0x106de7000 + 28880073
5 Adobe Photoshop 2022 0x10aee0c78 0x106de7000 + 68131960
Thread 117:: AMCP Logging Spool
1 caulk 0x7ff8245c71c0 caulk::mach::semaphore::wait_or_error() + 16
2 caulk 0x7ff8245ae08a caulk::concurrent::details::worker_thread::run() + 36
3 caulk 0x7ff8245add4e void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*) + 41
Thread 118:
0 libsystem_pthread.dylib 0x7ff81bb38fec start_wqthread + 0
Thread 119:
Thread 120:: com.apple.coreaudio.AQClient
5 AudioToolbox 0x7ff8294d20bd CADeprecated::GenericRunLoopThread::Entry(void*) + 157
6 libAudioToolboxUtility.dylib 0x7ff828452067 CADeprecated::CAPThread::Entry(CADeprecated::CAPThread*) + 77
Thread 121:: com.apple.coremedia.imagequeue.coreanimation.common
2 CoreMedia 0x7ff8245ee180 WaitOnCondition + 11
3 CoreMedia 0x7ff8245d9bc7 FigSemaphoreWaitRelative + 145
4 MediaToolbox 0x7ff828adfa55 0x7ff8287bd000 + 3287637
5 CoreMedia 0x7ff8245eccd0 figThreadMain + 276
Thread 122:
Thread 123:
Thread 124:
Thread 125:
Thread 126:
Thread 127:
Thread 128:
Thread 129:
Thread 130:
Thread 131:
Thread 132:
Thread 133:
Thread 134:
Thread 135:
Thread 136:
Thread 137:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x00000000ffffffff rbx: 0x00000000000000b8 rcx: 0x0000000000000005 rdx: 0x0000000000000000
rdi: 0x00000000000000b8 rsi: 0x0000000000000001 rbp: 0x00007ff7b9115210 rsp: 0x00007ff7b9115210
r8: 0x0000000000000000 r9: 0x0000000000000000 r10: 0x000000010f528f70 r11: 0x00000001098c5dc0
r12: 0x000000010f924130 r13: 0x000000010f52f218 r14: 0x0000000000000000 r15: 0x00007f971fab1c00
rip: 0x000000010934e6e4 rfl: 0x0000000000010206 cr2: 0x00000000000000b8
Logical CPU: 6
Error Code: 0x00000004 (no mapping for user data read)
Trap Number: 14
Thread 0 instruction stream:
89 fb 48 8b 06 4c 8d 75-d0 4c 89 f7 ff 90 88 00 ..H..L.u.L......
00 00 66 0f 70 45 d0 4e-66 0f 70 4d e0 4e f3 0f ..f.pE.Nf.pM.N..
7f 03 f3 0f 7f 4b 10 4c-89 f7 e8 4d e9 3d 03 48 .....K.L...M.=.H
89 d8 48 83 c4 20 5b 41-5e 5d c3 48 8d 3d 0a 2c ..H.. [A^].H.=.,
0d 04 48 89 fe ba d3 01-00 00 e8 0d bf 6a 00 66 ..H..........j.f
2e 0f 1f 84 00 00 00 00-00 0f 1f 00 55 48 89 e5 ............UH..
[48]8b 3f 48 85 ff 74 07-48 8b 07 5d ff 60 20 31 H.?H..t.H..].` 1 <==
c0 5d c3 66 0f 1f 84 00-00 00 00 00 55 48 89 e5 .].f........UH..
53 50 48 89 fb 48 8b 3f-48 85 ff 74 18 48 8b 07 SPH..H.?H..t.H..
ff 50 28 84 c0 74 0e 83-7b 18 16 0f 95 c0 48 83 .P(..t..{.....H.
c4 08 5b 5d c3 31 c0 48-83 c4 08 5b 5d c3 66 2e ..[].1.H...[].f.
0f 1f 84 00 00 00 00 00-0f 1f 40 00 55 48 89 e5 ..........@.UH..
Binary Images:
0x106de7000 - 0x10f062fff com.adobe.Photoshop (23.2.2) <bc21ebd7-3d85-3f23-953f-2a5df8f6d4eb> /Applications/Adobe Photoshop 2022/Adobe Photoshop 2022.app/Contents/MacOS/Adobe Photoshop 2022
0x7ff81ca0a000 - 0x7ff81cdc4fff com.apple.Foundation (6.9) <bf00b016-c645-3574-b74f-4386750fb009> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7ff81bb84000 - 0x7ff81c086fff com.apple.CoreFoundation (6.9) <9b112884-be6c-3c7f-9a2a-a47c491105db> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7ff82480d000 - 0x7ff824b04fff com.apple.HIToolbox (2.1.1) <c538aa78-7afd-3f8a-8fdb-1fc2acde6b3f> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7ff81e5f3000 - 0x7ff81f484fff com.apple.AppKit (6.9) <9d3ab204-4858-3120-b002-5c38b02edec4> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x11dbe2000 - 0x11dc4dfff dyld (*) <7de33963-bbc5-3996-ba6e-f1d562c17c95> /usr/lib/dyld
0x7ff81bb00000 - 0x7ff81bb36fff libsystem_kernel.dylib (*) <c1d58a50-5a4d-3bcb-a1fc-ec0902ce34d3> /usr/lib/system/libsystem_kernel.dylib
0x7ff81b984000 - 0x7ff81b9cafff libdispatch.dylib (*) <67d92c93-aa68-34c2-964b-23e8a8d32098> /usr/lib/system/libdispatch.dylib
0x7ff81bb37000 - 0x7ff81bb42fff libsystem_pthread.dylib (*) <ee564342-d8f2-396d-b642-40092cf34d82> /usr/lib/system/libsystem_pthread.dylib
0x7ff81ba91000 - 0x7ff81bae9fff libc++.1.dylib (*) <fa3f989d-0003-37ef-a495-36be29bc1552> /usr/lib/libc++.1.dylib
0x1118b5000 - 0x111940fff VulcanMessage5.dylib (*) <d5a56ee4-f4cc-380f-b893-76b9d2f58da0> /Applications/Adobe Photoshop 2022/Adobe Photoshop 2022.app/Contents/Frameworks/VulcanMessage5.dylib
0x7ff8205b0000 - 0x7ff820a46fff com.apple.CFNetwork (1329) <3612e3e1-9739-39b2-a97d-9b75862a53fd> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x122313000 - 0x124bb2fff com.adobe.uxp.macos.alpaca.v8 (local) <a8f0cb52-c89a-3fb1-93fe-c31a3e14f257> /Applications/Adobe Photoshop 2022/Adobe Photoshop 2022.app/Contents/Frameworks/dynamic-torqnative.framework/Versions/A/dynamic-torqnative
0x11171e000 - 0x11188dfff com.adobe.headlights.LogSessionFramework (*) <96cb4041-f593-393f-a5ed-3e0e00a1f882> /Applications/Adobe Photoshop 2022/Adobe Photoshop 2022.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
0x7ff81ba08000 - 0x7ff81ba90fff libsystem_c.dylib (*) <4b160c81-ec52-3243-aaba-49f719bbf617> /usr/lib/system/libsystem_c.dylib
0x126edf000 - 0x1273cdfff com.dxo.selectivetool (5.0.3) <a23bdae0-5e10-340d-8e9b-67c18e5203b2> /Library/Application Support/Adobe/*/SelectivePalette.plugin/Contents/MacOS/SelectivePalette
0x12c770000 - 0x12cbabfff com.adobe.PSAutomate (23.2) <2c07e7f5-d5b5-3a82-81b5-f75527f5174b> /Applications/Adobe Photoshop 2022/Adobe Photoshop 2022.app/Contents/PlugIns/Required/Extensions/ScriptingSupport.plugin/Contents/MacOS/ScriptingSupport
0x30cd19000 - 0x313edbfff org.chromium.ContentShell.framework (3.3626.1882.0) <0e0cf0df-f3bd-3ea0-aeeb-f8f6ec8157d6> /Applications/Adobe Photoshop 2022/Adobe Photoshop 2022.app/Contents/PlugIns/Required/Spaces/Frameworks/Chromium Embedded Framework.framework/Chromium Embedded Framework
0x321c5a000 - 0x327f35fff com.adobe.CameraRaw (14.2 (1028)) <cc71553d-7d17-3922-a50d-74796044d059> /Library/Application Support/Adobe/*/Camera Raw.plugin/Contents/MacOS/Camera Raw
0x1106c6000 - 0x1106e5fff libtbb.dylib (*) <a1114b8f-f099-3681-8884-1526eaf5dfc2> /Applications/Adobe Photoshop 2022/Adobe Photoshop 2022.app/Contents/Frameworks/libtbb.dylib
0x1109ec000 - 0x110cebfff com.adobe.PlugPlugOwl (11.2.0.100) <a569e456-406d-3152-affa-be229464b454> /Applications/Adobe Photoshop 2022/Adobe Photoshop 2022.app/Contents/Frameworks/PlugPlugOwl.framework/Versions/A/PlugPlugOwl
0x37ebb5000 - 0x37f0b8fff com.adobe.dvacore.framework (14.0.0) <d84f4977-ea10-3109-88e9-785d10693666> /Applications/Adobe Photoshop 2022/Adobe Photoshop 2022.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
0x371642000 - 0x37164dfff com.adobe.boost-threads.framework (14.0.0) <494ca48e-71fa-3304-8e21-9e34f5829980> /Applications/Adobe Photoshop 2022/Adobe Photoshop 2022.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
0x37185a000 - 0x3718aafff com.adobe.dvatransport.framework (14.0.0) <7e6c9e00-6068-31a7-819b-bfdc5c5fffae> /Applications/Adobe Photoshop 2022/Adobe Photoshop 2022.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
0x7ff83405d000 - 0x7ff83538cfff com.apple.JavaScriptCore (17612) <8d491514-e159-36dd-a89b-245e1331b8a1> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7ff822c7f000 - 0x7ff822f67fff com.apple.QuartzCore (1.11) <9e727a38-d1d3-3d6a-940c-0ebfa61e28e6> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7ff8245ac000 - 0x7ff8245cefff com.apple.audio.caulk (1.0) <0a60f9ec-f83c-388e-bcb1-43b785c997d1> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
0x7ff8293ec000 - 0x7ff829526fff com.apple.audio.toolbox.AudioToolbox (1.14) <f12ce1a4-a5b9-3b68-bc80-df155bd54852> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7ff828446000 - 0x7ff828475fff libAudioToolboxUtility.dylib (*) <16b70463-892b-36e2-ad97-e39092df84bc> /usr/lib/libAudioToolboxUtility.dylib
0x7ff8245cf000 - 0x7ff8246cffff com.apple.CoreMedia (1.0) <f588e97b-d586-39f3-84b5-a3399674cde8> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7ff8287bd000 - 0x7ff828efbfff com.apple.MediaToolbox (1.0) <8e5f7be0-8b93-377c-ab9b-c17e52360cf6> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.9G resident=0K(0%) swapped_out_or_unallocated=1.9G(100%)
Writable regions: Total=19.0G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=19.0G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 4480K 35
Activity Tracing 256K 1
CG backing stores 4560K 8
CG image 11.4M 84
CG raster data 60K 1
ColorSync 248K 30
CoreAnimation 204.1M 202
CoreGraphics 20K 4
CoreImage 4K 1
CoreServices 624K 2
CoreUI image data 4080K 43
Foundation 40K 2
IOKit 7940K 1
Image IO 1016K 100
JS JIT generated code 1.0G 3
Kernel Alloc Once 8K 1
MALLOC 6.1G 5052
MALLOC guard page 72K 16
MALLOC_LARGE (reserved) 40.3M 2 reserved VM address space (unallocated)
MALLOC_MEDIUM (reserved) 808.0M 8 reserved VM address space (unallocated)
MALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated)
Memory Tag 255 725.7M 1161
Memory Tag 255 (reserved) 16K 1 reserved VM address space (unallocated)
PROTECTED_MEMORY 4K 1
SQLite page cache 256K 4
STACK GUARD 56.5M 138
Stack 330.1M 141
VM_ALLOCATE 9.9G 398
WebKit Malloc 8348K 11
__DATA 75.4M 693
__DATA_CONST 45.0M 409
__DATA_DIRTY 1636K 225
__FONT_DATA 4K 1
__GLSLBUILTINS 5176K 1
__LINKEDIT 680.8M 115
__OBJC_RO 81.8M 1
__OBJC_RW 3136K 2
__TEXT 1.3G 662
__UNICODE 588K 1
dyld private memory 1344K 3
libnetwork 1664K 24
mapped file 461.0M 112
shared memory 1296K 18
TOTAL 22.1G 9719
TOTAL, minus reserved VM space 20.9G 9719
Full Report
