• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Lightroom 2015.10.1 stops running in Slideshow module
Community Beginner ,
Jul 02, 2017 Jul 02, 2017
I get "lightroom stopped working" when I am in the slideshow module.  I upgraded to 10.1 to try to resolve the problem with no success.  It fails with or without music.
I have not created a slideshow since i upgraded form Lightroom 5 to CC.  I tried to go back to LR5 but my new collections are not available.
Creating Slideshows is the primary reason I use Lightroom.  Please HELP  Graphics processor is not selected in preferences.  OS is Windows 7 with service Pack 1.
Here is the event log.
Faulting application name: lightroom.exe, version: 6.10.1.10, time stamp: 0x591f413f
Faulting module name: ig4icd64.dll, version: 8.15.10.2476, time stamp: 0x4e414c6f
Exception code: 0xc0000005
Fault offset: 0x000000000006556e
Faulting process id: 0x1dfc
Faulting application start time: 0x01d2f3671f02cf38
Faulting application path: C:\Program Files\Adobe\Adobe Lightroom\lightroom.exe
Faulting module path: C:\Windows\system32\ig4icd64.dll
Report Id: 6bc48a54-5f5b-11e7-b9bb-b9eb62bdc79c
Views
437
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee ,
Hi
Could check if there is any GPU driver or Windows update?
Also, could you share if you are facing any specific error?
Smit Keniya
Adobe Lightroom Team
Smit | Lightroom Classic Team
Votes
Translate
Translate
Report
Report
I'm not sure if this is the info you requested. If not plese tell me how
to find the indo.
Regards
Sharon
On Sun, Jul 2, 2017 at 10:01 PM, SmitKeniya <forums_noreply@adobe.com>
Votes
Translate
Translate
Report
Report
Adobe Employee ,
I looked into it. It looks like your OpenGL library is crashing. Could you check if there is an update to your Display driver?
Also, could you share your Display Graphics Card details?
Smit Keniya
Votes
Translate
Translate
Report
Report
Jul 03, 2017 Jul 03, 2017
Thank you for your prompt response.
I did not find any newer drivers to install. Here is what I found.
Regards
Sharon
On Sun, Jul 2, 2017 at 10:42 PM, SmitKeniya <forums_noreply@adobe.com>
Votes
Translate
Translate
Report
Report
LATEST
Can this be a data related problem?
Here's what I've done today.
The slide show I am trying to create has about 380 images which area mix of
cr2, jpg, and Tiffs. They are a collection with the actual images in
several different folders, all on the same external hard drive.
The failure is reproducible and consistent if I pick the same range of
images and fails on the same frame. However the actual frame that the
failure occurs on is specific to the range., A different range fails on a
different image. Excluding those images from the range still results in a
failure - on a different image.
However, I selected about the same number of images from a single folder
with only CR2 images and was able to successfully play the slide show. I
did not try to save it and I did not try other data sets. I also did not
repeat that experiment.
Can the fact that I am selecting images from a collection instead of a
folder be significant? Can the mixture of cr2, jpg, and tiffs be causing a
problem?
Regards
Sharon
Votes
Translate
Translate
Report
Report