{"app_name":"Adobe Photoshop 2022","timestamp":"2022-03-30 08:48:20.00 -0700","app_version":"23.2.2","slice_uuid":"bc21ebd7-3d85-3f23-953f-2a5df8f6d4eb","build_version":"23.2.2","platform":1,"bundleID":"com.adobe.Photoshop","share_with_app_devs":0,"is_first_party":0,"bug_type":"309","os_version":"macOS 12.2.1 (21D62)","incident_id":"BDF7D305-4E77-4AA2-8A2D-B97090C2F1B2","name":"Adobe Photoshop 2022"}
"uptime" : 77000,
"procLaunch" : "2022-03-29 19:44:38.0419 -0700",
"procRole" : "Foreground",
"version" : 2,
"userID" : 501,
"deployVersion" : 210,
"modelCode" : "iMac19,1",
"procStartAbsTime" : 31443144943475,
"coalitionID" : 9512,
"osVersion" : {
"train" : "macOS 12.2.1",
"build" : "21D62",
"releaseType" : "User"
"captureTime" : "2022-03-30 08:48:09.5321 -0700",
"incident" : "BDF7D305-4E77-4AA2-8A2D-B97090C2F1B2",
"bug_type" : "309",
"pid" : 10794,
"procExitAbsTime" : 77643917747198,
"cpuType" : "X86-64",
"procName" : "Adobe Photoshop 2022",
"procPath" : "\/Applications\/Adobe Photoshop 2022\/Adobe Photoshop 2022.app\/Contents\/MacOS\/Adobe Photoshop 2022",
"bundleInfo" : {"CFBundleShortVersionString":"23.2.2","CFBundleVersion":"23.2.2","CFBundleIdentifier":"com.adobe.Photoshop"},
"storeInfo" : {"deviceIdentifierForVendor":"9F71C397-A25F-5BA0-B647-EBB9A8BFB4F0","thirdParty":true},
"parentProc" : "launchd",
"parentPid" : 1,
"coalitionName" : "com.adobe.Photoshop",
"crashReporterKey" : "75B196F3-5CA5-370F-3CE2-31FB033E7D95",
"wakeTime" : 2945,
"sleepWakeUUID" : "F7C5BD4B-C36C-4CF4-814F-03F2F9BA4620",
"sip" : "enabled",
"vmRegionInfo" : "0xb8 is not in any region. Bytes before following region: 4410208072\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n __TEXT 106de7000-10f063000 [130.5M] r-x\/r-x SM=COW ...hotoshop 2022",
"isCorpse" : 1,
"exception" : {"codes":"0x0000000000000001, 0x00000000000000b8","rawCodes":[1,184],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x00000000000000b8"},
"termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":10794},
"vmregioninfo" : "0xb8 is not in any region. Bytes before following region: 4410208072\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n __TEXT 106de7000-10f063000 [130.5M] r-x\/r-x SM=COW ...hotoshop 2022",
"extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
"faultingThread" : 0,
"threads" : [{"queue":"com.apple.main-thread","instructionState":{"instructionStream":{"bytes":[137,251,72,139,6,76,141,117,208,76,137,247,255,144,136,0,0,0,102,15,112,69,208,78,102,15,112,77,224,78,243,15,127,3,243,15,127,75,16,76,137,247,232,77,233,61,3,72,137,216,72,131,196,32,91,65,94,93,195,72,141,61,10,44,13,4,72,137,254,186,211,1,0,0,232,13,191,106,0,102,46,15,31,132,0,0,0,0,0,15,31,0,85,72,137,229,72,139,63,72,133,255,116,7,72,139,7,93,255,96,32,49,192,93,195,102,15,31,132,0,0,0,0,0,85,72,137,229,83,80,72,137,251,72,139,63,72,133,255,116,24,72,139,7,255,80,40,132,192,116,14,131,123,24,22,15,149,192,72,131,196,8,91,93,195,49,192,72,131,196,8,91,93,195,102,46,15,31,132,0,0,0,0,0,15,31,64,0,85,72,137,229],"offset":96}},"frames":[{"imageOffset":39220964,"imageIndex":0},{"imageOffset":33331736,"imageIndex":0},{"imageOffset":43830812,"imageIndex":0},{"imageOffset":23735820,"imageIndex":0},{"imageOffset":46303666,"imageIndex":0},{"imageOffset":46303411,"imageIndex":0},{"imageOffset":46303411,"imageIndex":0},{"imageOffset":46303411,"imageIndex":0},{"imageOffset":46303411,"imageIndex":0},{"imageOffset":46303411,"imageIndex":0},{"imageOffset":46303411,"imageIndex":0},{"imageOffset":46096594,"imageIndex":0},{"imageOffset":46096801,"imageIndex":0},{"imageOffset":31023635,"imageIndex":0},{"imageOffset":16100752,"imageIndex":0},{"imageOffset":31025930,"imageIndex":0},{"imageOffset":45391006,"imageIndex":0},{"imageOffset":46085804,"imageIndex":0},{"imageOffset":46086001,"imageIndex":0},{"imageOffset":45031361,"imageIndex":0},{"imageOffset":45030893,"imageIndex":0},{"imageOffset":661200,"symbol":"__NSFireTimer","symbolLocation":67,"imageIndex":1},{"imageOffset":628815,"symbol":"__CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__","symbolLocation":20,"imageIndex":2},{"imageOffset":627518,"symbol":"__CFRunLoopDoTimer","symbolLocation":927,"imageIndex":2},{"imageOffset":626333,"symbol":"__CFRunLoopDoTimers","symbolLocation":307,"imageIndex":2},{"imageOffset":521248,"symbol":"__CFRunLoopRun","symbolLocation":1922,"imageIndex":2},{"imageOffset":517597,"symbol":"CFRunLoopRunSpecific","symbolLocation":563,"imageIndex":2},{"imageOffset":206065,"symbol":"RunCurrentEventLoopInMode","symbolLocation":292,"imageIndex":3},{"imageOffset":205383,"symbol":"ReceiveNextEventCommon","symbolLocation":587,"imageIndex":3},{"imageOffset":204773,"symbol":"_BlockUntilNextEventMatchingListInModeWithFilter","symbolLocation":70,"imageIndex":3},{"imageOffset":257416,"symbol":"_DPSNextEvent","symbolLocation":886,"imageIndex":4},{"imageOffset":250868,"symbol":"-[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:]","symbolLocation":1411,"imageIndex":4},{"imageOffset":45025634,"imageIndex":0},{"imageOffset":194841,"symbol":"-[NSApplication run]","symbolLocation":586,"imageIndex":4},{"imageOffset":45030706,"imageIndex":0},{"imageOffset":45040918,"imageIndex":0},{"imageOffset":46092972,"imageIndex":0},{"imageOffset":94354601,"imageIndex":0},{"imageOffset":21442,"imageIndex":0},{"imageOffset":21758,"symbol":"start","symbolLocation":462,"imageIndex":5}],"id":902459,"triggered":true,"threadState":{"r13":{"value":4552061464},"rax":{"value":4294967295},"rflags":{"value":66054},"cpu":{"value":6},"r14":{"value":0},"rsi":{"value":1},"r8":{"value":0},"cr2":{"value":184},"rdx":{"value":0},"r10":{"value":4552036208},"r9":{"value":0},"r15":{"value":140287048096768},"rbx":{"value":184},"trap":{"value":14,"description":"(no mapping for user data read)"},"err":{"value":4},"r11":{"value":4455161280},"rip":{"value":4449429220,"matchesCrashFrame":1},"rbp":{"value":140701938569744},"rsp":{"value":140701938569744},"r12":{"value":4556210480},"rcx":{"value":5},"flavor":"x86_THREAD_STATE","rdi":{"value":184}},"name":"Main Thread"},{"id":902495,"queue":"com.apple.root.default-qos","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":6},{"imageOffset":527090,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":2},{"imageOffset":520651,"symbol":"__CFRunLoopRun","symbolLocation":1325,"imageIndex":2},{"imageOffset":517597,"symbol":"CFRunLoopRunSpecific","symbolLocation":563,"imageIndex":2},{"imageOffset":1074734,"symbol":"CFRunLoopRun","symbolLocation":40,"imageIndex":2},{"imageOffset":6872,"symbol":"_dispatch_call_block_and_release","symbolLocation":12,"imageIndex":7},{"imageOffset":11465,"symbol":"_dispatch_client_callout","symbolLocation":8,"imageIndex":7},{"imageOffset":21439,"symbol":"_dispatch_queue_override_invoke","symbolLocation":801,"imageIndex":7},{"imageOffset":74682,"symbol":"_dispatch_root_queue_drain","symbolLocation":343,"imageIndex":7},{"imageOffset":76634,"symbol":"_dispatch_worker_thread2","symbolLocation":160,"imageIndex":7},{"imageOffset":12334,"symbol":"_pthread_wqthread","symbolLocation":256,"imageIndex":8},{"imageOffset":8187,"symbol":"start_wqthread","symbolLocation":15,"imageIndex":8}]},{"id":902525,"name":"HB Kill Signal Processor","frames":[{"imageOffset":21598,"symbol":"kevent","symbolLocation":10,"imageIndex":6},{"imageOffset":94342951,"imageIndex":0},{"imageOffset":94343804,"imageIndex":0},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902533,"name":"com.adobe.ngl-ProcessNglIngestEvents-0x700007c16000","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":48979,"symbol":"std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >)","symbolLocation":93,"imageIndex":9},{"imageOffset":79025896,"imageIndex":0},{"imageOffset":78451239,"imageIndex":0},{"imageOffset":78451066,"imageIndex":0},{"imageOffset":78451614,"imageIndex":0},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902534,"name":"com.adobe.ngl-MonitorSuccessEventsThread-0x700007c99000","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":48979,"symbol":"std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >)","symbolLocation":93,"imageIndex":9},{"imageOffset":79039136,"imageIndex":0},{"imageOffset":78451239,"imageIndex":0},{"imageOffset":78451066,"imageIndex":0},{"imageOffset":78451614,"imageIndex":0},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902612,"name":"VM IO Processor","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":44808859,"imageIndex":0},{"imageOffset":44806603,"imageIndex":0},{"imageOffset":44806968,"imageIndex":0},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902614,"name":"com.adobe.ngl-RecurringLogPosting-0x700007b93000","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":48979,"symbol":"std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >)","symbolLocation":93,"imageIndex":9},{"imageOffset":78365966,"imageIndex":0},{"imageOffset":78451239,"imageIndex":0},{"imageOffset":78451066,"imageIndex":0},{"imageOffset":78451614,"imageIndex":0},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902617,"name":"VulcanMsgRecv","frames":[{"imageOffset":16418,"symbol":"__recvfrom","symbolLocation":10,"imageIndex":6},{"imageOffset":481472,"imageIndex":10},{"imageOffset":493604,"imageIndex":10},{"imageOffset":325885,"imageIndex":10},{"imageOffset":301423,"imageIndex":10},{"imageOffset":308526,"imageIndex":10},{"imageOffset":307529,"imageIndex":10},{"imageOffset":332411,"imageIndex":10},{"imageOffset":331393,"imageIndex":10},{"imageOffset":331165,"imageIndex":10},{"imageOffset":58164,"imageIndex":10},{"imageOffset":397537,"imageIndex":10},{"imageOffset":521161,"imageIndex":10},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902638,"name":"com.apple.NSURLConnectionLoader","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":6},{"imageOffset":527090,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":2},{"imageOffset":520651,"symbol":"__CFRunLoopRun","symbolLocation":1325,"imageIndex":2},{"imageOffset":517597,"symbol":"CFRunLoopRunSpecific","symbolLocation":563,"imageIndex":2},{"imageOffset":2422450,"imageIndex":11},{"imageOffset":361177,"symbol":"__NSThread__start__","symbolLocation":1025,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902677,"name":"com.adobe.ngl-RecurringProfileAndAuthStateCheck-0x700008134000","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":48979,"symbol":"std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >)","symbolLocation":93,"imageIndex":9},{"imageOffset":78378847,"imageIndex":0},{"imageOffset":78451239,"imageIndex":0},{"imageOffset":78451066,"imageIndex":0},{"imageOffset":78451614,"imageIndex":0},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902678,"name":"com.adobe.ngl-AuthStatusFileWatcher-0x7000081b7000","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":6},{"imageOffset":527090,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":2},{"imageOffset":520651,"symbol":"__CFRunLoopRun","symbolLocation":1325,"imageIndex":2},{"imageOffset":517597,"symbol":"CFRunLoopRunSpecific","symbolLocation":563,"imageIndex":2},{"imageOffset":1074734,"symbol":"CFRunLoopRun","symbolLocation":40,"imageIndex":2},{"imageOffset":78824943,"imageIndex":0},{"imageOffset":78232595,"imageIndex":0},{"imageOffset":78451239,"imageIndex":0},{"imageOffset":78451066,"imageIndex":0},{"imageOffset":78451614,"imageIndex":0},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902686,"name":"PS SAM Task Queue","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":61001323,"imageIndex":0},{"imageOffset":60996269,"imageIndex":0},{"imageOffset":93519720,"imageIndex":0},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902687,"name":"UXP Database Thread","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":792300,"imageIndex":12},{"imageOffset":790049,"imageIndex":12},{"imageOffset":804818,"imageIndex":12},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902689,"name":"LibUV Loop Thread","frames":[{"imageOffset":21598,"symbol":"kevent","symbolLocation":10,"imageIndex":6},{"imageOffset":17479150,"imageIndex":12},{"imageOffset":17488965,"symbol":"uv_run","symbolLocation":359,"imageIndex":12},{"imageOffset":20052165,"imageIndex":12},{"imageOffset":20052755,"imageIndex":12},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902690,"name":"Third Party - UXP JavaScript Thread","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":792300,"imageIndex":12},{"imageOffset":790049,"imageIndex":12},{"imageOffset":804818,"imageIndex":12},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902691,"name":"First Party - UXP JavaScript Thread","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":48979,"symbol":"std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >)","symbolLocation":93,"imageIndex":9},{"imageOffset":987811,"imageIndex":12},{"imageOffset":792262,"imageIndex":12},{"imageOffset":790049,"imageIndex":12},{"imageOffset":804818,"imageIndex":12},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902692,"name":"UI Worker 1","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":22545968,"imageIndex":0},{"imageOffset":22544809,"imageIndex":0},{"imageOffset":22551102,"imageIndex":0},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902693,"name":"V8 DefaultWorke","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":20279828,"imageIndex":12},{"imageOffset":20277328,"imageIndex":12},{"imageOffset":20240919,"imageIndex":12},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902694,"name":"V8 DefaultWorke","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":20279828,"imageIndex":12},{"imageOffset":20277328,"imageIndex":12},{"imageOffset":20240919,"imageIndex":12},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902695,"name":"V8 DefaultWorke","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":20279828,"imageIndex":12},{"imageOffset":20277328,"imageIndex":12},{"imageOffset":20240919,"imageIndex":12},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902696,"name":"V8 DefaultWorke","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":20279828,"imageIndex":12},{"imageOffset":20277328,"imageIndex":12},{"imageOffset":20240919,"imageIndex":12},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902697,"name":"V8 DefaultWorke","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":20279828,"imageIndex":12},{"imageOffset":20277328,"imageIndex":12},{"imageOffset":20240919,"imageIndex":12},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902698,"name":"V8 DefaultWorke","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":20279828,"imageIndex":12},{"imageOffset":20277328,"imageIndex":12},{"imageOffset":20240919,"imageIndex":12},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902699,"name":"V8 DefaultWorke","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":20279828,"imageIndex":12},{"imageOffset":20277328,"imageIndex":12},{"imageOffset":20240919,"imageIndex":12},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902700,"name":"V8 DefaultWorke","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":20279828,"imageIndex":12},{"imageOffset":20277328,"imageIndex":12},{"imageOffset":20240919,"imageIndex":12},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902701,"name":"V8 DefaultWorke","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":20279828,"imageIndex":12},{"imageOffset":20277328,"imageIndex":12},{"imageOffset":20240919,"imageIndex":12},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902702,"name":"V8 DefaultWorke","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":20279828,"imageIndex":12},{"imageOffset":20277328,"imageIndex":12},{"imageOffset":20240919,"imageIndex":12},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902703,"name":"V8 DefaultWorke","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":20279828,"imageIndex":12},{"imageOffset":20277328,"imageIndex":12},{"imageOffset":20240919,"imageIndex":12},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902704,"name":"V8 DefaultWorke","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":20279828,"imageIndex":12},{"imageOffset":20277328,"imageIndex":12},{"imageOffset":20240919,"imageIndex":12},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902705,"name":"V8 DefaultWorke","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":20279828,"imageIndex":12},{"imageOffset":20277328,"imageIndex":12},{"imageOffset":20240919,"imageIndex":12},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902706,"name":"V8 DefaultWorke","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":20279828,"imageIndex":12},{"imageOffset":20277328,"imageIndex":12},{"imageOffset":20240919,"imageIndex":12},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902707,"name":"V8 DefaultWorke","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":20279828,"imageIndex":12},{"imageOffset":20277328,"imageIndex":12},{"imageOffset":20240919,"imageIndex":12},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902708,"frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":1313006,"imageIndex":13},{"imageOffset":820333,"imageIndex":13},{"imageOffset":798486,"imageIndex":13},{"imageOffset":1309927,"imageIndex":13},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902709,"frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":1313006,"imageIndex":13},{"imageOffset":1022281,"imageIndex":13},{"imageOffset":1021098,"imageIndex":13},{"imageOffset":1309927,"imageIndex":13},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902720,"name":"com.apple.CFSocket.private","frames":[{"imageOffset":36426,"symbol":"__select","symbolLocation":10,"imageIndex":6},{"imageOffset":687821,"symbol":"__CFSocketManager","symbolLocation":630,"imageIndex":2},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902721,"frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":17530110,"symbol":"uv_cond_wait","symbolLocation":9,"imageIndex":12},{"imageOffset":17461624,"imageIndex":12},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902722,"frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":17530110,"symbol":"uv_cond_wait","symbolLocation":9,"imageIndex":12},{"imageOffset":17461624,"imageIndex":12},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902723,"frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":17530110,"symbol":"uv_cond_wait","symbolLocation":9,"imageIndex":12},{"imageOffset":17461624,"imageIndex":12},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902724,"frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":17530110,"symbol":"uv_cond_wait","symbolLocation":9,"imageIndex":12},{"imageOffset":17461624,"imageIndex":12},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902749,"name":"General Background Service","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":22545968,"imageIndex":0},{"imageOffset":22544809,"imageIndex":0},{"imageOffset":22551102,"imageIndex":0},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902751,"name":"LEC-IngestPoll","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":48979,"symbol":"std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >)","symbolLocation":93,"imageIndex":9},{"imageOffset":46203963,"imageIndex":0},{"imageOffset":2328241,"imageIndex":0},{"imageOffset":2166926,"imageIndex":0},{"imageOffset":2171905,"imageIndex":0},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902758,"name":"ACPLSDKWorkerThread2","frames":[{"imageOffset":13274,"symbol":"__semwait_signal","symbolLocation":10,"imageIndex":6},{"imageOffset":67753,"symbol":"nanosleep","symbolLocation":196,"imageIndex":14},{"imageOffset":89105,"symbol":"std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > const&)","symbolLocation":73,"imageIndex":9},{"imageOffset":56238520,"imageIndex":0},{"imageOffset":56243134,"imageIndex":0},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902837,"frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":4135736,"symbol":"gpr_cv_wait","symbolLocation":120,"imageIndex":15},{"imageOffset":2714277,"symbol":"grpc_impl::Server::Wait()","symbolLocation":133,"imageIndex":15},{"imageOffset":16967,"symbol":"RunServer()","symbolLocation":1207,"imageIndex":15},{"imageOffset":57768,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (*)()> >(void*)","symbolLocation":40,"imageIndex":15},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902838,"name":"default-executor","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":4135736,"symbol":"gpr_cv_wait","symbolLocation":120,"imageIndex":15},{"imageOffset":2156410,"symbol":"grpc_core::Executor::ThreadMain(void*)","symbolLocation":234,"imageIndex":15},{"imageOffset":4145308,"symbol":"grpc_core::(anonymous namespace)::ThreadInternalsPosix::ThreadInternalsPosix(char const*, void (*)(void*), void*, bool*, grpc_core::Thread::Options const&)::'lambda'(void*)::__invoke(void*)","symbolLocation":156,"imageIndex":15},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902839,"name":"resolver-executor","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":4135736,"symbol":"gpr_cv_wait","symbolLocation":120,"imageIndex":15},{"imageOffset":2156410,"symbol":"grpc_core::Executor::ThreadMain(void*)","symbolLocation":234,"imageIndex":15},{"imageOffset":4145308,"symbol":"grpc_core::(anonymous namespace)::ThreadInternalsPosix::ThreadInternalsPosix(char const*, void (*)(void*), void*, bool*, grpc_core::Thread::Options const&)::'lambda'(void*)::__invoke(void*)","symbolLocation":156,"imageIndex":15},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902840,"name":"grpc_global_timer","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":4135718,"symbol":"gpr_cv_wait","symbolLocation":102,"imageIndex":15},{"imageOffset":2231185,"symbol":"timer_thread(void*)","symbolLocation":881,"imageIndex":15},{"imageOffset":4145308,"symbol":"grpc_core::(anonymous namespace)::ThreadInternalsPosix::ThreadInternalsPosix(char const*, void (*)(void*), void*, bool*, grpc_core::Thread::Options const&)::'lambda'(void*)::__invoke(void*)","symbolLocation":156,"imageIndex":15},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902841,"name":"grpc_health_check_service","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":4135736,"symbol":"gpr_cv_wait","symbolLocation":120,"imageIndex":15},{"imageOffset":2389200,"symbol":"(anonymous namespace)::non_polling_poller_work(grpc_pollset*, grpc_pollset_worker**, long long)","symbolLocation":208,"imageIndex":15},{"imageOffset":2382993,"symbol":"cq_next(grpc_completion_queue*, gpr_timespec, void*)","symbolLocation":497,"imageIndex":15},{"imageOffset":2652033,"symbol":"grpc_impl::CompletionQueue::AsyncNextInternal(void**, bool*, gpr_timespec)","symbolLocation":49,"imageIndex":15},{"imageOffset":2659617,"symbol":"grpc::DefaultHealthCheckService::HealthCheckServiceImpl::Serve(void*)","symbolLocation":97,"imageIndex":15},{"imageOffset":4145308,"symbol":"grpc_core::(anonymous namespace)::ThreadInternalsPosix::ThreadInternalsPosix(char const*, void (*)(void*), void*, bool*, grpc_core::Thread::Options const&)::'lambda'(void*)::__invoke(void*)","symbolLocation":156,"imageIndex":15},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902842,"name":"grpcpp_sync_server","frames":[{"imageOffset":29102,"symbol":"poll","symbolLocation":10,"imageIndex":6},{"imageOffset":2144305,"symbol":"pollset_work(grpc_pollset*, grpc_pollset_worker**, long long)","symbolLocation":1297,"imageIndex":15},{"imageOffset":2382993,"symbol":"cq_next(grpc_completion_queue*, gpr_timespec, void*)","symbolLocation":497,"imageIndex":15},{"imageOffset":2652033,"symbol":"grpc_impl::CompletionQueue::AsyncNextInternal(void**, bool*, gpr_timespec)","symbolLocation":49,"imageIndex":15},{"imageOffset":2719226,"symbol":"grpc_impl::Server::SyncRequestThreadManager::PollForWork(void**, bool*)","symbolLocation":106,"imageIndex":15},{"imageOffset":2764095,"symbol":"grpc::ThreadManager::MainWorkLoop()","symbolLocation":447,"imageIndex":15},{"imageOffset":2766993,"symbol":"grpc::ThreadManager::WorkerThread::WorkerThread(grpc::ThreadManager*)::$_0::__invoke(void*)","symbolLocation":17,"imageIndex":15},{"imageOffset":4145308,"symbol":"grpc_core::(anonymous namespace)::ThreadInternalsPosix::ThreadInternalsPosix(char const*, void (*)(void*), void*, bool*, grpc_core::Thread::Options const&)::'lambda'(void*)::__invoke(void*)","symbolLocation":156,"imageIndex":15},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902854,"name":"BridgeTalk","frames":[{"imageOffset":13274,"symbol":"__semwait_signal","symbolLocation":10,"imageIndex":6},{"imageOffset":67753,"symbol":"nanosleep","symbolLocation":196,"imageIndex":14},{"imageOffset":3586232,"symbol":"ScObjects::Thread::wait(unsigned int)","symbolLocation":56,"imageIndex":16},{"imageOffset":3464530,"symbol":"ScObjects::BridgeTalkThread::run()","symbolLocation":290,"imageIndex":16},{"imageOffset":3585127,"symbol":"ScObjects::Thread::go(void*)","symbolLocation":151,"imageIndex":16},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902877,"name":"TaskSchedulerServiceThread","frames":[{"imageOffset":21598,"symbol":"kevent","symbolLocation":10,"imageIndex":6},{"imageOffset":39717593,"imageIndex":17},{"imageOffset":39708093,"imageIndex":17},{"imageOffset":39704510,"imageIndex":17},{"imageOffset":39185109,"imageIndex":17},{"imageOffset":39399044,"imageIndex":17},{"imageOffset":39473942,"imageIndex":17},{"imageOffset":39670887,"imageIndex":17},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902878,"name":"TaskSchedulerForegroundWorker","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":6},{"imageOffset":39277696,"imageIndex":17},{"imageOffset":39277969,"imageIndex":17},{"imageOffset":39380216,"imageIndex":17},{"imageOffset":39382403,"imageIndex":17},{"imageOffset":39381556,"imageIndex":17},{"imageOffset":39670887,"imageIndex":17},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902879,"name":"TaskSchedulerForegroundBlockingWorker","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":6},{"imageOffset":39277696,"imageIndex":17},{"imageOffset":39277969,"imageIndex":17},{"imageOffset":39380216,"imageIndex":17},{"imageOffset":39382403,"imageIndex":17},{"imageOffset":39381556,"imageIndex":17},{"imageOffset":39670887,"imageIndex":17},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902880,"name":"TaskSchedulerBackgroundWorker","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":6},{"imageOffset":39277696,"imageIndex":17},{"imageOffset":39277969,"imageIndex":17},{"imageOffset":39380216,"imageIndex":17},{"imageOffset":39382403,"imageIndex":17},{"imageOffset":39381412,"imageIndex":17},{"imageOffset":39670887,"imageIndex":17},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902882,"name":"Chrome_IOThread","frames":[{"imageOffset":21598,"symbol":"kevent","symbolLocation":10,"imageIndex":6},{"imageOffset":39717593,"imageIndex":17},{"imageOffset":39708093,"imageIndex":17},{"imageOffset":39704510,"imageIndex":17},{"imageOffset":39185109,"imageIndex":17},{"imageOffset":22374980,"imageIndex":17},{"imageOffset":39473942,"imageIndex":17},{"imageOffset":39670887,"imageIndex":17},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902883,"name":"NetworkConfigWatcher","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":6},{"imageOffset":527090,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":2},{"imageOffset":520651,"symbol":"__CFRunLoopRun","symbolLocation":1325,"imageIndex":2},{"imageOffset":517597,"symbol":"CFRunLoopRunSpecific","symbolLocation":563,"imageIndex":2},{"imageOffset":390766,"symbol":"-[NSRunLoop(NSRunLoop) runMode:beforeDate:]","symbolLocation":216,"imageIndex":1},{"imageOffset":39049856,"imageIndex":17},{"imageOffset":39045607,"imageIndex":17},{"imageOffset":39185109,"imageIndex":17},{"imageOffset":39473942,"imageIndex":17},{"imageOffset":39670887,"imageIndex":17},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902884,"name":"DnsConfigService","frames":[{"imageOffset":21598,"symbol":"kevent","symbolLocation":10,"imageIndex":6},{"imageOffset":39717593,"imageIndex":17},{"imageOffset":39708093,"imageIndex":17},{"imageOffset":39704535,"imageIndex":17},{"imageOffset":39185109,"imageIndex":17},{"imageOffset":39473942,"imageIndex":17},{"imageOffset":39670887,"imageIndex":17},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902887,"name":"TaskSchedulerBackgroundBlockingWorker","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":6},{"imageOffset":39277696,"imageIndex":17},{"imageOffset":39277969,"imageIndex":17},{"imageOffset":39380216,"imageIndex":17},{"imageOffset":39382403,"imageIndex":17},{"imageOffset":39381412,"imageIndex":17},{"imageOffset":39670887,"imageIndex":17},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902888,"name":"CompositorTileWorker1\/174851","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":39667413,"imageIndex":17},{"imageOffset":55959928,"imageIndex":17},{"imageOffset":39470964,"imageIndex":17},{"imageOffset":39670887,"imageIndex":17},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902889,"name":"AudioThread","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":6},{"imageOffset":39277696,"imageIndex":17},{"imageOffset":39277375,"imageIndex":17},{"imageOffset":39045277,"imageIndex":17},{"imageOffset":39185109,"imageIndex":17},{"imageOffset":39473942,"imageIndex":17},{"imageOffset":39670887,"imageIndex":17},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902890,"name":"TaskSchedulerSingleThreadForegroundBlocking0","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":6},{"imageOffset":39277696,"imageIndex":17},{"imageOffset":39277375,"imageIndex":17},{"imageOffset":39380202,"imageIndex":17},{"imageOffset":39382403,"imageIndex":17},{"imageOffset":39381652,"imageIndex":17},{"imageOffset":39670887,"imageIndex":17},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902892,"name":"TaskSchedulerSingleThreadBackgroundBlocking1","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":6},{"imageOffset":39277696,"imageIndex":17},{"imageOffset":39277375,"imageIndex":17},{"imageOffset":39380202,"imageIndex":17},{"imageOffset":39382403,"imageIndex":17},{"imageOffset":39381508,"imageIndex":17},{"imageOffset":39670887,"imageIndex":17},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902893,"name":"TaskSchedulerSingleThreadSharedBackgroundBlocking2","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":6},{"imageOffset":39277696,"imageIndex":17},{"imageOffset":39277375,"imageIndex":17},{"imageOffset":39380202,"imageIndex":17},{"imageOffset":39381794,"imageIndex":17},{"imageOffset":39381460,"imageIndex":17},{"imageOffset":39670887,"imageIndex":17},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902894,"name":"TaskSchedulerSingleThreadSharedForegroundBlocking3","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":6},{"imageOffset":39277696,"imageIndex":17},{"imageOffset":39277375,"imageIndex":17},{"imageOffset":39380202,"imageIndex":17},{"imageOffset":39381794,"imageIndex":17},{"imageOffset":39381604,"imageIndex":17},{"imageOffset":39670887,"imageIndex":17},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902895,"name":"NetworkConfigWatcher","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":6},{"imageOffset":527090,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":2},{"imageOffset":520651,"symbol":"__CFRunLoopRun","symbolLocation":1325,"imageIndex":2},{"imageOffset":517597,"symbol":"CFRunLoopRunSpecific","symbolLocation":563,"imageIndex":2},{"imageOffset":390766,"symbol":"-[NSRunLoop(NSRunLoop) runMode:beforeDate:]","symbolLocation":216,"imageIndex":1},{"imageOffset":39049856,"imageIndex":17},{"imageOffset":39045607,"imageIndex":17},{"imageOffset":39185109,"imageIndex":17},{"imageOffset":39473942,"imageIndex":17},{"imageOffset":39670887,"imageIndex":17},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902897,"name":"CacheThread_BlockFile","frames":[{"imageOffset":21598,"symbol":"kevent","symbolLocation":10,"imageIndex":6},{"imageOffset":39717593,"imageIndex":17},{"imageOffset":39708093,"imageIndex":17},{"imageOffset":39704510,"imageIndex":17},{"imageOffset":39185109,"imageIndex":17},{"imageOffset":39473942,"imageIndex":17},{"imageOffset":39670887,"imageIndex":17},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902981,"name":"grpcpp_sync_server","frames":[{"imageOffset":29102,"symbol":"poll","symbolLocation":10,"imageIndex":6},{"imageOffset":2144305,"symbol":"pollset_work(grpc_pollset*, grpc_pollset_worker**, long long)","symbolLocation":1297,"imageIndex":15},{"imageOffset":2382993,"symbol":"cq_next(grpc_completion_queue*, gpr_timespec, void*)","symbolLocation":497,"imageIndex":15},{"imageOffset":2652033,"symbol":"grpc_impl::CompletionQueue::AsyncNextInternal(void**, bool*, gpr_timespec)","symbolLocation":49,"imageIndex":15},{"imageOffset":2719226,"symbol":"grpc_impl::Server::SyncRequestThreadManager::PollForWork(void**, bool*)","symbolLocation":106,"imageIndex":15},{"imageOffset":2764095,"symbol":"grpc::ThreadManager::MainWorkLoop()","symbolLocation":447,"imageIndex":15},{"imageOffset":2766993,"symbol":"grpc::ThreadManager::WorkerThread::WorkerThread(grpc::ThreadManager*)::$_0::__invoke(void*)","symbolLocation":17,"imageIndex":15},{"imageOffset":4145308,"symbol":"grpc_core::(anonymous namespace)::ThreadInternalsPosix::ThreadInternalsPosix(char const*, void (*)(void*), void*, bool*, grpc_core::Thread::Options const&)::'lambda'(void*)::__invoke(void*)","symbolLocation":156,"imageIndex":15},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902984,"name":"com.apple.NSEventThread","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":6},{"imageOffset":527090,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":2},{"imageOffset":520651,"symbol":"__CFRunLoopRun","symbolLocation":1325,"imageIndex":2},{"imageOffset":517597,"symbol":"CFRunLoopRunSpecific","symbolLocation":563,"imageIndex":2},{"imageOffset":1757144,"symbol":"_NSEventThread","symbolLocation":132,"imageIndex":4},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":902992,"name":"grpc_global_timer","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":4135736,"symbol":"gpr_cv_wait","symbolLocation":120,"imageIndex":15},{"imageOffset":2231185,"symbol":"timer_thread(void*)","symbolLocation":881,"imageIndex":15},{"imageOffset":4145308,"symbol":"grpc_core::(anonymous namespace)::ThreadInternalsPosix::ThreadInternalsPosix(char const*, void (*)(void*), void*, bool*, grpc_core::Thread::Options const&)::'lambda'(void*)::__invoke(void*)","symbolLocation":156,"imageIndex":15},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903009,"name":"cr_scratch","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":15019115,"imageIndex":18},{"imageOffset":11679985,"imageIndex":18},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903020,"name":"BGThread (AMD Radeon Pro Vega 48)","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":15759603,"imageIndex":18},{"imageOffset":11679985,"imageIndex":18},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903065,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":95896,"imageIndex":19},{"imageOffset":95545,"imageIndex":19},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903066,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":95896,"imageIndex":19},{"imageOffset":95545,"imageIndex":19},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903067,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":95896,"imageIndex":19},{"imageOffset":95545,"imageIndex":19},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903068,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":95896,"imageIndex":19},{"imageOffset":95545,"imageIndex":19},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903069,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":95896,"imageIndex":19},{"imageOffset":95545,"imageIndex":19},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903070,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":95896,"imageIndex":19},{"imageOffset":95545,"imageIndex":19},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903071,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":95896,"imageIndex":19},{"imageOffset":95545,"imageIndex":19},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903072,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":95896,"imageIndex":19},{"imageOffset":95545,"imageIndex":19},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903073,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":95896,"imageIndex":19},{"imageOffset":95545,"imageIndex":19},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903074,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":95896,"imageIndex":19},{"imageOffset":95545,"imageIndex":19},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903075,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":95896,"imageIndex":19},{"imageOffset":95545,"imageIndex":19},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903076,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":95896,"imageIndex":19},{"imageOffset":95545,"imageIndex":19},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903077,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":95896,"imageIndex":19},{"imageOffset":95545,"imageIndex":19},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903078,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":95896,"imageIndex":19},{"imageOffset":95545,"imageIndex":19},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903079,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":95896,"imageIndex":19},{"imageOffset":95545,"imageIndex":19},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903347,"name":"UI Worker 2","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":22545968,"imageIndex":0},{"imageOffset":22544809,"imageIndex":0},{"imageOffset":22551102,"imageIndex":0},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903348,"name":"Background DOM Loader Thread - UXP JavaScript Thread","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":792300,"imageIndex":12},{"imageOffset":790049,"imageIndex":12},{"imageOffset":804818,"imageIndex":12},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903361,"name":"UI Worker 3","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":22545968,"imageIndex":0},{"imageOffset":22544809,"imageIndex":0},{"imageOffset":22551102,"imageIndex":0},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903362,"name":"UI Worker 4","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":22545968,"imageIndex":0},{"imageOffset":22544809,"imageIndex":0},{"imageOffset":22551102,"imageIndex":0},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903363,"name":"com.apple.CFStream.LegacyThread","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":6},{"imageOffset":527090,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":2},{"imageOffset":520651,"symbol":"__CFRunLoopRun","symbolLocation":1325,"imageIndex":2},{"imageOffset":517597,"symbol":"CFRunLoopRunSpecific","symbolLocation":563,"imageIndex":2},{"imageOffset":1032932,"symbol":"_legacyStreamRunLoop_workThread","symbolLocation":251,"imageIndex":2},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903370,"frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":6},{"imageOffset":527090,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":2},{"imageOffset":520651,"symbol":"__CFRunLoopRun","symbolLocation":1325,"imageIndex":2},{"imageOffset":517597,"symbol":"CFRunLoopRunSpecific","symbolLocation":563,"imageIndex":2},{"imageOffset":1400538,"symbol":"-[NSConnection run]","symbolLocation":126,"imageIndex":1},{"imageOffset":361177,"symbol":"__NSThread__start__","symbolLocation":1025,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903372,"name":"CEPMonitorThread","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":6},{"imageOffset":527090,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":2},{"imageOffset":520651,"symbol":"__CFRunLoopRun","symbolLocation":1325,"imageIndex":2},{"imageOffset":517597,"symbol":"CFRunLoopRunSpecific","symbolLocation":563,"imageIndex":2},{"imageOffset":965549,"symbol":"-[NSConcreteTask waitUntilExit]","symbolLocation":334,"imageIndex":1},{"imageOffset":868412,"imageIndex":20},{"imageOffset":361177,"symbol":"__NSThread__start__","symbolLocation":1025,"imageIndex":1},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903415,"frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":2862331,"imageIndex":21},{"imageOffset":2860542,"imageIndex":21},{"imageOffset":2852172,"imageIndex":21},{"imageOffset":2838829,"imageIndex":21},{"imageOffset":7496,"imageIndex":22},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903416,"frames":[{"imageOffset":21598,"symbol":"kevent","symbolLocation":10,"imageIndex":6},{"imageOffset":139590,"imageIndex":23},{"imageOffset":138549,"imageIndex":23},{"imageOffset":137697,"imageIndex":23},{"imageOffset":97548,"symbol":"SkyConnectionEnv::MainLoop()","symbolLocation":172,"imageIndex":23},{"imageOffset":95657,"symbol":"SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*)","symbolLocation":9,"imageIndex":23},{"imageOffset":7496,"imageIndex":22},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903429,"frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":138758,"imageIndex":23},{"imageOffset":137697,"imageIndex":23},{"imageOffset":187423,"imageIndex":23},{"imageOffset":1495568,"symbol":"boost_asio_detail_posix_thread_function","symbolLocation":16,"imageIndex":21},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903430,"frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":2862331,"imageIndex":21},{"imageOffset":2860542,"imageIndex":21},{"imageOffset":2852172,"imageIndex":21},{"imageOffset":2838829,"imageIndex":21},{"imageOffset":7496,"imageIndex":22},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903431,"frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":2862331,"imageIndex":21},{"imageOffset":2860542,"imageIndex":21},{"imageOffset":2852172,"imageIndex":21},{"imageOffset":2838829,"imageIndex":21},{"imageOffset":7496,"imageIndex":22},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903432,"frames":[{"imageOffset":21598,"symbol":"kevent","symbolLocation":10,"imageIndex":6},{"imageOffset":139590,"imageIndex":23},{"imageOffset":138549,"imageIndex":23},{"imageOffset":137697,"imageIndex":23},{"imageOffset":97548,"symbol":"SkyConnectionEnv::MainLoop()","symbolLocation":172,"imageIndex":23},{"imageOffset":95657,"symbol":"SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*)","symbolLocation":9,"imageIndex":23},{"imageOffset":7496,"imageIndex":22},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903433,"name":"JavaScriptCore bmalloc scavenger","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":18847381,"symbol":"void std::__1::condition_variable_any::wait<std::__1::unique_lock<bmalloc::Mutex> >(std::__1::unique_lock<bmalloc::Mutex>&)","symbolLocation":85,"imageIndex":24},{"imageOffset":18865723,"symbol":"bmalloc::Scavenger::threadRunLoop()","symbolLocation":443,"imageIndex":24},{"imageOffset":18864489,"symbol":"bmalloc::Scavenger::threadEntryPoint(bmalloc::Scavenger*)","symbolLocation":9,"imageIndex":24},{"imageOffset":18870295,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (*)(bmalloc::Scavenger*), bmalloc::Scavenger*> >(void*)","symbolLocation":39,"imageIndex":24},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903436,"name":"com.apple.coreanimation.render-server","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":6},{"imageOffset":288350,"symbol":"CA::Render::Server::server_thread(void*)","symbolLocation":493,"imageIndex":25},{"imageOffset":287841,"symbol":"thread_fun(void*)","symbolLocation":25,"imageIndex":25},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903582,"frames":[{"imageOffset":21598,"symbol":"kevent","symbolLocation":10,"imageIndex":6},{"imageOffset":2444543,"imageIndex":12},{"imageOffset":2453834,"imageIndex":12},{"imageOffset":2430699,"imageIndex":12},{"imageOffset":2430467,"imageIndex":12},{"imageOffset":2390748,"imageIndex":12},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903583,"frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":2489326,"imageIndex":12},{"imageOffset":2453772,"imageIndex":12},{"imageOffset":2430699,"imageIndex":12},{"imageOffset":2430467,"imageIndex":12},{"imageOffset":2446964,"imageIndex":12},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903762,"name":"Font Initialization","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":22545968,"imageIndex":0},{"imageOffset":22544809,"imageIndex":0},{"imageOffset":22551102,"imageIndex":0},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":903763,"name":"DeepFont","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":48834,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":9},{"imageOffset":22545968,"imageIndex":0},{"imageOffset":22544809,"imageIndex":0},{"imageOffset":22551102,"imageIndex":0},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":904785,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":95896,"imageIndex":19},{"imageOffset":95545,"imageIndex":19},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":904786,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":95896,"imageIndex":19},{"imageOffset":95545,"imageIndex":19},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":904973,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":95896,"imageIndex":19},{"imageOffset":95545,"imageIndex":19},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":904974,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":95896,"imageIndex":19},{"imageOffset":95545,"imageIndex":19},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":904975,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":95896,"imageIndex":19},{"imageOffset":95545,"imageIndex":19},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":904976,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":95896,"imageIndex":19},{"imageOffset":95545,"imageIndex":19},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":904977,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":95896,"imageIndex":19},{"imageOffset":95545,"imageIndex":19},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":904978,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":95896,"imageIndex":19},{"imageOffset":95545,"imageIndex":19},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":904979,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":95896,"imageIndex":19},{"imageOffset":95545,"imageIndex":19},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":904980,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":95896,"imageIndex":19},{"imageOffset":95545,"imageIndex":19},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":904981,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":95896,"imageIndex":19},{"imageOffset":95545,"imageIndex":19},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":904982,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":95896,"imageIndex":19},{"imageOffset":95545,"imageIndex":19},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":905779,"name":"Background Save","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":38910715,"imageIndex":0},{"imageOffset":28881516,"imageIndex":0},{"imageOffset":28880073,"imageIndex":0},{"imageOffset":68131960,"imageIndex":0},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":1621985,"name":"AMCP Logging Spool","frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":111040,"symbol":"caulk::mach::semaphore::wait_or_error()","symbolLocation":16,"imageIndex":26},{"imageOffset":8330,"symbol":"caulk::concurrent::details::worker_thread::run()","symbolLocation":36,"imageIndex":26},{"imageOffset":7502,"symbol":"void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*)","symbolLocation":41,"imageIndex":26},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":1626241,"frames":[{"imageOffset":8172,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":8}]},{"id":1628209,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":111040,"symbol":"caulk::mach::semaphore::wait_or_error()","symbolLocation":16,"imageIndex":26},{"imageOffset":8330,"symbol":"caulk::concurrent::details::worker_thread::run()","symbolLocation":36,"imageIndex":26},{"imageOffset":7502,"symbol":"void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*)","symbolLocation":41,"imageIndex":26},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":1628210,"name":"com.apple.coreaudio.AQClient","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":6},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":6},{"imageOffset":527090,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":2},{"imageOffset":520651,"symbol":"__CFRunLoopRun","symbolLocation":1325,"imageIndex":2},{"imageOffset":517597,"symbol":"CFRunLoopRunSpecific","symbolLocation":563,"imageIndex":2},{"imageOffset":942269,"symbol":"CADeprecated::GenericRunLoopThread::Entry(void*)","symbolLocation":157,"imageIndex":27},{"imageOffset":49255,"symbol":"CADeprecated::CAPThread::Entry(CADeprecated::CAPThread*)","symbolLocation":77,"imageIndex":28},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":1628212,"name":"com.apple.coremedia.imagequeue.coreanimation.common","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":6},{"imageOffset":27241,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":8},{"imageOffset":127360,"symbol":"WaitOnCondition","symbolLocation":11,"imageIndex":29},{"imageOffset":43975,"symbol":"FigSemaphoreWaitRelative","symbolLocation":145,"imageIndex":29},{"imageOffset":3287637,"imageIndex":30},{"imageOffset":122064,"symbol":"figThreadMain","symbolLocation":276,"imageIndex":29},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":1629008,"frames":[{"imageOffset":8172,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":8}]},{"id":1629149,"frames":[{"imageOffset":8172,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":8}]},{"id":1629243,"frames":[{"imageOffset":8172,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":8}]},{"id":1629244,"frames":[{"imageOffset":8172,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":8}]},{"id":1629246,"frames":[{"imageOffset":8172,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":8}]},{"id":1629247,"frames":[{"imageOffset":8172,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":8}]},{"id":1629248,"frames":[{"imageOffset":8172,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":8}]},{"id":1629249,"frames":[{"imageOffset":8172,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":8}]},{"id":1629256,"frames":[{"imageOffset":8172,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":8}]},{"id":1629257,"frames":[{"imageOffset":8172,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":8}]},{"id":1629258,"frames":[{"imageOffset":8172,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":8}]},{"id":1629259,"frames":[{"imageOffset":8172,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":8}]},{"id":1629260,"frames":[{"imageOffset":8172,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":8}]},{"id":1629298,"frames":[{"imageOffset":8172,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":8}]},{"id":1629299,"frames":[{"imageOffset":8172,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":8}]},{"id":1629300,"frames":[{"imageOffset":8172,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":8}]}],
"usedImages" : [
"source" : "P",
"arch" : "x86_64",
"base" : 4410208256,
"CFBundleShortVersionString" : "23.2.2",
"CFBundleIdentifier" : "com.adobe.Photoshop",
"size" : 136822784,
"uuid" : "bc21ebd7-3d85-3f23-953f-2a5df8f6d4eb",
"path" : "\/Applications\/Adobe Photoshop 2022\/Adobe Photoshop 2022.app\/Contents\/MacOS\/Adobe Photoshop 2022",
"name" : "Adobe Photoshop 2022",
"CFBundleVersion" : "23.2.2"
"source" : "P",
"arch" : "x86_64",
"base" : 140703608905728,
"CFBundleShortVersionString" : "6.9",
"CFBundleIdentifier" : "com.apple.Foundation",
"size" : 3911680,
"uuid" : "bf00b016-c645-3574-b74f-4386750fb009",
"path" : "\/System\/Library\/Frameworks\/Foundation.framework\/Versions\/C\/Foundation",
"name" : "Foundation",
"CFBundleVersion" : "1856.107"
"source" : "P",
"arch" : "x86_64h",
"base" : 140703593676800,
"CFBundleIdentifier" : "com.apple.CoreFoundation",
"size" : 5255168,
"uuid" : "9b112884-be6c-3c7f-9a2a-a47c491105db",
"path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
"name" : "CoreFoundation",
"source" : "P",
"arch" : "x86_64",
"base" : 140703741038592,
"CFBundleShortVersionString" : "2.1.1",
"CFBundleIdentifier" : "com.apple.HIToolbox",
"size" : 3112960,
"uuid" : "c538aa78-7afd-3f8a-8fdb-1fc2acde6b3f",
"path" : "\/System\/Library\/Frameworks\/Carbon.framework\/Versions\/A\/Frameworks\/HIToolbox.framework\/Versions\/A\/HIToolbox",
"name" : "HIToolbox"
"source" : "P",
"arch" : "x86_64",
"base" : 140703638171648,
"CFBundleIdentifier" : "com.apple.AppKit",
"size" : 15278080,
"uuid" : "9d3ab204-4858-3120-b002-5c38b02edec4",
"path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",
"name" : "AppKit",
"CFBundleVersion" : "2113.30.116"
"source" : "P",
"arch" : "x86_64",
"base" : 4793966592,
"size" : 442368,
"uuid" : "7de33963-bbc5-3996-ba6e-f1d562c17c95",
"path" : "\/usr\/lib\/dyld",
"name" : "dyld"
"source" : "P",
"arch" : "x86_64",
"base" : 140703593136128,
"size" : 225280,
"uuid" : "c1d58a50-5a4d-3bcb-a1fc-ec0902ce34d3",
"path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
"name" : "libsystem_kernel.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 140703591579648,
"size" : 290816,
"uuid" : "67d92c93-aa68-34c2-964b-23e8a8d32098",
"path" : "\/usr\/lib\/system\/libdispatch.dylib",
"name" : "libdispatch.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 140703593361408,
"size" : 49152,
"uuid" : "ee564342-d8f2-396d-b642-40092cf34d82",
"path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
"name" : "libsystem_pthread.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 140703592681472,
"size" : 364544,
"uuid" : "fa3f989d-0003-37ef-a495-36be29bc1552",
"path" : "\/usr\/lib\/libc++.1.dylib",
"name" : "libc++.1.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4589309952,
"size" : 573440,
"uuid" : "d5a56ee4-f4cc-380f-b893-76b9d2f58da0",
"path" : "\/Applications\/Adobe Photoshop 2022\/Adobe Photoshop 2022.app\/Contents\/Frameworks\/VulcanMessage5.dylib",
"name" : "VulcanMessage5.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 140703671451648,
"CFBundleShortVersionString" : "1329",
"CFBundleIdentifier" : "com.apple.CFNetwork",
"size" : 4812800,
"uuid" : "3612e3e1-9739-39b2-a97d-9b75862a53fd",
"path" : "\/System\/Library\/Frameworks\/CFNetwork.framework\/Versions\/A\/CFNetwork",
"name" : "CFNetwork",
"CFBundleVersion" : "1329"
"source" : "P",
"arch" : "x86_64",
"base" : 4868616192,
"CFBundleShortVersionString" : "local",
"CFBundleIdentifier" : "com.adobe.uxp.macos.alpaca.v8",
"size" : 42598400,
"uuid" : "a8f0cb52-c89a-3fb1-93fe-c31a3e14f257",
"path" : "\/Applications\/Adobe Photoshop 2022\/Adobe Photoshop 2022.app\/Contents\/Frameworks\/dynamic-torqnative.framework\/Versions\/A\/dynamic-torqnative",
"name" : "dynamic-torqnative",
"CFBundleVersion" : "local"
"source" : "P",
"arch" : "x86_64",
"base" : 4587642880,
"CFBundleIdentifier" : "com.adobe.headlights.LogSessionFramework",
"size" : 1507328,
"uuid" : "96cb4041-f593-393f-a5ed-3e0e00a1f882",
"path" : "\/Applications\/Adobe Photoshop 2022\/Adobe Photoshop 2022.app\/Contents\/Frameworks\/LogSession.framework\/Versions\/A\/LogSession",
"name" : "LogSession",
"CFBundleVersion" : "8.2.0.16"
"source" : "P",
"arch" : "x86_64",
"base" : 140703592120320,
"size" : 561152,
"uuid" : "4b160c81-ec52-3243-aaba-49f719bbf617",
"path" : "\/usr\/lib\/system\/libsystem_c.dylib",
"name" : "libsystem_c.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4948094976,
"CFBundleShortVersionString" : "5.0.3",
"CFBundleIdentifier" : "com.dxo.selectivetool",
"size" : 5173248,
"uuid" : "a23bdae0-5e10-340d-8e9b-67c18e5203b2",
"path" : "\/Library\/Application Support\/Adobe\/*\/SelectivePalette.plugin\/Contents\/MacOS\/SelectivePalette",
"name" : "SelectivePalette",
"CFBundleVersion" : "5.0.3"
"source" : "P",
"arch" : "x86_64",
"base" : 5040963584,
"CFBundleShortVersionString" : "23.2",
"CFBundleIdentifier" : "com.adobe.PSAutomate",
"size" : 4440064,
"uuid" : "2c07e7f5-d5b5-3a82-81b5-f75527f5174b",
"path" : "\/Applications\/Adobe Photoshop 2022\/Adobe Photoshop 2022.app\/Contents\/PlugIns\/Required\/Extensions\/ScriptingSupport.plugin\/Contents\/MacOS\/ScriptingSupport",
"name" : "ScriptingSupport",
"CFBundleVersion" : "23.2"
"source" : "P",
"arch" : "x86_64",
"base" : 13099962368,
"CFBundleShortVersionString" : "3.3626.1882.0",
"CFBundleIdentifier" : "org.chromium.ContentShell.framework",
"size" : 119287808,
"uuid" : "0e0cf0df-f3bd-3ea0-aeeb-f8f6ec8157d6",
"path" : "\/Applications\/Adobe Photoshop 2022\/Adobe Photoshop 2022.app\/Contents\/PlugIns\/Required\/Spaces\/Frameworks\/Chromium Embedded Framework.framework\/Chromium Embedded Framework",
"name" : "Chromium Embedded Framework",
"CFBundleVersion" : "1882.0"
"source" : "P",
"arch" : "x86_64",
"base" : 13451501568,
"CFBundleShortVersionString" : "14.2 (1028)",
"CFBundleIdentifier" : "com.adobe.CameraRaw",
"size" : 103661568,
"uuid" : "cc71553d-7d17-3922-a50d-74796044d059",
"path" : "\/Library\/Application Support\/Adobe\/*\/Camera Raw.plugin\/Contents\/MacOS\/Camera Raw",
"name" : "Camera Raw",
"CFBundleVersion" : "14.2f1028"
"source" : "P",
"arch" : "x86_64",
"base" : 4570505216,
"size" : 131072,
"uuid" : "a1114b8f-f099-3681-8884-1526eaf5dfc2",
"path" : "\/Applications\/Adobe Photoshop 2022\/Adobe Photoshop 2022.app\/Contents\/Frameworks\/libtbb.dylib",
"name" : "libtbb.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4573806592,
"CFBundleShortVersionString" : "11.2.0.100",
"CFBundleIdentifier" : "com.adobe.PlugPlugOwl",
"size" : 3145728,
"uuid" : "a569e456-406d-3152-affa-be229464b454",
"path" : "\/Applications\/Adobe Photoshop 2022\/Adobe Photoshop 2022.app\/Contents\/Frameworks\/PlugPlugOwl.framework\/Versions\/A\/PlugPlugOwl",
"name" : "PlugPlugOwl",
"CFBundleVersion" : "11.2.0.100"
"source" : "P",
"arch" : "x86_64",
"base" : 15011106816,
"CFBundleShortVersionString" : "14.0.0",
"CFBundleIdentifier" : "com.adobe.dvacore.framework",
"size" : 5259264,
"uuid" : "d84f4977-ea10-3109-88e9-785d10693666",
"path" : "\/Applications\/Adobe Photoshop 2022\/Adobe Photoshop 2022.app\/Contents\/Frameworks\/dvacore.framework\/Versions\/A\/dvacore",
"name" : "dvacore",
"CFBundleVersion" : "14.0.0.0"
"source" : "P",
"arch" : "x86_64",
"base" : 14787289088,
"CFBundleIdentifier" : "com.adobe.boost-threads.framework",
"size" : 49152,
"uuid" : "494ca48e-71fa-3304-8e21-9e34f5829980",
"path" : "\/Applications\/Adobe Photoshop 2022\/Adobe Photoshop 2022.app\/Contents\/Frameworks\/boost_threads.framework\/Versions\/A\/boost_threads",
"name" : "boost_threads",
"source" : "P",
"arch" : "x86_64",
"base" : 14789484544,
"CFBundleIdentifier" : "com.adobe.dvatransport.framework",
"size" : 331776,
"uuid" : "7e6c9e00-6068-31a7-819b-bfdc5c5fffae",
"path" : "\/Applications\/Adobe Photoshop 2022\/Adobe Photoshop 2022.app\/Contents\/Frameworks\/dvatransport.framework\/Versions\/A\/dvatransport",
"name" : "dvatransport",
"source" : "P",
"arch" : "x86_64",
"base" : 140704001413120,
"CFBundleShortVersionString" : "17612",
"CFBundleIdentifier" : "com.apple.JavaScriptCore",
"size" : 20119552,
"uuid" : "8d491514-e159-36dd-a89b-245e1331b8a1",
"path" : "\/System\/Library\/Frameworks\/JavaScriptCore.framework\/Versions\/A\/JavaScriptCore",
"name" : "JavaScriptCore",
"CFBundleVersion" : "17612.4.9.1.8"
"source" : "P",
"arch" : "x86_64",
"base" : 140703712145408,
"CFBundleShortVersionString" : "1.11",
"CFBundleIdentifier" : "com.apple.QuartzCore",
"size" : 3051520,
"uuid" : "9e727a38-d1d3-3d6a-940c-0ebfa61e28e6",
"path" : "\/System\/Library\/Frameworks\/QuartzCore.framework\/Versions\/A\/QuartzCore",
"name" : "QuartzCore",
"CFBundleVersion" : "962.63"
"source" : "P",
"arch" : "x86_64",
"base" : 140703738544128,
"CFBundleShortVersionString" : "1.0",
"CFBundleIdentifier" : "com.apple.audio.caulk",
"size" : 143360,
"uuid" : "0a60f9ec-f83c-388e-bcb1-43b785c997d1",
"path" : "\/System\/Library\/PrivateFrameworks\/caulk.framework\/Versions\/A\/caulk",
"name" : "caulk"
"source" : "P",
"arch" : "x86_64",
"base" : 140703820595200,
"CFBundleShortVersionString" : "1.14",
"CFBundleIdentifier" : "com.apple.audio.toolbox.AudioToolbox",
"size" : 1290240,
"uuid" : "f12ce1a4-a5b9-3b68-bc80-df155bd54852",
"path" : "\/System\/Library\/Frameworks\/AudioToolbox.framework\/Versions\/A\/AudioToolbox",
"name" : "AudioToolbox",
"CFBundleVersion" : "1.14"
"source" : "P",
"arch" : "x86_64",
"base" : 140703804186624,
"size" : 196608,
"uuid" : "16b70463-892b-36e2-ad97-e39092df84bc",
"path" : "\/usr\/lib\/libAudioToolboxUtility.dylib",
"name" : "libAudioToolboxUtility.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 140703738687488,
"CFBundleIdentifier" : "com.apple.CoreMedia",
"size" : 1052672,
"uuid" : "f588e97b-d586-39f3-84b5-a3399674cde8",
"path" : "\/System\/Library\/Frameworks\/CoreMedia.framework\/Versions\/A\/CoreMedia",
"name" : "CoreMedia",
"CFBundleVersion" : "2935.5.1"
"source" : "P",
"arch" : "x86_64",
"base" : 140703807819776,
"CFBundleIdentifier" : "com.apple.MediaToolbox",
"size" : 7598080,
"uuid" : "8e5f7be0-8b93-377c-ab9b-c17e52360cf6",
"path" : "\/System\/Library\/Frameworks\/MediaToolbox.framework\/Versions\/A\/MediaToolbox",
"name" : "MediaToolbox",
"size" : 0,
"source" : "A",
"base" : 0,
"uuid" : "00000000-0000-0000-0000-000000000000"
"sharedCache" : {
"base" : 140703590129664,
"size" : 15216836608,
"uuid" : "0939015d-8308-3e69-b095-bd928f835202"
"vmSummary" : "ReadOnly portion of Libraries: Total=1.9G resident=0K(0%) swapped_out_or_unallocated=1.9G(100%)\nWritable regions: Total=19.0G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=19.0G(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nAccelerate framework 4480K 35 \nActivity Tracing 256K 1 \nCG backing stores 4560K 8 \nCG image 11.4M 84 \nCG raster data 60K 1 \nColorSync 248K 30 \nCoreAnimation 204.1M 202 \nCoreGraphics 20K 4 \nCoreImage 4K 1 \nCoreServices 624K 2 \nCoreUI image data 4080K 43 \nFoundation 40K 2 \nIOKit 7940K 1 \nImage IO 1016K 100 \nJS JIT generated code 1.0G 3 \nKernel Alloc Once 8K 1 \nMALLOC 6.1G 5052 \nMALLOC guard page 72K 16 \nMALLOC_LARGE (reserved) 40.3M 2 reserved VM address space (unallocated)\nMALLOC_MEDIUM (reserved) 808.0M 8 reserved VM address space (unallocated)\nMALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated)\nMemory Tag 255 725.7M 1161 \nMemory Tag 255 (reserved) 16K 1 reserved VM address space (unallocated)\nPROTECTED_MEMORY 4K 1 \nSQLite page cache 256K 4 \nSTACK GUARD 56.5M 138 \nStack 330.1M 141 \nVM_ALLOCATE 9.9G 398 \nWebKit Malloc 8348K 11 \n__DATA 75.4M 693 \n__DATA_CONST 45.0M 409 \n__DATA_DIRTY 1636K 225 \n__FONT_DATA 4K 1 \n__GLSLBUILTINS 5176K 1 \n__LINKEDIT 680.8M 115 \n__OBJC_RO 81.8M 1 \n__OBJC_RW 3136K 2 \n__TEXT 1.3G 662 \n__UNICODE 588K 1 \ndyld private memory 1344K 3 \nlibnetwork 1664K 24 \nmapped file 461.0M 112 \nshared memory 1296K 18 \n=========== ======= ======= \nTOTAL 22.1G 9719 \nTOTAL, minus reserved VM space 20.9G 9719 \n",
"legacyInfo" : {
"threadTriggered" : {
"name" : "Main Thread",
"queue" : "com.apple.main-thread"
"trialInfo" : {
"rollouts" : [
"rolloutId" : "607844aa04477260f58a8077",
"factorPackIds" : {
"SIRI_MORPHUN_ASSETS" : "6103050cbfe6dc472e1c982a"
"deploymentId" : 240000066
"rolloutId" : "60da5e84ab0ca017dace9abf",
"factorPackIds" : {
"deploymentId" : 240000008
"rolloutId" : "602ad4dac86151000cf27e46",
"factorPackIds" : {
"SIRI_DICTATION_ASSETS" : "6193d03f2171a2330e561dfc"
"deploymentId" : 240000305
"rolloutId" : "601d9415f79519000ccd4b69",
"factorPackIds" : {
"SIRI_TEXT_TO_SPEECH" : "622657ce37186c771d5404ad"
"deploymentId" : 240000414
"rolloutId" : "5ffde50ce2aacd000d47a95f",
"factorPackIds" : {
"deploymentId" : 240000128
"rolloutId" : "5fc94383418129005b4e9ae0",
"factorPackIds" : {
"deploymentId" : 240000309
"experiments" : [
Model: iMac19,1, BootROM 1715.80.5.0.0, 8 processors, 8-Core Intel Core i9, 3.6 GHz, 64 GB, SMC 2.46f12
Graphics: Radeon Pro Vega 48, Radeon Pro Vega 48, PCIe, 8 GB
Display: iMac, Retina 5K (5120 x 2880), Main, MirrorOff, Online
Display: PA248, 1920 x 1200 (WUXGA - Widescreen Ultra eXtended Graphics Array), MirrorOn, Online
Memory Module: BANK 0/ChannelA-DIMM0, 16 GB, DDR4, 2667 MHz, 859B, CT16G4S266M.M16FE
Memory Module: BANK 1/ChannelA-DIMM1, 16 GB, DDR4, 2667 MHz, 859B, CT16G4S266M.M16FE
Memory Module: BANK 2/ChannelB-DIMM0, 16 GB, DDR4, 2667 MHz, 859B, CT16G4S266M.M16FE
Memory Module: BANK 3/ChannelB-DIMM1, 16 GB, DDR4, 2667 MHz, 859B, CT16G4S266M.M16FE
AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x7BF), wl0: Jul 12 2021 19:26:30 version 9.30.464.0.32.5.76 FWID 01-45ccefcd
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Network Service: Wi-Fi, AirPort, en1
PCI Card: pci1987,5012, NVM Express Controller, Thunderbolt@137,0,0
PCI Card: pci1987,5012, NVM Express Controller, Thunderbolt@138,0,0
PCI Card: pci1987,5012, NVM Express Controller, Thunderbolt@135,0,0
PCI Card: pci1987,5012, NVM Express Controller, Thunderbolt@136,0,0
PCI Card: pci8086,15d4, USB eXtensible Host Controller, Thunderbolt@139,0,0
PCI Card: pci1b21,625, AHCI Controller, Thunderbolt@14,0,0
PCI Card: pci8086,15d4, USB eXtensible Host Controller, Thunderbolt@15,0,0
PCI Card: pci1b21,625, AHCI Controller, Thunderbolt@13,0,0
Serial ATA Device: Samsung SSD 870 EVO 2TB, 2 TB
USB Device: USB31Bus
USB Device: Mercury Elite Pro Quad
USB Device: Mercury Elite Pro Quad D
USB Device: Mercury Elite Pro Quad C
USB Device: Mercury Elite Pro Quad B
USB Device: Mercury Elite Pro Quad A
USB Device: USB3.0 Hub
USB Device: External HDD
USB Device: USB2.0 Hub
USB Device: USB 2.0 Hub
USB Device: FaceTime HD Camera (Built-in)
USB Device: hub_device
USB Device: VLI Product String
USB Device: SDDR-A631
USB Device: Wacom Wireless Receiver
USB Device: USB Receiver
Thunderbolt Bus: iMac, Apple Inc., 47.5
Thunderbolt Device: ThunderBay 43, Other World Computing, 1, 28.2
Thunderbolt Device: Express 4M2, Other World Computing, 3, 33.1
